Question about Refrigerators
I need to order a new thermocoupler. Do you know where I can order one for an explorer GRO-10 model?
  • sandy318 Nov 11, 2010
    The brand is Explorer. It is a propane refriderator and the model number is GRO-10.
  • sandy318 Nov 12, 2010
    Somewhat helpful
  • Refrigerators Master
  • 1,711 Answers
Can you write the brand name and exact model for confirmation since you case is under refrigerators and we want to be sure for what we are talking about.
Posted on Nov 10, 2010
  • espressonist
    espressonist Nov 11, 2010
    We could not find any parts online for the specific model of your Gas refrigerator. However thermocouples are mainly similar and the main difference is the length. So we have here below a link with a list of the thermocouples and you can compare with one you have mainly the length and you can match it with one of the list in the link.
    You can contact them also directly by phone or email or even online chat and they can be more than happy to help you find the one you need.
Is B&B Super gro toxic because on a YouTube video they make lipstick out of crayons and one of their ingredients is coconut oil and super gro has that. Is it toxic?
I don't know if it is but here you can make your own non-toxic lipstick:
DIY nontoxic Lipstick from Crayola Crayons viral video ' > article > diy-nonto...
Jul 7, 2014 - Crayola crayons are like the Legos of crayons there are millions of ... DIY: Make lipstick out ofCRAYONS! ... the base to make a million different things and they are not toxic. ... ...Ingredients, coconut oil, crayons.
Oct 13, 2013 | Bb Super Gro - Regular 6oz
The liquafeed did not dispense much during about 10 minutes of spraying, (Only about 1/4"of Liquafeed was dispensed.
I'm sorry to hear about the problems you are having with your LiquaFeed Sprayer. Your water pressure needs to be at least 45 PSI. If your garden hose is longer than 50 ft, this can lessen the water pressure. If there is any foreign matter or crystalization on the bottle or the sprayer where the bottle inserts, this will need to be soaked in warm water, as it may be clogging the sprayer. With the bottle of LiquaFeed apart from the sprayer, squeeze the bottle to see if any product comes out. If none of these troubleshooting steps help, please call us at 877-465-5160, and we will be happy to assist you further.
Hilary @Miracle-Gro
Sep 19, 2011 | Scotts Miracle Gro Liquafeed Sprayer 6...
I changed the thermocoupler but problem remains the same: pilot goes out after about 10-15 minutes. I have Williams model 250912. Please help! How do I test if new thermocoupler is also bad, beside...
Remove the thermocouple and take a pencil eraser to the hole. Clean the corrosion out the hole. Reconnect the thermocouple tight. The tip of the flame must hit the tip of the new thermocouple.
If the flame is hitting the middle of the thermocouple that is called wash through (no good) The bimetal tip of the thermocouple is made of nickel and copper layered. When heated it produces millivolts. This holds the electromagnet in and that is your safety feature. Thank you Ralph Nader.
Jan 30, 2011 | Williams 2509612 Ceramic Mid-Size Heater
My Williams heater Model # 435FXR, is not staying lit after I light the pilot. I changed the thermocouple (even tho I sensed it might not be that), and it still didn't work. I disconnected it again and...
You may have changed the thermocouple, but did you clean the pilot assembly? Dust & dirt can get pulled in and restrict the gas/air mixture. The "blue flame" needs to impinge on the thermocouple in order for it to stay lit. Or, couId there be a possible "crack" in the heat exchanger ?
Mar 31, 2017 | Williams Heating & Cooling
I have been told that I need to buy a new gas fire because the thermocouple is not working and needs replacing.Unfortunately the fire is approx 10-12 years old and no longer made hence the heating engineer...
I think before I went to the expence of buying a new fire place I would remove old thermocouple and take it to a heating equipment supply house and see if they can find a replacement. Most equipment manufactures don't make their own controls, such as thermocouples,gas valves ,sensors and other equipment. Many chain stores such as true value have good knowedgable people and if they don't have what you need they may know someone that does. I hope this helps you. thanks
Nov 09, 2010 | Heating & Cooling
I have a desa fireplace model CGCFTP 26K btu, THE PILOT WILL NOT STAY LIT, I believe that it is the thermocouple, would you confirm or deny
Many times this problem is because the thermocouple has developed a bad seating connection between the thermocouple fixing nut and the Thermo-Electric valve located inside of your actual control valve assembly.
Meaning the connection between the end of the thermocouple wire just above the thermocouple fixing nut and the seat which is inside the Thermo-Electric valve have a bad connection that does now allows current to pass through the connection and into the Thermo-Electric valve.
When you have a good connection here it allows the control valve to stay open and allows gas to pass through the control valve into both the pilot and the main burner, but if this connection is bad then each time you release the button the pilot light will goes out.
Now to try and resolve this service problem with having to purchase new and sometimes expensive parts.
Remove the thermocouple wire from the gas control valve Thermo-Electric unit by turning fitting counter clockwise with a 5/16 wrench
Once the thermocouple fitting has been loosened and the thermocouple has been removed inspect the thermocouple Power Unit Connector Contact (PUCC).
Although the PUCC may appear clean may times the PUCC has developed a thin layer of corrosion that prevents the thermocouple from sending the needed current to the Thermo-Electric unit resulting in a pilot flame that may only remain burning strong as long as the pilot button is being pushed by the operator.
After removing the thermocouple PUCC from the valve you will need to clean both the power unit connector contact and the Thermo-Electric valve seat contact.
The connecting will require that a small amount of new "Clean Metal" be exposed providing a new fresh metal seat for the PUCC and the Thermo-Electric valve.
With a safety blade or a metal pick expose some new metal on both the PUCC and then up inside the Thermal-Electric valve seat scraping just a small amount of old surface from each item.
Now reassemble the thermocouple wire back into your gas control valve and tighten the nut firmly to achieve a good solid seating connection.
This new fresh metal seat should allow the millivolt current generated from the thermocouple to energize the Thermo-Electric valve and allow the gas control valve to remain in the open position.
If this does not work you may need to order a ned Pilot/ODS assembly.
You can find that at or
Thank you:
Nov 05, 2010 | Desa International CGCFTP Compact Heater
Pilot assembly parts or thermocouples
Hardware store thermocouples don't work on patio heaters. The fittings are not the same thread and they are not set up for the anti tilt safety switch. You'll need to purchase the parts from Blue Rhino.
Jan 29, 2010 | Endless Summer 233000 Open Flame Patio...
Natural gas patio heater
Sep 27, 2008 | Heating & Cooling
Glo-Warm Wall Gas Wall-heater parts...
We had a problem keeping the pilot light to stay on, and this site recommended that it could possibly be the thermocoupler that was causing our problems also. We ordered the thermocouple, put it on,hooked it back up and it worked great! Thank you so much.
ordered thermocouple from
Nov 19, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
