Question about Packard Bell Computers & Internet
When i switch my tower on it starts up two beeps screen works for 3seconds then tower shuts down i have replaced the motherboard battery but this didnt fix problem any advice
  • Packard Bell Master
  • 5,660 Answers
The beeps you hear are BIOS Beep Codes.
The computers way of telling you something is wrong, and an area to look into for it.
It sounds as though your Packard Bell has an AMI BIOS.
[American Megatrends Inc.
BIOS stands for Basic Input/Output System]
2 Beeps then a pause, then it repeats usually means a problem with the Ram Memory.
I would suggest you remove the Ram Memory modules, ('Sticks'), and clean the gold plated contact pins on the bottom.
This is an example of a DDR Sdram ram memory module,
http://en.wikipedia.org/wiki/File:Generic_DDR_Memory_%28Xytram%29.jpg
(You can left-click on the photo to enlarge. You can enlarge twice)
Use a pencil eraser to clean the gold plated contact pins on the bottom, of the ram memory module.
Both sides.
If you are not using a solid eraser, and using one on the end of a pencil, refrain from letting the metal band contact the pins.
Rub the eraser up, and down each contact pin.
You may not see anything happening for your work, but I assure you that you are cleaning the contact pin.
Doesn't take much pressure with the eraser.
{The gold plated contact pins develop corrosion on the surface. Doesn't take much corrosion to make a bad contact ]
Use air to remove the eraser dust.
You can use a can of compressed air for computers, or air pressure from your mouth will be sufficient.
If you have a can of compressed air for computers available, also use air to clean out the ram memory slot/s.
Reinstall the ram memory. Close the computer case. Plug the computer into power, WAIT 1 minute, turn the computer on.
Basic guide in a video of how to remove, and replace Ram Memory,
http://www.youtube.com/watch?v=r2EC4BxtBSY&feature=related
NOTE*
When I stated basic guide, I meant Basic.
Since you have already replaced your CMOS battery, you are probably aware of the following.
If so, please disregard.
Always work on a table. If your table is directly on a carpet floor, do not swing your legs.
Observe Anti-Static Precautions when working on a computer.
Your body carries Static electricity.
Static will fry out (Short circuit) the hardware components inside a computer.
You may not even see it, or feel it.
Computer on a table, computer unplugged from power, computer case open.
TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
The Locks, or 'Ears' as I like to call them, on the outside of the Ram Memory slots, swing to the outside.
The top of the Lock moves to the outside of the ram memory slot.
The lock pivots much like the action of a see-saw on a playground.
There is a Lock on each end of the Ram Memory slot.
Down in the bottom of the Lock is a small slot.
This is where the bottom outside corner of the ram memory module sits in.
There is a Locating Notch in the bottom of the Ram Memory module. It may look to be centered upon a casual observation. It is NOT.
There is a Locating Lug in the bottom of the ram memory slot. The Locating Notch must line up with the Locating Lug.
There is a Notch on each end of the ram memory module.
There is a protrusion, or "Bump', on the Lock that matches the Notch.
When the ram memory module is inserted correctly, there are usually two satisfying clicks, as each "bump' clicks into the Notch.
Have any further questions please state in a Comment.
[The tower shutting completely off does concern me. Clean the ram memory module contact pins. Clean inside of the computer with a can of air. Try to start the computer again.
You may have a failing Power Supply ]
Posted on Nov 10, 2010
Monitor immediately goes to sleep. Tower shuts down from unplugging it.
have you tryed starting up in safe mode to see if you can get into your windows?
Apr 09, 2015 | HP Pavilion Media Center TV m8400f...
Why does my tower beep one time during shut down?
If it does not detect an optional sound card or the integrated sound in the motherboard, it will beep rather than play the "Windows shut down" music. This is a normal operation and nothing to fret.
Sep 19, 2014 | Computers & Internet
Lg ibm multinet i tower allows power to the motherboard but wont start up, what should i do?
remove the power cord, remove the bios battery, short the two contact together in the battery holder for a few seconds, replace the battery and power cord and try again.
if that doesn't work, start removing items/plugs (not the big 20/24 pin one) from the motherboard until you get beeping noises.
if still nothing then put everything back and try a different power supply.
if that doesn't work, your motherboard is probably dead.
Apr 18, 2014 | Computers & Internet
Nx5000: Won't power up. symptoms:battery does not start(believed to be dead). Mains power,starts up and shuts down on a continuous 3-5 second cycle, from the time you switch mains on at wall. The...
Hi whisky_zulu,
I see that you have basically done everything possible on the machine still to no avail.
Basing from what you've done still the issue is the same it shows that the motherboard on the machine needs to be replaced.
no beep codes as you mentioned indicates that the motherboard does not respond at all there maybe power but you also mentioned that it also shuts down once turned on for a couple of seconds.
replacing the systems motherboard will be the only solution to this issue.
I hope that this makes it clear regarding your query.
Have a nice day,
mvincentc
May 07, 2011 | HP Compaq nx5000 Notebook
K8N mortheboard no signal screen
HI,
In this new tower you are swttching to, does it have it's own power supply? And if so, what are the amps, and what are the amps on your old power supply? I have the K8N, and it needs at least 450W to run decent. Let me know?
Mark
Jan 03, 2010 | ASUS K8N-DL Motherboard
My Hp a1630n does not start up. It does not boot,no beep, screen displays 'no signal'
If it is getting no power at all to the tower, your power supply is probably dead. If you are getting lights but no beeping then it may be a matter of resetting your motherboard. This would entail opening up the computer removing the power cord and removing (carefully) the small watch battery on the motherboard. After waiting about 30 minutes, put battery back in and try to power up. If it still dosen't boot up then it's time to start removing parts and keep trying to boot up until you have narrowed down what the problem is. If all is removed and still nothing. Your motherboard is probably bad. Good Luck.
Oct 25, 2009 | HP Pavilion a1630n PC Desktop
Tower shuts off after it beeps on start up
It COULD be an issue with the video card or the memory. Try to remove and hook it up again. But make sure it will not loose.
Jul 20, 2009 | E-Machines eMachines Desktop PC
Compaq Presario CQ50 Labtop, makes awful constant beeps
If you shut it down when WinFlash was running, then bad news - BIOS corrupted. This means faulty motherboard. Solution - replace motherboard.
Mar 11, 2009 | Acer TravelMate 2480 Notebook
Computer tower started beeping
If you added more memory this may make your tower beep.
If so I WOULD REMOVE THE ADDED MEMORY AND THEN RESTART
Jan 12, 2009 | HP Pavilion a305w (DM181AR) PC Desktop
Computers & Internet Logo
96 people viewed this question
Top Packard Bell Computers & Internet Experts
carey w mason
carey w mason
Steve Sweetleaf
Steve Sweetleaf
Are you a Packard Bell Computer and Internet Expert? Answer questions, earn points and help others
