Question about Rancilio Silvia Espresso Machine
Coffee is not coming out hot enough
When I make an espresso shot the coffee is not coming out hot enough. It is more like room temperature.
I am not sure how old. It was a gift. It is definitely not the latest model. As far as descaling,I am also not sure.My father had someone come out and take a look at it and he said it was fine. If you recommend descaling that is what I will do.
Posted on Jul 15, 2008
  • 515 Answers
How old is the machine?
Do you descale it regulary?
If ther are calcium in the boiler then you get this problem.
Water not hot enough
Set the temperature to "extra hot" If still not hot enough, try zapping your coffee for a few moments in the microwave.. no coffee machine will boil the coffee as this would burn and cause an awful burned coffee taste
Apr 19, 2014 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Our Delonghi Prima Donna always made hot coffee up until 2 weeks ago
Try first to heat the cups ,and then make the coffee.
Becouse the water for coffee and for hot water comes from the same way.
Apr 25, 2017 | DeLonghi Prima Donna Avante ESAM6700...
DeLonghi Magnifica 3200 how to increase coffee temperature?
Evening to you
Not hot enough, do you leave it to stand with the green lights on?
By my experience the machine is best left on so everything is hot when the water passes through.
To let some time pass before you make the next cup.
And lasly to make sure that machine is clean.
Good luck
kolbrun
Mar 05, 2012 | Faberware FSCM100 Coffee and Espresso...
Coffee brewing comes out in a fast steady stream when brewing, coffee doesn't brew properly and comes out weak. taste like unbrewed.
If it comes out in a steady "stream" it sounds like the sprayhead is missing. The sprayhead disperses the water out and evenly over the grounds.
If the sprayhead IS in place then it could be a temperature problem. If the temperature is not hot enough the coffee will not brew correctly.
Sep 06, 2010 | Bunn Coffee Makers & Espresso Machines
Milk is not dispensing hot enough from saeco Primea Cappuccino Touch Plus coffee maker?? any ideas
I have the same problem, my wife complain me everyday, now we use our coiffe machine 90$ from sears it`s still better then this 3200$....
Apr 25, 2010 | Saeco Primea Cappuccino Touch Plus Coffee...
Coffee is cold and not brewed properly. Unit has been cleaned,de-calcified, rinsed, but still the coffe is cold. temperature is set to high, and the machine can produce steam. Anyone help?
Check water temp, if water temp is insufficient , most common is scale heating element , faulty element, faulty thermostat.
Check if water is dripping right at the center of the filter, if it is dripping on one side because the orifice is clogged, that can result in weak coffee.
Coffee blend not well distributed on filter basket.
On Espresso machines:
Check water temp, same as filter coffee machines (thermostat element, scale on heating chamber).
Ensure that coffee is filled correctly in the filter cup (fill at level), and well pressed.
Ensure that the coffee mixture that you are using is not too coarse, buy the apposite one for espresso.
Ensure that you are not leaving the machine brewing for a time that is too long, and Italian coffee cup is very small, approximately one regular shot.
On the hob moka pots (espresso, Moka and Bialetti type):
This are the trickiest ones, you need art and practice to get a good espresso with a Moka, but when you learn, the result is better than what you may get with an home electrical espresso maker.
The frame on the hob must be not too strong, and the mixture coarse but well pressed, with water at level tag, or you will get a weak coffee.
On Mokas a good strategy is keeping hob at minimum, and turning up the flame at top when coffee starts coming out.
French and turkish cafetieres:
Ensure that you put enough coffee, water hot enough, and that you left the infusion enough time to get a strong coffee.
Note: insufficient pressure and clogged lines on electric machines never give you a weak coffee, exactly the opposite.
Not pressed mixture always gives weak coffee, but too much pressed mixture may give you coffee with bad taste.
Apr 02, 2009 | Gaggia Titanium Espresso Machine
WEAK COFFEE & NOT HOT ENOUGH
Basing on personal experience (you can find more on Google probably), solutions are:
On percolated (filter) coffee machines:
Dec 22, 2008 | Bunn NHB Coffee Maker
The water that comes out thru the coffee gounds and into the carafe is only warm not hot.The coffee that is brewed is weak and only warm.
Sep 12, 2008 | Krups Small Appliances Espresso Machine
Sissling when making espresso
First of all, do you steam your milk first then immediately brew the shot? If so, that is your problem. When you depress the steam switch, the temperature elevates way past what is optimal for brewing espresso. If you try to brew immediately after steaming milk or using the hot water feature, that would definitely be why your espresso sizzles. Your shot will likely come out burnt tasting, thin and just plain rancid.
Either brew your shot first (learn temperature surfing for your best shots), or immediately after steaming milk, turn off the steam switch, depress the brew switch (without portafilter in place) for a few seconds until no steam comes out- only water (wait till you don't hear the sizzling sound). Hope this helps.
Aug 07, 2008 | Rancilio Silvia Espresso Machine
Wet Steam? Weak Espressos
Sep 11, 2007 | Saeco Vienna SuperAutomatica Coffee...
Rancilio Silvia Espresso Machine Logo
169 people viewed this question
Top Rancilio Coffee Makers & Espresso Machines Experts
vilhj
Level 1 Expert
Craig Butler
Craig Butler
Are you a Rancilio Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
