Question about Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive
My harddisk isnt opening and is asking me to" format the disk before use".when i cancel it says"G:is not accessible.Data error(cylic redundancy check) kindly help me retrieve my data.it is urgent and important.
    Brigadier General:
  • 10,406 Answers
When you try to write a block of data onto the disk-drive, a CRC (Cyclic Redundancy Check) value is calculated, based on the values of the bits of the data. Then, both your data and the CRC are written to the disk-drive. When you read that block of data, the CRC is also read from the disk, and the CRC is recalculated, based on the data that was read from the disk.
If the "new" CRC does not match the "old" CRC, then your block of data has been corrupted,
i.e,. the disk-drive is malfunctioning.
See: https://services.seagate.com/index.aspx?lng=en-US
for a professional "data recovery" service -- they will try to repair your disk-drive,
just long-enough to retrieve and copy all your files to a new disk-drive.
Posted on Nov 10, 2010
Recover data from wd 500 gb which is not working
You should use easy data recover software because this software support "raw" type of bad drive file system .
visit here
Apr 04, 2013 | Computers & Internet
Transcend external harddisk 250gb not accessing windows7 and asking for formatting and also immediate disconecting. How can i solve it? and how can i access it ?
Copy any data on the disk onto some other media using another computer (I know you have friends running XP and Vista) then just format the hard disk.= as requested by 7.
Sep 01, 2011 | Transcend 2.5 StoreJet Portable Shockproof...
Hi Sir, I have a problem with my SD Card when im going to read it on my pc. It ask for "format the disk before you use it". When I click cancel, it says"your volume not contain...
Does the SD card have pictures on it? What is the camera model used with this card? Have you tried connecting the camera itself to the PC in order to transfer the card's contents?
Dec 17, 2010 | Computers & Internet
320GB seagate freeagent, cant open some of the files.
If you have the ability and space then recover any files that you can
use the RUN option from the start menu
now type in "cmd" then ENTER
Now in the black box that appears type "chkdsk x: /f /r" and press ENTER
The "x" is the drive letter of the drive you wish to check
It may take some time but this will try fix any errors it comes acrosss and you may have to re-start to complete the task.
Now remove any more files that you can.
Use the RUN command again but this time type "compmgmt.msc"
Select Disk management
Make sure you freeagent is listed here.
Right click and select "Format"
Select NTFS as the file system
Do not tic any other boxes
Click OK
When it is done you can move the files back to this drive.
It is quite possible you hit the limits of the FAT32 file system which would have caused the types of error you saw.
Sep 17, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Hard disk no open
Hello, may b your other harddisk mite hav sum errors in it. Hope its detected in windows, bt not accesable.
Try booting with any linux live CD (google "puppy linux", its just 90MB approx) and connect the harddisk. Now access ur harddisk from linux. If u still cant access it, then u should format it.
if it works in linux, then backup all ur improtant data and format it wit NTFS. Ur prob shud b solved!!
Jun 22, 2009 | Video Game Consoles & Games
Error message: Failed- Replace Hard Disk 1 (Warrany ID error code 10008) what does this mean I have a compaq Presario A900
It means that Hard Disk 1, which is either the first or second harddisk in the laptop, has failed. First open the BIOS on your latop. Before windows startup there should be a Compaq logo on screen. There also is some text saying which key to press to access BIOS. In BIOS, try opening some menus and look for a menu that shows your disk drive. In the same menu should be your harddisk. If it is there, go to A. If not, go to B. A: The disk is not broken, it just made a write error that destroyed WIndows. Insert the disk with your operating system on it into the laptop, and reinstall it. Your data is gone, but the laptop will work. If reinstalling the OS gives errors, and is unable to complete, go to B. B: Your harddisk is broken. There is no way to fix it, and you will need a new one. Contact Compaq if your warranty is still valid, and if not, take it to the nearest computer shop and ask for a new harddisk. If you have any more questions or trouble just post back here. I hope this helps, Yannick
Jun 07, 2009 | Compaq Presario Notebook
Unable to copy files from cd
Please check with the another disk if the same issue is coming with different disks this is a ODD issue otherwise the disk is faulty as cyclic redundancy means the data could not red from the sector of the disk.
Thanks
Mar 01, 2009 | Computers & Internet
Computer doesnt detect chrashed harddisk so that to recover data
Your going to need a technician that specializes in hard drive data recovery.
Nov 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Transcend StoreJet 2.5 (TS120GSJ25T) 120 GB USB 2.0 Hard Drive Logo
714 people viewed this question
Top Transcend Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
pankaj rautela
pankaj rautela
Are you a Transcend Computer and Internet Expert? Answer questions, earn points and help others
