Question about RCA HD52W59 HDTV Projection Television
THIS SET IS GRAVEYARD DEAD. WHEN YOU TRY TO POWER IT ON, THERE'S NOTHING. I DON'T HEAR ANYTHING FROM THE SWITCHING MODE CIRCUIT. I MEAN THAT THIS THING IS DEAD.
  • RCA Master
  • 8,617 Answers
If the power light inst lighting even briefly its usually related to the Main AC filter board.
Posted on Nov 10, 2010
My Samsung led tv model number un60eh6003f is turning on but it has no picture
Fault with its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Nov 20, 2014 | Televison & Video
Squelch won't turn off, won't go into power save mode
Power-save mode means the radio is being turned on and off repeatedly, to save power. The radio turns on, & if it hears any signals (i.e., if squelch circuit determines a station is being received), it turns on the speaker; else it turns off again to save power. So, squelch and power-save modes work hand-in-hand, and your problem is squelch circuit is either set too low, or a station is being received by the receiver. Download/look at the owner's manual and adjust the squelch circuit for a higher setting, and it should go into power-save mode again.
Good luck.
Nov 10, 2013 | Cobra LI 7020 WX-EVP Two Way Radio
The PC is dead, no fans run or anything. It will not power up so I bought a new power supply and installed it but still the same issue? It does have 120 vac power into the power supply.
maybe your CPU is busted.try to replaced a new processor and test it.or double check the setting of the power on *********** board switch,maybe you inserted wrong.
Jul 11, 2011 | Computers & Internet
My hard drive wont read it worked before dont know why
A disk-drive has several major components:
* the electronics circuit-board
* the power/data external connectors
* the motor that spins the disk-drive
* the read/write mechanism that moves above the recording surface
* the recording surfaces
No power means no "spin", and nothing happens.
Dead motor means no "spin", and nothing happens.
Dead electronics on the circuit-board means that nothing happens.
Damaged read/write mechanism.
Damaged recording surfaces.
Feb 26, 2011 | Hitachi Computers & Internet
AC was weak so had it recharged. Everything was fine for the rest of the day. Next morning I started the car, turned on the AC, was putting junior into his carseat when the AC quit. I turned it off then...
read the owner manual to see how the auto works. try the defrost mode whcih is a fail safe mode and should always come on unless a major system issue.
Oct 15, 2010 | 1988 Jaguar XJ6
My RCA52W59 wont turn on. I plug it in and the
Common faults with this model are flyback trans former and power supply problems (capacitors)
This set is in shut down or protection mode and will attempt to restart 3 times
Read below and decide if you want to tackle the problem yourself if so I’ll help along the way with what info I have. If not contact the nearest repair shop armed with the info below.
A dead set (no picture no sound) can indicate any number of problems – Usually the set is in shutdown or protection mode – this means that the internal circuits have detected a problem with a supply voltage missing, drawing too much current, going over voltage or a short condition.
The first thing to do is power off the set unplug it for 5min. than replug and try again. This in effect resets the main micro and will sometime unlatch a fault and resume working. There are certain common problems based on the make model – for instance convergence output IC’s(CRT projection TV’s) can cause a dead set symptom in many models. Vertical output IC failure can also cause the same symptom (CRT standard and Projection).
The only way to determine the real cause is :
By an educated guess based on experience or by directly troubleshooting the set – checking fuses, measuring voltages and checking for shorts. Many of the intermittent problems such as, int.(Intermittent) no sound or picture, int. picture shrunken or misshaped. These problems are generally due to cold (bad) solder joints (all TV’s and electronics) that break down under slight temperature changes or vibration and are usually verified by physically tapping the suspected area on the circuit board, or by quickly heating or cooling a suspected component or area ( cold spray and hot air gun). The other main culprit is leaky or dried out capacitors or capacitors that change value depending on temperature. These can sometimes be seen as bulged or leaky and have an acrid odour.
Sep 30, 2009 | RCA HD52W59 HDTV Projection Television
No Display, no audio, no power up sounds.
Sounds like a hardware failure because your not even reaching post. which means that its not software. i would take out the ram and hard drive. and then putting them back in. if that didn't do anything than I'm going to say you've probably got a dead mother board.
Aug 19, 2008 | Toshiba Satellite A135-S2276 Notebook
Neovia 38inch flat screen lcd
maybe inverter board problem or maybe eeprom on mainboard corrupt-i would say inverterboard
Nov 14, 2007 | Televison & Video
No power to tv
You say didn't do anything, Like did you hear a squealing sound or did you see led lights on front of panel or just dead nothing? If dead and nothing then look for fuse blown in power supply if not then there maybe a small sound coming out of set when you press power if so then the power supply is trying to start up then you will have to look elsewhere like horizontal or convergence or vertical areas.
Sep 18, 2007 | Philips 51PW9363 51" Rear Projection...
RCA HD52W59 HDTV Projection Television Logo
35 people viewed this question
Top RCA Televison & Video Experts
Steve Allison
Steve Allison
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
