Question about Samsung MD800SC Microwave Oven
None of the push buttons work when i shut door light stays on can't reset anything
  • tjs32 Nov 10, 2010
    Been unplugged for over an hour...plugged it back up and nothing
    Genius:
  • 1,112 Answers
Try unplugging from the AC outlet for at least two mins, then try the unit again. If problem still exists after doing a cold restart then you may have a control board failure.
Posted on Nov 10, 2010
  • Lavell Turner
    Lavell Turner Nov 10, 2010
    Then it is possible that the S-CON board is faulty this is the computer board that controls all functions of the unit.
    thank you
    sounds too expensive for age of unit.
    I wish they still made this design
    round but small
Sharp Carousel Microwave I heated some food. It worked fine, and shut off when it was done. I took out the food. When I closed the door the light stayed on. Light will not shut off. I tried...
Sometimes the switch in the door latch sticks. Mine did that and I ust closed the door with just a slight more force and everything started working fine.
Mar 03, 2015 | Sharp Microwave Ovens
Micro has a message F3 and and none of the controls work when i push the buttons
You have one of 2 problems, an open Thermocouple or a bad control panel DISCHARGE high voltage components first with no power applied prior to touching anything in the unit. Failure to discharge High Voltage Components can result in death
Aug 13, 2012 | GE Spacemaker JVM1640SJ Microwave Oven
Why does the light / safety switch stay on when the door latches shut ?
Most likely there is a part missing from the door latch mechanism that you need. This probably broke off when the handle failed. It would be a tab or wedge shaped piece of plastic that strikes the door switch and pushes the switch closed when the door is completely shut. You will need to find that piece and glue it back on or get a new handle assembly from Samsung.
Aug 01, 2012 | Samsung Microwave Ovens
Our LG microwave (LMA 1560SW?LMA1560SB) has a door that won't open. The open button will push in, but not release the door - the plastic button cover pops back out, but just the cover - not the whole...
Mine did this too. Also, at times when I would shut the door, the whole keypad would go dark and the clock would have to be reset. There were also times when I would push Start and it would do nothing. I'd have to unplug it so it would reset itself.
I used a screwdriver and forced the door open. Mine is about 2 years old and it's now dead. Biggest piece of junk I've purchased in years. Really ticked me off, no more LG products for me. I had a Toshiba that lasted me 22 years and the only thing that went bad on it was the light stopped working and the fan cover fell off.
Mar 20, 2011 | LG LRM1230W Microwave Oven
Hi I have a new Kenmore microwave model 721.8503 - it is a month old and wont turn on.. I close the door and the light stays on and it wont work..the door is completely shut
It sounds like the light switch isn't being deactivated which is preventing the microwave from operating (a failsafe).
Look to see that the buttons inside the microwave (where the latches are inserted when you close the door) are actually being pressed.
They may be out of place, obstructed, or your latches on the door may be damaged.
If you don't see anything wrong, try pressing the buttons yourself (with a pen bottom) to see if the light goes off.
Dec 18, 2010 | Kenmore Microwave Ovens
THE DOOR DOES NOT OPEN
Take a look at the button you push to open the door.
You will need to remove the panel the door button is on and get to the back side.
This is very easy to do after you remove the cabinet.
The button you push to open the door is held in place with four tabs. If one of them tabs break it jams the button.
Feb 18, 2009 | Neff H7871 Convection/Microwave Oven
Wont work...
check control circuit and door switches,
Oct 27, 2007 | Emerson Black Microwave Oven
GE Profile Advantium Wall Oven 240 volts 950 Watts
How long does it run before it fails? Does it look like the display is getting scrambled characters? I'm leaning toward a bad magnetron, but it may be more or less than that. If you can give more details and especially the actual full model number (as opposed to the model name Advantium 120) that would help. Thanks!
Oct 02, 2007 | GE Advantium 120 Convection/Microwave Oven
Samsung MD800SC Microwave Oven Logo
166 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Henry  Thomas
Henry Thomas
Devabhakthuni...
Devabhakthuni...
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
