presume its an electronic gas oven.
on the main burner in the bottom of the oven (you might need a screw driver to remove the lower cover inside the oven) you will see a spark plug that makes the spark for ignition and you will see what looks like a bent bit of wire that is in the flame when its on. the bit of wire is the flame sensor. check that it is in the flame and hasn't moved. also give it a clean with a bit of fine steel wool to remove any carbon that might have built up on the flame sensor.
also here is a link to a free manual down load.
http://www.bakeryequipment.net/Baxter_OV500_Series_Rack_Oven_Manual_p/ov500ge.htm
