Question about LG Washing Machines
Hi. Have a wd-12392TD Direct Drive LG washing machine. When I starts working and drum begins to rotate it seems it's working fine but as the load inceases (after some water added to the drum) it seems that it's too difficult for the motor to work, it sounds as if there are loosey parts inside ( sounds a bit like abag full of nails or nuts hitting each other). I've tried to replace the motor->didn't help. I've opened the back, and started a cotton cycle, after few min' when it got 'stucked' using a tool I helped the rotor to cycle. It doesn't allways get stucked but as too often. Any ideas why ??
  • 1462 Answers
SOURCE: Drum will not rotate
im confused as to why you think no drum rotation would be caused by bearings. typically worn bearings would cause noisy spin. only if bearings were completely seized would that cause no drum rotation. can you rotate drum by hand? if so bearings are not seized. can you hear motor rotate when you select spin? if not, then likely cause is motor brushes. do these simple tests and get back to me if you want. and bearings are quite difficult to replace on this machine
Posted on Apr 27, 2007
  • 139 Answers
SOURCE: no spin
Your problem is that the carbon brushes on the motor have worn out and need replacing.. eaisly done
Posted on Dec 11, 2007
BADBOYJAY
  • 264 Answers
SOURCE: LG Direct Drive WM-16220FD loud vibration during spin cycle
the pump hose is knocking if you can unplug the machine and tilt the machine on its back you can see the hose get a cable tie big one you can cable tie it down that would stop it from moving that's why its knocking if the pump is not on that side then your suspension leg is on its way out meaning you will have to call your local second hand shop to have a look but be for you do have a loo your self save money
Posted on Jan 05, 2008
  • 9 Answers
SOURCE: WMA62
Have you checked to see that the waste is not blocked? THis is very common on these machines and causes the pressure switch not to operate, making the machine fail to spin or spin with water in the drum, causing unbalance symptoms.
This is extremely common on Hotpoint machines without a accessible filter. The filter is in the rubber waste pipe under the drum and needs to be removed to be cleaned out. When iti s blocked it also blocks the chamber that operates the pressure switch.
Posted on Feb 29, 2008
SOURCE: My Hotpoint Aquarius WF210 washing machine drum is not rotating
I think the belt has come off or has been damaged.
To open the machine slide out the machine. On the back panel lower 1/3 you will see a plastic panel remove the screws and the panel will come away. Inside you will see the belt. I suspect you will need to reattach the belt of remove it and buy a replacement.
Sin é
Posted on Jun 27, 2009
Hi. Have a wd-12392TD Direct Drive LG washing machine,gives OE error code and makes a lot of rattling noises, water won't pump out,
take the back off
see if the water pump making that noise or is broken
should look something like this one
May 18, 2016 | LG WM Washing Machines
Drum starts to move then stops then Le appears and a slight hissing noise from direct drive motor. Looks like intemittant fault
The LE error message means "locked motor error" which means the control is not seeing the motor running.
The problem can be caused by a broken wire or loose connection but the most likely cause of the problem is a bad hall sensor.
The sensor can be accessed by removing the rear panel and the rotor assembly. See the image below for help with this. Remember to unplug the washer first.
Make sure the rotor and drum rotate. Anything blocking the tub rotation might trigger an LE code.
Aug 11, 2011 | LG WD-1080FD Front Load Washer
I have a LG front loading direct drive washing machine (WM1812CW) that is 5 years old that is making a loud knocking noise during the spin cycle and is emitting a burnt smell after the cycle ends. ...
It seems you need to have a new sealing rubber fitted. IN THE MEANTIME, if the knocking happens again when the spin starts, stop the machine, let the washing drop to rest, and then start it again, the re-positioning of the fabric inside the drum should even out. Also, do not load with say.. only towels, that way the weight is one sided and will make the drum spin in an uneven way.
Oct 07, 2017 | LG WM1812C Front Load Washer
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
New washer, seems to work fine. I just question the water filling sequence at start of a wash. The water valve opens in 1 sec spurts about 6 times when drum is rotating in one direction. On 7th time it...
Every few months, new things are done to improve washing methods. If washing machine is washing clothing cleanly, and no apparant fault code comes up, then it is how the controller is programmed and meant to be.
Aug 14, 2010 | LG Washing Machines
Bosch WFMC 3200UC can't rotate the drum
that test indicates a faulty speed sensor or wiring harness.
Jan 23, 2010 | Bosch WFMC 3200 Front Load Washer
LG direct drive washing machine WM-16220FD
This is a fun task. Not sure of this model number, whether it has a heater or not, if it does you can remove the heater and attempt to get out whatever it is out through there. The other way is to remove the bottom bellows, drain out the water through the drain trap first, this will give you a bit of access. The easiet way is to take the front panel off, otherwise you would have to tip the unit back, securing it, and trying to access it that way.
good luck.
Sgt 48
May 17, 2008 | LG WD-1280FHD Front Load Washer
Wm noisy
drum bearings, check and investigate, remove drive belt and then rotate, if still noisy then yes its the drum bearings, if the noise stops when the belt removed the motor bearings are faulty costly repair on most models, sorry oh there is also the possibility there is something lodged within the drum cavity between the lining and the drum casing
Sep 25, 2007 | LG WD-16110FD Front Load Washer
Washing Machines Logo
96 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
