Question about Indesit W 123 Front Load Washer
My machine has washed a load half way and stopped. The water is still in the machine and I am unable to open the door. What shall I do
Pull out the machine. remove the drain hose from the water outlet pipe and place it low down in a basin on the floor. The water should empty from the drum by gravity. when the water empties you should be able to open the door.
The water pump may be blocked. To check this, unplug the machine, tilt it machine backwards and have someone hold it. Have a look underneath and if you can locate the pump you should be able to rotate the impeller wheel, (probably plastic) freely by hand. if there is any resistance, it is most likely blocked, (small sock, coin etc.). You may need a service man to repair this
Posted on Nov 15, 2010
Malber P28 washer. On hot water cycle the drum is part filling with water then stopping wash cycle and door is unlocking. I was able to open the front loading door with the drum half full of water - gushed...
Sounds like a control pcb malfunction. Remember that you are dealing with MAINS Voltages which can be lethal.
Never continue to use a machine that floods or enables random water release for any reason. The end result might be Electrocution, and it is certainly not worth that risk
Poppa
http://www.cdbaby.com/cd/poppamadison
Oct 04, 2013 | Malber P28 Front Load All-in-One Washer /...
Unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Oct 02, 2009 | Zanussi ZJ1217 Front Load Washer
C2 error
aeg lavamar error c2
Dec 25, 2008 | Maytag NFW7200TW Front Load Washer
Kenmore HE4 latch will not unlock, unable to close door
is there water in the machine if so you need to clean your pump there is a safety feature on the washer that does not allow the door to open if there is water in the machine if you open the pump be sure to have plenty of towels around
Dec 24, 2008 | Kenmore Elite 45986 Front Load Washer
Not quite enough water getting into the machine. Some washes coming out with dry patches on the laundry
hi when doing wash are you sure wash load button is set for full load and not half load ? as half load is less water used and wash time can you hear water entering machine clearly when on ? also check the tun on/off tap for wash machine pipes are fully open as well as the main water supply stop **** for your abode ?
Nov 01, 2008 | Washing Machines
Hotpoint WT741 Front Load- unable to open door.
hi julie,
is there an error message on your display?
can you provide me with the complete model #?
Jul 05, 2008 | Whirlpool AWM6120 Front Load Washer
Washing machine
usually switching off at the mains and the machine and waiting for a few minutes should do it. Make sure the programme select dial is at the correct position. Have you tried emptying out the water first? (either by putting it on a spin cycle or physically removing the outlet hose from the pump and catching the water in a basin or bucket)
Mar 23, 2008 | Washing Machines
Kenmore HEt4 code F11 and F dL
Some machines will not let you open the door if there is still water in the machine. Try syphoning the water out by removing the drain hose where it connects to the plumbing and letting it go lower than the machine. The water wll run out and you should then be able to open the door. If door still does not open, replace the door interlock.
Nov 02, 2007 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
Indesit W 123 Front Load Washer Logo
98 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
