Question about LG GCC4522B CD-RW/DVD-ROM Combo Drive
Dvd rom my dvd-rom doesn't read anything and doesnt even appear on my computer
What is IDE connector? the problem above is the to my PC. appreciate your quick response
thanks,
marvin
Posted on Jul 22, 2008
    Scholar:
  • 168 Answers
Try to check the IDE connector and power supply of the DVD. also check the jumper setting of your DVD whether its slave or master. good luck!
Posted on Jun 17, 2008
Corrupted CD/DVDROM driver
Please explain your problem as corrupted cd/dvd rom driver doesn't stand for anything.
CD/DVD ROM driver can never corrupt only lens of cd/dvd driver becomes weak because of which it cann't read cd or dvd
Thank you for using fixya.
Aug 05, 2011 | Computers & Internet
My cd rom is not reading or even showen
try to clean it with cd cleaner. after that try your known good cd maybe its just the cd/dvd that has the problem. if still doesn't work try using cd first then dvd. because some combo drive fail to read cd but can read dvd or vice versa. also check for the cd or dvd speed, type and class.
Apr 17, 2011 | Acer (91.42R37.001) CD-RW/DVD-ROM (Combo)...
My pc doesnt detect my HL-DT-ST-DVD-RAM-GSA-H55N LG super multi dvd/cd-rom, i tried checking ide cables but still it doesnt read, i cant even see the dvd/cd-rom on device manager------there is no...
you might have to uninstall both the dvd/cd + its drivers then reinstall them actually unplug the cd/dvd from its power cable then restart your computer plug it back in your computer should activate found new hardware or
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
Oct 31, 2010 | LG GSA-H55N DVD-RAM Burner
I had this problem for about 5 months my lg dvd rom dint read dvds . i installed ffirmware and tried to update it but there was erreor and now dvd drive doesnt even work. no green blinking light. when i...
This is the inherent risk in updating firmware to optical drives.
Buy a new drive, power down the PC, install it and reboot the PC. If it is and IDE drive, or a SATA for that matter, before you buy a new drive make sure to disconnect and reconnect both ends of the cable prior to replacing it, just to be sure it wasn't an accidentally dislodged cable causing the problem.
Dec 28, 2009 | LG GCC4522B CD-RW/DVD-ROM Combo Drive
This drive reads a dvd but not cds. do you have
may be it's only a DVD ROM drive not a combo,
you will need a combo to read both DVD and CD
if it was reading CDs earlier then the CDs might have scratch in them, try with new CD.
did u make changes to the cables inside, if you did check if the cabels are connected properly to the drive
Dec 06, 2009 | Sony DDU1613 16X DVD-ROM Drive, Black...
DVDRW will not read CDs
1)right clik on my computer
go to
properties
device manager
clik on cdrom
uninstall it then re-install it
after reinstall try using the drive
2)update windows ,use custom and see if it finds an updated driver,if it does or doesnt update windows anyhow.
after you restart the computer try using the rom drive.
if that doesnt work;
go buy a cd/dvd rom cleaning disk at your local electronics store and use it.
if all this doesnt work;
buy a new rom drive
Dec 08, 2007 | Computers & Internet
The computer read the driver but it doesnt open
It sounds like Vista has recognized the device as a CD-ROM drive, but NOT as a DVD-ROM drive, and the disk you have inserted is a DVD.
Try getting an updated driver and possibly a new firmware from http://www.lge.com/support/software.jsp
If my advice was helpful please vote for me!
Nov 16, 2007 | LG GSA-2166D DVD RW Dual Layer Burner
Not working
Is the drive connected propperly ?
look at the jumper settings if its IDE
if it is connected propperly and still doesnt show up
( verify its showing up in My COMPUTER)
try it on anoter PC to see if it works.
Just cause its new doesnt mean it works
If it works and you did connect it propperly the let me know
IS IT READING ANYTHING ?
Is IT SHOWING UP IN YOUR DEVICE MANGER?
Click START, (right Click) my computer, select properties then device manager, it shoud show up in DVD/CD-ROM drives
if it doesnt then right click on anything and scan for hardware changes. If it doesnt show up then it isnt connected propperly.
Oct 13, 2007 | LG GSA-E10L (8801031212552) DVD±RW Dual...
Cd-rom dvd
CDROM CAN NOT READ CD'S Try cleaning the lens using a high grade CD Lens Cleaner.
Sep 21, 2007 | Computers & Internet
Reads all but DVD-Help PLEASE
When you say it won?t read are you trying to play commercial DVD movies or read DVD data disks? If you're trying to play movies then you need a couple of things the first being some type of player program. Real player works as does Windows media player but usually DVD drives come with a striped down version of PowerDVD or WinDVD. If you in fact have a player installed and when a DVD is inserted in your drive it doesn't play it may not be configured to automatically play DVDs. Try opening your player program and trying to manually play your DVD. Let us know if you have any success or if you need more assisted. If you do let us know what player program and operating system you have and any error messages that may appear.
Jan 01, 2007 | LG GCC 4320B CD-RW/DVD-ROM Burner
LG GCC4522B CD-RW/DVD-ROM Combo Drive Logo
43 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
