Question about Watches
Al cambiar la hora cambie tambien el dia correspondiente y en este momento marca el dia 16 que puedo hacer
  • 2 more comments
  • rp_martinez2 Nov 10, 2010
    I change the hour and incidentally change the date now is posted 16 how I change to 10
    Thanks
    Citizen Eco-Drive Perpetual Calendar
    Thanks a lot for the data.
    Thanks a lot for the Data
  • Watches Master
  • 6,993 Answers
please can you rephrase this question in English?
I look forward to your reply.
Bye for now.
Posted on Nov 10, 2010
  • Walesarumi
    Walesarumi Nov 10, 2010
    Hell again,
    Please what's the name and model of the watch?
    So that I can give you the correct procedure.
  • Walesarumi
    Setting the Time
    1. When the crown is pulled out to the second click (time setting position), the
    second hand rapicly advances to the 0 seconds position and stops.
    2. Turn the crown and set the time.
    When the crown is turned to the right, the hour and minute hands move forward
    (clockwise rotation).
    1. When turned to the left, the hour and minute hands move backward by one
    minute (counter-clockwise rotation).
    • When the crown is turned continuously, the hands advance rapidly. Turn the
    crown to either the left or right to stop the hands from advancing
    rapidly.
    NOTE 1: When correction in the forward direction, the date changes when the
    hour and minutes hands indicate 12:00 AM. However, when the date is changed
    7when the hands are in the "rapid advance" mode, the hour and minute hands
    "pause" at the 12:00 am and then resume rapid advancement.
    NOTE 2: When correcting in the backward direction, the date does not change
    even if the hour and minute hands pass 12:00 AM
    3. Return the crown to the normal position in synchronization with a telephone
    time signal or other time service.
    Good luck.
Como cambiar fecha en casio g shock gw3000b
Hola,
Aqui puede encontrar la ficha completa del reloj:
http://www.tictacarea.com/es/relojes-casio/4557-reloj-casio-g-shock-gw-3000b-1aer.html
En este enlace puede descargar el manual :
http://www.tictacarea.com/es/index.php?controller=attachment&id_attachment=5
Si tiene cualquier duda puede consultarnos,
Distribuidores oficiales de Relojes Casio
TictacArea.com
Jun 08, 2014 | Casio G-Shock GW300CA-1V Wrist Watch
Eve mon crois watch 9441-FS instruktionbook
Watch controls (eve mon crois) TL= top left button TR= top right button BL= bottom left button BR= bottom right button TL= toggle light TR= view date BR= view alarm time BL= toggle options 1 press --> stopwatch 2 press --> change alarm time 3 press --> change digital time 4 press --> return to regular view (When on option) Stopwatch: TR= stop/start stopwatch BR= reset stopwatch time BL= next option Change alarm time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Change digital time: TR= +1 to selected (flashing) unit BR= change selected (flashing) unit BL= next option Normal view: (controls shown at top) In normal view when: TR is held down --> BR= toggle alarm on/off TL is held down --> BL= toggle through days BR is held down --> TR= toggle alarm on/off (for accurate digital time go to the option of change digital time and set it to the next minute from when you are make sure that the the counting seconds are flashing. When the next minute comes press TR this will reset the seconds to '00' without changing the minute and you will now be accurate to the clock you used by less than a second) I got this info through a long time of just experimenting with the buttons, still working on finding a way of changing the date but for now this should be enough to get you by with the watch. Hope this helps somebody :)
Jan 30, 2014 | Watches
Como ajustar a hora do timex T5K618
Ir alla a el internet y escrivez " como adjustar el hora de TIMEX T5K618".....en el caja de GOOGLE........
Sep 19, 2012 | Timex Mens Ironman T5K618 Blue Resin...
How to set up the chronograph needle
acabo de adquirir un reloj armani AR0431 segui las instrucciones ajuste fecha y hora, pero no trabaja..que pasa a caso no bienen de fabrica con la bateria instalada? o cual podria ser el problema?
Sep 11, 2012 | Giorgio Armani Emporio Armani AR0584 AA...
How to change a timex wr50m from military time to regular time
in the setting after you have set the date, you have to choose whether 12 or 24. choose 12.
Jul 14, 2011 | Watches
Hi i have an aviator watch avw7770G59 and i can't change the date ?? please help me by which button should i press
disculpe queria saber a que precio tiene el reloj aviator reloj_ caballero clave a v w 7 7 7 o g 5 9 y keria aber si me podrian vender el puro cascaron la caja eske ya teno la caja y la tapa
Jul 01, 2011 | Bulova Watch
Como porfabor puedo descargar o obtener el manual de instrursiones de mi relo Citizen eco driver e310 pero no se cual es el modelo aqui le dejo porfavor alguno de los datos que tiene en la tapa y en la...
HOLA YASSERDIDIE !!!!!!!
ENCONTRE UNA PAGINA DONDE VIENE UN MANUAL PARA EL RELOJ CITIZEN E310, ES UN ARCHIVO EN PDF Y VIENE EN ESPA?OL
EL LINK ES: http://sumanual.com/instrucciones-guia-manual/CITIZEN%20WATCH/E310-_S
ESPERO SEA EL MISMO MODELO QUE TU RELOJ Y QUE MI INFORMACION TE SIRVA PARA RESOLVER TU PROBLEMA. :)
Apr 29, 2011 | Citizen EcoDrive Calibre 3100 BT000007E...
Hola tengo un casio prg80T pro trek aparece en la pantalla la palabra OPEN solo da la hora y no permite la operacion de ningun boton la pila marca HI ya saque la pila se la coloque de nuevo y nada si me...
I know the secret behind CASIO's "OPEN" problem. This is not a joke. You'll be happy to get your watch working again. Because the procedure is too long to fit in here, send me an e-mail at s.duteau@videotron.ca and I'll send you the solution. This is no scam.
Aug 08, 2010 | Casio Triple Sensor Pathfinder PRG60-1AV...
Watches Logo
85 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
