Question about Maytag MMV5156AAS Microwave Oven
Will run, but wont heat.. - Maytag MMV5156AAS Microwave Oven
  • 11,896 Answers
The magnetron is what makes a microwave heat. The megnatron can go bad causing no heat but let the rest of the unit work just fine.
partselect,com and daysappliance are excellent sites for parts, prices, diagrams, and more.
Posted on Nov 10, 2010
Oster microwave OM1101NOE wont heat carosel turns light is on time runs but not heat
There are three things to consider, the magnetron "heats food" high voltage diode "sometimes cracks" and the high voltage capacitor "sometimes shorts" one or more can cause the symptom of no heat. I recommend a professional to assess.
Mar 08, 2012 | Oster Microwave Ovens
Microwave wont heat up food
If your microwave runs, but doesn'theat your food, verify that you have selected a cooking setting. You mayaccidentally set the timer. Test the magnetron by placing 1 cup of water in themicrowave and heating the water for three minutes. If the water doesn't heat,your magnetron is dead.
Mar 08, 2012 | Sanyo Microwave Ovens
Microwave runs but wont heat. sounds a bit labored also while running
The description you provide indicates the magnetron has failed, "heats food" and the labored sound you hear supports that, cheaper to replace.
Apr 07, 2011 | Microwave Ovens
Kenmore microwave runs but wont heat
Hello there:
There's no heat, When the microwave won't heat, soemtimes you will get a loud buzz, you usually have a defective power diode, high-voltage capacitor, or magnetron. We recommend that you consult with a qualified appliance repair technician for help in determining the problem and deciding what to do about it.
Oct 05, 2010 | Kenmore 63252 Microwave Oven
JVM1640WB007 MICROWAVE RUNS BUT DOESN'T HEAT. WHAT COULD BE THE PROBLEM?
It is most common for the magnetron in GE microwaves to go out. This is the part that heats the food. Basically everything on the unit works and runs like normal but it wont heat. Check your owners manual for the warranty on the magnetron. They usually put a 5-7 year warranty on the part itself. If you dont have the owners manual check for it online. Hope this helps you.
Jan 24, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
Wont heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jkfk
Nov 06, 2009 | GE Profile Spacemaker JVM1871 Microwave...
MICROWAVE WONT HEAT
the lock on the door could be loose so the microwave light will turn on but it wont heat u should press on the door or buy a new one emai me at chattarbox24_7@yahoo.com
Jul 21, 2009 | Microwave Ovens
Ge spacemaker runs but wont heat
Hi, there are three issues that will cause a no heat situation in a microwave. these issue are a failed Magnetron, busted cut-off fuse and, failed diode.
I recommend checking all these area that are located inside the microwave for faults.
The most common issue will be a failed Magnetron.
The diode and, fuse will be located on the noise filter assembly.
Jan 16, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My micro wont heat the food but everything else seems ok
I have a GE Spacemaker Microwave, model # JVM1650WB008
The lights work and everything runs in a normal operation, it will not heat the food. I have changed the fuse and still the same, no heat.
Oct 05, 2008 | Microwave Ovens
Wont heat
If the diode is good (not shorted) then I would suspect the magnetron.
Here are some tests that might help:
http://www.microtechfactoryservice.com/diode.html
http://www.microtechfactoryservice.com/mag_test.html
http://www.microtechfactoryservice.com/xformer.html
We\'re happy to help and we appreciate your thoughtful rating of our answer.
Jun 26, 2008 | Amana ACO1860 Microwave Oven
Maytag MMV5156AAS Microwave Oven Logo
219 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
