Question about Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer
Hello, How to disable WIFI; - Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer
  • LXK Chris
    LXK Chris Nov 12, 2010
    I'm afraid I'm not completely understanding what you're trying to do here. It's sounds to me that you don't want to use the printer's wireless function/feature. Unfortunately, the WiFi function of the printer can't be disabled. If you prefer not to use it, just connect the printer straight to your computer via the USB cable. Your printer should have a USB cable included in the package.
How do I go about disabling wi-fi on a samsung smart tv?
Hello. I can't think of a good reason to disable wifi on a smart TV, and there are a couple of reasons not to! Reason number one, wifi allows the TV to access the internet for things like YouTube, Netflix, etc., and without wifi, the TV can't update the software, which is vital to getting the most out of the TV. Also, without wifi, the TV is no longer smart, so why buy a smart TV in the first place? By the way, wifi isn't two-way unless you are using an app like Skype, and you aren't creating a hotspot. I hope I answered your question.
Aug 08, 2016 | Samsung Televison & Video
My digihome wifi sayin disabled I can't go down or use button to enable it is there another way?
Hello Shannon,
Disabled WIFI can be frustrating. In a case like this, there is usually a button on your wireless router or laptop that DISABLES/ENABLES the wifi functionality. I would look for this switch or button and make sure it is ON. On a laptop, it may also be a FUNCTION key at the top of the keyboard. Just hold down the FN key and press the FUNCTION key that has a wireless symbol painted on it.
Otherwise, check the software on your device. Many wifi devices come with software that can be installed from a CD or the Internet. That software may also have a feature that can disable the WIFI.
Apr 29, 2016 | Computers & Internet
I can't connect to WiFi. Any advice?
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
Jun 04, 2014 | Computers & Internet
How to use internet in androidtab 7
Hello , with any tablet device, including Ipads, or Androids, device, check for setting and wifi setup, or if enable, or perhaps disable? if so, enable it. check for wap and secure open wifi areas
Oct 02, 2013 | Acer Iconia Tab A200-10g16u XE.H8QPN.001...
Hello sir, i am using apple iphone 3g i am getting internet connection autometically so i am loosing money in the left corner of the phone letter E is always visible i wants to disconnect the internet pls...
1.Turn on your local Wifi either home or how so its temporaily disabled the 'E' Edge connection provided by your carrier provider
2.After the Wifi is connected
3.Open safari browser on your iphone
4.Type in the address bar www.iphonenodata.com
5.Scroll down to the end until you see a Disable EDGE/3G
6.Click on Disable EDGE/3G
7.You'll see a popup asking you to install a Profile
8.Install the profile and after the installation is done
9.Restart the iphone
10.Turn off the Wifi
11.Wait for 'E' to appear on the statusbar (Edge)
12.Try surfing the internet
13.If you get an error saying "Could not activate cellular data network"
14.You have successfully disabled the edge it will longer take your money if the phone is idle
Mar 27, 2011 | Apple iPhone 3G
Where is the wifi switch on the ibm thinkpad and how do i fix it
hello dear first you check in the computer BIOS may be disable /enabled so if disable then you enable then its working
if have a button on keyboad then push the button of FN or that key who have a sign of wifi press it
okyyyyy dear by take care
Dec 25, 2010 | IBM ThinkPad T42 Notebook
Is there a way to turn on the WiFi function
Try to disable the network card using the Device Manager.
Apr 13, 2010 | ASUS Eee PC 900HD Netbook
I have no sound or wifi on my tecra p9000 laptop,any ideas?
Firstly, go to "control panel", click "sound" and confirm if the sound was disabled or not. Also check if your wifi was disabled or turned of.
If there is still no sound, then maybe the sound and wifi of your laptop are not installed. To confirm this, go to "control panel", click "system", from system, look out for "Device Manager", under device manager, you will find a list of all your computer hardware(s) that are installed and not installed. If your wifi and sound are amongs the hardware(s) not installed, then you will have to look for drivers to install them. After installation, go back to the device manager to confirm if they installed not.
Take care.
Nov 18, 2009 | Computers & Internet
Toshiba satellite wifi not working
Hello
You might have physically switched on the adapter, but in Windows it is still disabled.
In Windows XP, click the start button, look for CONNECT TO (don't go in the all programs menu), and click SHOW all connections. A window opens showing all the connections available. If the wireless connection icon displays a red X crossing it, it is disabled.
To reenable it,
Point the mouse cursor to the wireless connection and right click mouse button. Click enable or repair.
One question though. If your computer is toshiba, you must have installed the configFree software that came with it.
If so, look to the left right of the task bar and click the ConfigFree Icon. Choose Connectivity doctor. It will diagnose your connections. If one is disabled or has a problem, a yellow triangle with an exclamation mark ! will appear on the connection.
Use the device setting thumbnail, select your WIFI adapter . A button at the right bottom side, will show either Enable (if your adapter is disabled), or disable i(f adapter is enabled). With that button, you can toggle between enable and disable. After that click the close button, and hopefully you will be able to surf the web.
Hope it helps
Hope it helps
Aug 21, 2009 | Dell Inspiron 6400 Notebook
Wifi connection
hello
1. what is the model number of your adapter?
2. what is the operating system of your computer?
3. did you install the wireless adapter on your pc or is it a built in wireless adapter?
-- if you install another wireless adapter on your pc, possible that its the one causing the conflict between the two utility. I suggest to disable the other adapter before installing the other wireless adapter
-- if the wireless adapter is a built in wireless adapter and you are using a windows xp computer, chances are that the built in utility and the xp wzc are the one causing the problem. you have to disable one of this utility to make your connection working
-- the utility is sometimes located at your system. if you wish to use the utility you have to disable the wzx or the other way around.
Apr 30, 2008 | WiFlyer - Portable, shareable WiFi base...
Lexmark Prospect Pro205 Wireless All-In-One InkJet Printer Logo
104 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Clive
Clive
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
