Question about Dell Dimension 4600 PC Desktop
I am unable to open up programs now on my computer. It says its unable to fin win32.exe something like that...is there a way i can fix this? I can't even open up anything in my control panal to access accounts, etc. Thanks
  • esugalski Nov 10, 2010
    I did scan for virus and there werent any. It seems like the main program or driver is corrupt.
    Guru:
  • Dell Master
  • 2,178 Answers
Scan for virus.
Posted on Nov 10, 2010
  • Rommel Alilin
    Rommel Alilin Nov 10, 2010
    You didn't state that in your first comment. Yes, the hard drive is corrupted. You'll need to re-install the operating system from the set-up disk. After that, you'll need to re-install the drivers. Here is the link:http://support.dell.com/support/download...
UNABLE TO DOWNLOAD ITUNES TO MY unable to download itunes this is tghe messg I get: : C:\Documentsand Settings\DELL\Local Settings\Temporary Internet Files\Content.IE5\XMB6JTLP\iTUNES SETUP[1].EXE IS NOT...
It is required to clear the temporary folder before downloading the Software. For this click 'Start' button then select 'Run' (you can open 'Run' by press and hold Windows button on the keyboard and then pressing alphabet key 'R'). Type '%temp%' inside the Run window, and you will get a folder opened. Delete all the files in the folder and close it. Now try to download the Software, it will work.
All the best.
Sep 21, 2010 | Dell Computers & Internet
It says exe is not a valid win32 Application
This usually means you are trying to double click on something that will not work in whatever version of Windows you are using. It could be written for an older version of Windows, such as you're using Vista and the program was written for Win98. Or it could be something else, such as you're running a 32 bit version of XP and the exe file is for a 64 bit version. Either way, it isn't going to work.
Aug 11, 2010 | Computers & Internet
See the end of this message for details on invoking just-in-time (JIT) debugging instead of this dialog box. ************** Exception Text ************** System.ArgumentOutOfRangeException: Cannot anchor...
Not sure whether this is a Q.
To enable just in time (JIT) debugging, the config file for this application or machine (machine.config) must have the jitDebugging value set in the system.windows.forms section. The application must also be compiled with debugging enabled. For example: <configuration> <system.windows.forms jitDebugging="true" /> </configuration> When JIT debugging is enabled, any unhandled exception will be sent to the JIT debugger registered on the machine rather than being handled by this dialog.
In VS the way to enable/disable that is: 1-On the "TOOLS" menu, click Options. 2-In the Options dialog box, select the Debugging folder. 3-In the Debugging folder, select the Just-In-Time page. 4-In the Enable Just-In-Time debugging of these types of code box, select or clear the relevant program types: Managed, Native, or Script. To disable Just-In-Time debugging, once it has been enabled, you must be running with Administrator privileges. Enabling Just-In-Time debugging sets a registry key, and Administrator privileges are required to change that key. 5-Click OK.
It has to be done by the developer and its his responsible to guide the application error reporting to the system event handlers. If this is an issue which occurs in a certain app, have to check for the .net version (specially in vista). Many 1.0 and 1.1 based apps give the problem. To install dotnet fw 1.1 on Vista will give an error. Most of the time caused by DEP (Data Execution Prevention). But the thing is some software forces the installation of .net framework (older versions). How ever Vista is packed with .net 3.0 and 2.0. Even if you allowed to install will not be able to uninstall 2.0 (possible to remove 3.0 though).
How to solve the installation issue: This issue is resolved in Microsoft .NET Framework 1.1 SP1, however you will need to use the following procedure to install both the .NET Framework and the Service Pack at the same time: Download Microsoft .NET Framework 1.1 Redistributable Package and Microsoft .NET Framework 1.1 Service Pack 1 using links below: Dotnet Framework 1.1 Redest Dotnet Framework 1.1 SP1
Save both installations in the same directory Ensure that the Microsoft .NET Framework 1.1 Redistributable Package is named dotnetfx.exe. If not, change its name to dotnetfx.exe. Ensure that Microsoft .NET Framework 1.1 Service Pack 1 is named dotnetfxsp1.exe. If not, change its name to dotnetfxsp1.exe. Open command prompt as Administrator, and change to the directory where the two installations are saved. Run the following commands using the order shown below dotnetfx.exe /c:"msiexec.exe /a netfx.msi TARGETDIR=C:dotnet" dotnetfxsp1.exe /Xp:C:dotnet etfxsp.msp msiexec.exe /a c:dotnet etfx.msi /p c:dotnet etfxsp.msp Install both Microsoft .Net Framework 1.1 and Service Pack 1 by running C:dotnet etfx.msi
The systems must be backed up before trying this specially the system state. How ever the keys can be repaid in a damage This thread will also be helpful http://blogs.msdn.com/b/astebner/archive/2007/03/26/how-to-repair-the-net-framework-2-0-and-3-0-on-windows-vista.aspx...
May 29, 2010 | Dell Studio XPS 16 Notebook
I am getting error message for win32 generic host data executor prevention
Here is my resolution to the error
SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR
IT DOES NOT INCLUDE
DISABLING WIA
OR
DISABLING DEP (which is a good security feature)
I have tried it on upto 3-4 computers with success and complete software functionality
Turn the All in One Off
Uninstall the whole of the HP software on the computer
Run a level 4 uninstall
Start --> Run -->X:\Util\CCC\Uninstall L1.bat
Start --> Run -->X:\Util\CCC\Uninstall L2.bat
Start --> Run -->X:\Util\CCC\Uninstall L3.bat
Start --> Run -->X:\Util\CCC\Uninstall L4.bat
Restart the computer
Check the computer on the restart
Check if you still get an SVCHOST.EXE GENERIC HOST PROCESS OR
DEP ERROR on restart
Start --> Run
Type in Msconfig
Click OK
Click Launch System Restore
Run System Restore
Create a Restore Point named Hp
Click Start --> Run
Type in Regedit
Click OK
Open Registry Editor
Scroll to the following Registry Key
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentV
ersion\Explorer\
RemoteComputer\NameSpace\2227A280-3AEA-1069-A2DE-08002B30309D
Right click on this Key Click Export
On the Export Registry Window which comes up
Type Hpprinter as the filename and save it on the desktop
Get back to the same Registry Key
Right Click the Key and Click Delete to remove the key
THERE SHOULD BE NO DEP ERRORS THIS TIME
(IF you have any issues after deleting the above key <possibility is remote> restore the computer back to the Hp restore point)
Reinstall the Hp printer Wirelessly or on a wired network now the usual way
Once the software installation finishes
Verify functionality
NOW
Right-Click My Computer, then click Properties.
On the Advanced tab, under Performance, click Settings.
On the Data Execution Prevention tab
Click Turn on DEP for all programs and services except those I select to select the OptOut policy, and then click Add to add the following programs
Create an exception in the DEP for the following programs by browsing to the correct location. The following list outlines the locations:
Hpcmpmgr.exe (x:\Program Files\HP\Hpcoretech\hpcmpmgr.exe)
HPwuSchd2.exe (x:\Program Files\HP\HP Software Update\hpwuSchd2.exe)
HP Digital Imaging Monitor (hpqtra08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqtra08.exe)
HP Image Zone Fast Start (hpqthb08.exe) (x:\Program Files\HP\Digital Imaging\bin\hpqthb08.exe)
Generic Host Process for Win32(svchost.exe)
(c:\windows\system32\svchost.exe)
Add all these files one by one by browsing to the locations
Click Apply and OK
Let the computer restart if prompted
Its also at times needed to disable
from the Startup of the computer in Msconfig
Hpcmpmgr.exe
HPwuSchd2.exe
The reason is the above mentioned exceptions to the Data Execution Prevention are loaded after the Startup loads and the DEP may try to shut them down at the startup itself and generate the errors
Unchecking the above files does not mean losing any functionality on the All in One all the features should work properly
Jan 21, 2010 | Dell Inspiron 6000 Notebook
I have a acer lap top im unable to watch films i have sound but no picture.its on avi format
The problem is due to missing codec.Anyway,you can download VLC Player, below is the download link
http://www.videolan.org/mirror-geo.php?file=vlc/1.0.3/win32/vlc-1.0.3-win32.exe
Or else you can install "Windows essentials codec" which will allow you to play any file in Windows Media Player  and others too.Below is the download link
http://www.mediacodec.org/WECPSetup.exe
Now enjoy your Movies.
Jan 05, 2010 | Acer Aspire 5100 Notebook
This program cannot be run under win32 mode.
To correct and solve this error, follow this steps:
1. Run Task Manager (Ctrl-Alt-Del or right click on Taskbar)
2. Stop wscript.exe process if available by highlighting the process name and clicking End Process.
3. Then terminate explorer.exe process.
4. In Task Manager, click on File -> New Task (Run…).
5. Type “cmd” (without quotes) into the Open text box and click OK.
6. Type the following command one by one followed by hitting Enter key:
del c:\autorun.* /f /s /q /a
del d:\autorun.* /f /s /q /a
del e:\autorun.* /f /s /q /a
c, d, e each represents drive letters on Windows system. If there are more drives or partitions available, continue to command by altering to other drive letter. Note that you must also clean the autorun files from USB flash drive or portable hard disk as the external drive may also be infected.
7. In Task Manager, click on File -> New Task (Run…).
8. Type “regedit” (without quotes) into the Open text box and click OK.
9. Navigate to the following registry key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
10. Check if the value name and value data for the key is correct (the value data of userint.exe include the path which may be different than C drive, which is also valid, note also the comma which is also needed):
“Userinit”=”C:\WINDOWS\system32\userinit.exe,”
If the value is incorrent, modify it to the valid value data.
Sep 01, 2008 | Microsoft Windows XP Professional for PC
Funny UST Scandal
hi my friend got that last week to... ehat you need to do is download kaspersky. after running kaspersky. that will be gone. you can download kaspersky @ majorgeeks.com Here are some examples of autorun viruses which rely on the autorun function of Windows to infect PC’s and flash drives. Funny UST Scandal.avi.exe Autorun.vbs win32.autorun.k copy.exe imgkulot taga lipa are autorun.vbs recycler FS6519.dll.vbs strawberry from baguio W32/Perlovga (copy.exe | host.exe) VBS_RESULOWS.A Bha.dll.vbs w32automa worm (Autorun.vbs) Trojan.Win32.VB.atg | Win32/Dzan | Worm_vb.bnr (tel.xls.exe | mmc.exe) W32/RJump.worm (RavMonE) Worm.Win32.Delf.bf | W32.Fujacks (spoclsv.exe) W32.Fujacks.BH (****.vbs) WORM_AGENT.PGV (soundmix.exe) W32/Hakaglan.worm (RVHost.exe) Trojan.Win32.VB.ayo [AVP] (Macromedia_Setup.exe) Trojan.VBS.DeltreeY.b#1 (Destrukto!!! | destrukto.vbs) if you want to manually delete it... Solution is here: 1. Start Notepad [Start Menu-All Programs-Accessories-Notepad] or right-click any empty space in your desktop then select New-Text Document 2. Copy the following text. (note: Everything in between the square brackets should be in one line) REGEDIT4 [HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindows NTCurrentVersionIniFileMappingAutorun.inf] @="@SYS:DoesNotExist" 3. Save the file with a name (anything) like DisableAutoRun.reg (The extension .reg is the important part) 4. Double Click your newly created registry file. Choose yes or continue to the warning that will appear. hope this helps
Jan 24, 2008 | Computers & Internet
Dell Dimension 4600 PC Desktop Logo
Alun Cox
