Question about Craftsman Garden
NEED TO SET IDLE SCREW AND MIX SCREW ON A GAS LEAF BLOWER
  • 297 Answers
The Idle screw should just touch the throttle lever to start, the low speed should be set at 1 to 1.5 turns out from lightly seated, and the high speed should be set the same. Final adjustments are made only after it has been warmed up. If you adjust before 2 minutes of use the mixture will be too rich.
Hope this helps
Posted on Nov 11, 2010
When running does not run on high when set to ?
You have a c@carburetor issue.. the needles need adjusting
Nov 05, 2015 | Homelite 'Yard Broom' Leaf Blower
How to start ryobi leaf blower model 09050 i tried everything i primed it with gas tried shooting starter fluid in it
Do you have a spark on the plug? Did you use gas-ethanol mix?
Use premium only.
Sep 12, 2015 | Ryobi Garden
I have a echo pb251 gas blower,stop running,has spark,rebuildt carb.fuel filter,after no start,plug is wet & sparks but wont hit/start
screw air mix screws in the out like a half turn each, one controls the high end speed and one controls the idle, do idle first and adjust just a little rich then do high speed screw.
Nov 03, 2014 | Echo Garden
What is gas ratio 50 t0 1 for homelite leaf blower
50:1 is the gas ratio... thats about 2.6 ounces of 2 cycle mix to one gallon of gas
Sep 14, 2014 | Homelite Garden
Required fuel oil mix
Two-stroke oil with a 50:1 (Gas:Oil) mix ratio is required for the Husqvarna 125B leaf blower. Using the wrong oil or improper mixture ratio can drastically affect the performance of the leaf blower.
Nov 02, 2012 | Husqvarna Hand Held Blower 125 B Grass...
Need carb adtusted
Hold @ full throttle and adjust high (H) screw until she raps out to max RPM, let off, if idle is rough adjust low (L) screw until idle is achieved, You should have it, if not, clean carb and check fuel filter.
Nov 26, 2010 | Troy-Bilt 31cc 2-Cycle Gas Powered...
Fuel Mixture Ratio Is it - 25:1 40:1 50:1
not sure if yo are changing the jets out but if your using the original screws and jets screw both screws in till they stop then turn 1 and a half turns out they try starting if it kicks and won't run then turn each screw another 1/2 turn out try starting if it runs rough adjust the gas jet a little bit till it runs smooth once it warms up give it full gas and you should get just a slight puff of black smoke to be set right, if it's too lean it will get hot and will be hard to start if it dies, if that happens then give it extra gas. once warmed up it should idle without dyeing if it dies adjust the idle screw up 1/4 turn at a time till it runs at idle without holding the gas trigger, be sure you replace the in line fuel filter and fuel line first then clean the air filter before doing any adjustments. most problems are caused by plugged fuel filter due to ethanol in the gas.
Mar 10, 2010 | Garden
Mb 3200 gas leaf blower will start when choke
The carburetor could need rebuilding or you have some bad gas. I would mix up some 2 cycle oil and fresh gas from the station. I would try the new fuel mixture first.
Good Day.
Nov 02, 2009 | McCulloch 26cc Gas Blower Mcb3208
BX 90 homelite leaf blower two idle screws
The initial setting is 1 1/2 turns out. Screw them all the way in and them turn them 1 1/2 turns out. This is the starting position and should start, it may need some final adjustments to run like you need it to run.
Remember more the screw is out the more fuel it will get.
Good Day.
Oct 14, 2009 | Homelite 'Yard Broom' Leaf Blower
Gas only or add mix?
mix!!! regular gas will ruin it
May 17, 2009 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
237 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
