Question about Dryers
Squeaks and has a burning smell - Dryers
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Nov 11, 2010
Squeak noise in washer smell rubber burning
sounds as tho drive mechanism or water pump generally separate
has frozen rotation causing belt to continue spinning as motor is good [ cause is tryn to work ] ,any how belt slipping on frozen puuley
causing burn smell , or just stretched or worn belt need to check internally. That is all I can suggest with info provided at this point.
Paul Douglas
Apr 17, 2014 | Kenmore Sears Washer and Dryer Stack...
Kenmore elite front load dryer squeaking and burning smell
you have a bearing in the drum support that has frozen and now the rubber wheel is burning up. The bearing needs to be replaced ASAP. You could damage the dryer if you continue to use it.
Feb 16, 2014 | Dryers
Loud noise burning smell
Most likely a belt problem or a worn out tensioner. You left off the year, make, model and engine so it's a guessing gamet. Read this post on how to track down the source of noise
http://ricksfreeautorepairadvice.com/diagnose-squeak-noise-creaks-and-squeals/
Diagnose squeaks creaks and squeals
Oct 05, 2017 | Cars & Trucks
During the spin cycle it has started to squeak? it sounds like rubber, maybe the seal or the fan belt?
If it squeaks or spins slower than when it was new, and/or you smell something like burning rubber, it is probably the belt. You can replace it yourself if you look up the make and model number on the internet. There are free sites that will walk you though the process. free.
Jun 19, 2011 | Neff Washing Machines
I have an ASKO T700 dryer. When I turn it on, it makes a high pitched squeak. If it's on for longer than a minute, I can smell a burning smell. Any suggestions?
you got a roller or belt idler not turning and burning the drum belt. you have to take the dryer apart and find the problem. if you need to lubricate a roller or idler use mineral oil or roller oil, do not use wd-40 or 3 in one.
Feb 12, 2011 | Asko T700 Electric Commercial Dryer
I got an 96 jetta and its has a burning smell and makes a sqeeking nosie
Could be a belt that is too loose.
Is the smell like burning rubber?
Is the squeak coming from the engine compartment?
Does the squeak go away when you rev the engine?
If yes to these questions it sounds like a loose belt. You would need to replace it.
Jan 04, 2010 | 1996 Volkswagen Jetta
New rear brake pads on drivers side smells like it is burning
If you smell burning - the caliper might not be opening properly.. Break might be sticking..
Jack it up.. The tire should spin freely..
If not - try bleedingthe lines real good..
PS - one should never use cheep pads..
Hope this helps !!
rate me good ;o)
Jul 13, 2009 | Hyundai Excel Cars & Trucks
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
Sep 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Dryers Logo
65 people viewed this question
Top Dryers Experts
