Question about Logitech QuickCam Express Web Camera
Microphone not working
Everything seems to be working OK, but the microphone isn't picking up any sound. The bar shows 1 green slot lighted, but moving the slider bar up makes no difference.
  • jillian m Jul 15, 2008
    Ya I have the same problem. The webcam records fine just the microphone isnt working.
    Iv'e gone to the setting and everything i thin is possible i just cannot fix it.
  • Anonymous Feb 05, 2009
    the mirophone does not work. the person on the other end does not hear me.
    President:
  • 8,637 Answers
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Posted on Feb 04, 2009
What? Kenmore central vac S107 34089?
Sounds like it's overheating and tripping the thermal breaker. The motor housing should have some ventilation (cooling) ports or slots. Inspect them carefully and remove any clogs and debris you find.
May 25, 2014 | Vacuums
My Samson C01U microphone doesnt seem to be working. the green light doesnt turn on when i plug it into the usb port of my computer. I have windows vista. Is it not compatible?? The computer says the...
Sorry this isn't a solution but just letting you know I'm having the same trouble, the funny thing is mine was working a couple of months back and now its not, it's driving me crazy.
May 19, 2011 | Samson C01U Consumer Microphone
My microphone is not working. What do I do? Trying to use Skype, but microphone want work
Hi ldlw65,
Please follow the below steps to set up your microphone properly :-
  1. Firstly check if your microphone's cable is in proper order, if it has been damaged, then it's that physical fault which stops microphone from working.
  2. Now if the wire or cable of microphone is OK, check if you have connected your microphone in the correct slot , in your motherboard , usually there is a sign of mic besides the microphone slot.
  3. Then check for the control panel's sound and audio devices option , by going in your control panel, if you open it and go in the audio tab you should see your recording device as enabled.
    If it's disabled then you need to install your audio driver's again.
  4. Now , if everything is ok till here , all you need to do is do a microphone check by going to sound recorder (start >programs>accessories >entertainment>sound recorder )in windows xp , in case you are using windows xp or any relevant software in the other operating system which records audio.
  5. Once you have the application like sound recorder try speaking on mic while you activate the record option , if you see that your sound is being recorded, then your mic is functioning properly, if it's not then you need to check if your mic is the current recording device.
  6. To check if your mic is the current recording device , all you need to do it double click on the volume icon on your task bar and you will have volume control box open , then you need to go to the options menu and choose properties.sajjad4help_2.gif
  7. After you choose properties you will have a radio button for recording , select it and you will find devices for recording , then make sure microphone is selected and click ok.sajjad4help_6.gif
  8. After you select ok , then you need to select microphone from the recording options to activate recording via your microphone.sajjad4help_7.gif
Now you should be able to use your microphone properly without any problems.
Your feedback would be appreciated.
Hope this helps ..)
May 13, 2011 | Toshiba (P000257700) Microphone
I can't seem to get PowerPoint to pick up the sound from the microphone..... I have tried every conceivable setting under the sun.... Using Microsoft XP.... Message telling me to go to Multimedia...
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Mar 01, 2011 | Dynex Voice-Certified PC Desktop...
I have a new Compaq 610 laptop with XP professional. For some reason we can't get the internal microphone to pick up any signal. What can we do to fix it?
wel first of all did you installed the sound card? And after that go to the control panel and sound and audio devices = > click on advanced a new window will pop up click in the left corner on OPTIONS and be sure in properties the mic box is checked and after that go again to OPTIONS and click Advanced options, under de mic level bar you wil have a buton called advanced click`it and Check the box 1 mic boost
Mar 11, 2010 | Computers & Internet
I cannot hear any microphone playback
I cannot hear any microphone playback 2) Installing the driver software for it takes sound out of my computer my microphone seems to be fine because the green light comes on when i test it, but no playback in speaker when i record. I know im jus missing one little thing...can you help me?
Feb 08, 2010 | Tascam US-122 USB Audio/MIDI Interface...
I have a 57abeta radio mic. Everything appears to
Please check if the gain in the microphone is open.
Ther's a little hole where you can adjust the gain.
Good luck,
Gerard
Dec 20, 2009 | Shure (LX287CC) Professional Microphone
Delay in pick up
If the audio is being run through a "noise gate", that is what clips the first part of sound.
Reduce the attack time of the noise gate or remove it from your system.
Oct 27, 2009 | Shure SM58 Professional Microphone
My dell inspiron 1525 microphone does not record.
I have a Dell Inspiron 1525. I used Skype ages ago and returned to it a couple of days ago. No one could hear me. I researched for 20 hours, downloading drivers, checking EVERY setting possible and NOW have got the ANSWER. The wires in the Microphone Array are fatigued. My microphone works perfectly when I tilt my lcd screen half way down. Go to Webcam Manager, Tools, Audio controls, the microphone has 2 bars which go green when you talk into it. Tilt your screen and watch the bars go up and down. Not the answer you probably wanted but as long as you skype with your screen half tilted everything is good to go
Mar 15, 2009 | Dell Inspiron 1525 Notebook
Acer Laptop built in Microphone
Try the link . . . www.laptop-problem-solution.com
For find your best solution.
48
Aug 22, 2008 | Computers & Internet
Logitech QuickCam Express Web Camera Logo
55 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
