Question about Canon i850 InkJet Photo Printer
Canon i850, service error 6800
Hi
Had a problem with using a new black ink cartridge, didn't work, and eventually I got the 6800 error, can you please advise how to fix it.
thanks
Steve
  • 3 more comments
  • Steven Schmi Jun 18, 2008
    Tried as you suggested, but no luck. The light has changed to green, however the print head has not moved, and I still get the 6800 error, do you have any other ideas.
    thanks
    I have followed steps 1-4 ok, however at step 5 the printhead doesn't move, any ideas ?
    thanks
    Steve
    Yep, followed instructions to the letter, have tried a few times. The printer doesn't make any noises at all.
  • Steven Schmi Jun 19, 2008
    I get a blink count of 9, which suggests a "EEPROM Error - SERVICE" according to your link above. When I googled "Canon i850 EEPROM" there were instructions as you suggested in an earlier note, which I followed to initialise the EEPROM. No luck however, the print head still will not move. Will try a few other options tonight, and may even take it apart on the weekend to see if anything else I can do, otherwise I think it's had it.
    thanks for the suggestions you have provided.
    Steve
  • desp50 Jun 23, 2008
    I have just encountered the same problem with the same printer.
    Coincidence isn't it... the timing I mean. Within days of each other.
    Maybe canon has a built-in timeout firmware.
    Anyways. I read the instructions recommended at this sight. I too couldn't get the print head to move. Leading to the ink cleaning felt area, I noticed it was way above liquidy.
    Frankly my kids had been complaining a lot over the past several months that the colors weren't correct. On that I had stopped using my own refilling of cartridges, which seemed to hold the colors correctly longer. In the end I presumed that the printer head was either going or needed a thorough cleaning. On occasion, the black would block-up. I kept using the maintenance feature to clean all colors or black only. I believe this was a tell'tale sign that there was something deeper to the root cause.
    Getting back... I just removed today the print head/cartridges and tried to start up the printer after throughly cleaning the liquidy area.... behold everything moved properly. Replacing the head brought back the same error code and the head didn't move. remove again.. everything goes... etc.
    I then thought I may have damaged the connector pins (head). Several experiments led me to accept that all was ok there.
    That leads me to believe that in fact that resetting the eprom may indeed be the ultimate corrective action, now that the area is clean. I'm just about to check out if any firmware can be downloaded directly into the computer to make this fix... or perhaps a factory reset.
    Anyone have anymore suggestions?Paul
    Master:
  • 788 Answers
This error indicated that the internal printer counter for the waste ink sponge has reached its threshold. You should be able to reset this counter once without cleaning the sponge.
Do this:
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
now try press resume button 4 times..after that press the power button
This should clear your error and let you resume printing. If you start getting ink smudges on the paper you will have to disassemble the printer and clean the waste toner sponge.
Posted on Jun 17, 2008
  • 2 more comments
  • Dean Joly
    Dean Joly Jun 18, 2008
    Try pressing the resume button 3 times instead of 4 at the end. I'm getting conflicting answers on the net as to which is correct.
  • Dean Joly
    Are you keeping your finger on the power button from step 2 all the way to step 4?
    Does the printer make any noises when the printhead is supposed to be moving?
  • Dean Joly
    Actually from doing a little more research I found this: http://www.local.nu/HelpDesk/index.php?t...
    It indicates that the 6800 error is an EEPROM error, there are EEPROM ressetter tools available online. Just google "Canon i850 EEPROM" and download from one of the first links. I can't check out these pages as they are blocked here at work. Hopefully resetting your EEPROM with one of these programs will get you back in business. Otherwise, I'm afraid, there isn't much that can be done to save your printer.
  • ise piq Apr 01, 2011
    This is how I just fixed a Canon MP800 all in one with the flashing green & orange lights (a series of 9) & error code 6800. Left it UNplugged from the electrical outlet over night(You have to give it HOURS UNplugged or this will not work). Plugged it in the next day & turned it on. First window now showed a different error iu30 or some such, & showed a graphic of the ink cartridges with problems recognizing them. Held down the RESET button until the graphic showed the first cartridge as ok, (the picture will change), let go and held down the RESET button again for the next cartridge & so on until all 5 were ok. The screen then changed to a menu asking me what language I would like. Used the arrow keys around the OK button to select English. Then pressed OK for that language. The screen then changed again & said it would have to do a printhead alignment & to put paper in the printer. I put paper in & pressed the OK button again. It took about 5 minutes for the print head alignment. The paper with the alingment marks came out printed correctly. The next screen showed a normal screen which usually defaults to the Copy properties. Turned the printer off & on again a few times & everything was fine. Have no idea how long this will last or what caused the problem, but it is fixed for now. Related Problems & Solutions Filter Problems by Issues:
    Master:
  • 623 Answers
System error code 6800 means "The function attempted to use a name that is reserved for use by another transaction." This error code may also display as "ERROR_TRANSACTIONAL_CONFLICT" or as the value 0x1A90.
Posted on Aug 12, 2008
    Had a neighbors Canon MP800 all in one that got the 6800 error code plus text had all turned to Japanese. Unplugged it overnight, plugged it back in in the morning & it started up with a different error & showed problems recognizing the ink cartridges. Pressed the Reset Button & the picture showed the first cartridge as ok, pressed & held Reset again, & the picture showed the second cartridge as ok. Did this until all 5 were shown as ok, then the screen changed & showed a menu asking what language I wanted. Picked English. The screen then said to insert sheet of paper for printhead alignment. Put paper in & hit the OK button. Took about 5 minutes for that, then the printer was back to normal. Do not know yet how long this will last, but it fixed it for now.
Canon pixma mp150 printer shows error E 2 7 and alarm light is on also cartridge holder is stuck on right hand side and wont slide to the left
If you are able to produce a self test print, this is good since it illustrates that the cartridges are electrically stable...if you observe any 'E' or 'V' error states (i.e. "E xx" or "V162" for example), this may indicate there is possibly an internal electrical problem with one of the ink cartridges. Refer to your user guide if E/V error messages are displayed.
Inkjet411 support page on the PG-40 black / CLI-41 color ink cartridge series: : http://inkjet411.com/?page_id=2709
If, after following the suggested ink monitoring/level reset procedures, you still have an error condition which prohibits regular printing, then the ink cartridge probably has internal electrical damage (micro-electronics failure); such a failure is unrelated to the ink cartridge refilling process. Typically, when the cartridge fails the problem is 'masked' by the ink out/empty condition so it can be difficult to distinguish between the two. Many cartridges eventually do encounter problems or failures, especially after their original ink is gone and they are re-used, and this is often unrelated to the refill process (i.e. typically ~2 years from original manufacturing date). Refer to picture at bottom of this page: http://inkjet411.com/?page_id=1533
Canon 30/31/40/41 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2709
Canon 50/51 - Refilled Cartridge Activation Instructions: http://inkjet411.com/?page_id=2719
If, following a reset of the printer via the 'Stop/Resume' button, printing is permitted but the 'Ink Low' indicator continues to be lit then one of the inks cartridges may be suffering from marginal internal electrical performance - a potential failure of the cartridge may eventually occur which will prevent printing.
However, if your printer works routinely after inserting a brand new PGI-40 black ink cartridge in it, then this will confirm root cause of failure as being limited to the ink cartridge iteslf.
CAUTION: Be advised, the use of compatible/clone cartridges (i.e. sold thru the internet from overseas) are known to be problematic and may cause printer errors and/or permanent PRINTHEAD failures. We do NOT suggest refilling these types of ink cartridges.....refilling of Canon original/genuine ink cartridges is only suggested!
Canon 30/31 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=3khyqBHMPVc
Canon 40/41 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=KHT8uBvDFi8
Canon 50/51 Ink Refilling Services & Additional Cautions:http://www.youtube.com/watch?v=CwDy1H5UJqA
If you ever need to purchase a new ink cartridge(s) and are trying to cut costs, we suggest you try a remanufactured ink cartridge from http://www.inkplicity.com/ as their ink cartridges typically have the lowest cost in the USA, have a high reliability rating, come with a 1-year warranty and provide free shipping for all orders above $20 (these are remanufactured ink cartridges which have been pre-tested in an actual printer; purchases are only available to USA residents).
Please let us know if you have any questions regarding the technical information provided herein. For any additional questions please contact us directly: Inkjet411help@gmail.com
Feb 24, 2015 | Canon Pg-40 Black Ink Cartridge Pixma Mp...
My Canon i850 printer has stopped responding to a
The Canon i850 uses cartridges of type BCI-3. according to Canon, the color cartridges are compatible to:
BJC-3000 Series, BJC 6000, i450, i550, i850 Series, MultiPASS F30, F50, F60, F80, MP 700 and MP 730, S400, S450, S500, S520, S530D, S600, S630, S630 Network and S750.
The black one will work in a few more models.
Feb 07, 2010 | Canon i850 InkJet Photo Printer
The black color doesn't print.
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 05, 2010 | Canon i850 InkJet Photo Printer
Printer not working. The light flashes red six times.
Error Condition Indicator Beeps Error
Code Possible Solution Paper Feed / Delivery Orange 2 Remove any paper jammed Paper Jam Orange 3 Remove any paper jammed Ink Out Orange 4 Add Ink BJ Cartridge Misinstalled Orange 5 Re-install cartridge or replace it NO BJ Cartridge Orange 6 Re-install cartridge or replace it BJ Cartridge Error Orange 7 Re-install cartridge or replace it Waste Full warning Orange 8 Waste is almost full , needs service very soon Service Errors Blinks Beeps Error
Code
Possible Solution ROM Error 1 x Orange 10 6100 Try unplugging Printer RAM Error 2 x Orange 10 6300 Try unplugging Printer EEPROM 3 x Orange 10 6800 Try unplugging Printer Home Position 4 x Orange 10 5100 Temperature Sensor 5 x Orange 10 5400 Try unplugging Printer Waste Full 6 x Orange 10 5B00 Needs Service Cartridge OverHeat 7 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge OverHeat 8 x Orange 10 5200 Replace the BJ Cartridge(Printhead) Cartridge Displaced 9 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 10 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Cartridge Displaced 11 x Orange 10 5200 Replace the BJ Cartridge(Printhead) or reinstall Other Hardware error 12 x Orange 10 6500 Other Hardware error None None 5910 Needs Service Other Hardware error None None 5C00 Needs Service
Oct 01, 2009 | Canon S400 InkJet Printer
Canon i850 printing but pages are blank
I had the same problem after changing the black ink cartridge. I went to Control Panel of my computer, chose Printers, then Canon Inkjet. Chose Properties, then Maintenance, the Deep Cleaning. NOW my printer is working!!
Jun 16, 2009 | Canon i850 InkJet Photo Printer
7 yellow flashes not printing
hi welcome to fixya!
I believe there is no print head failure happening. I experience that one time, it only needs a new ink cartridge. Be sure to replace the right color!
have a nice day!
Apr 17, 2009 | Canon i850 InkJet Photo Printer
Replaced ink in canon i850 printer. Now it will not print
Hello.
First make sure you removed any protective tape or caps on the
ink cartridge.
If there is a contact surface on the cartridge make sure
there is no dirt or fingerprints on the contact surfaces.
You can download the user manual here.. CLICK HERE.
Have a nice day...
/Tech5508
Feb 13, 2009 | Canon i850 InkJet Photo Printer
Black doesn't print
THE CARTRIDGE MAYBE NO GOOD OUT OF THE BOX.
PRINTER NEED TO BE CLEANED
I DONT THINK ITS A DRIVER PROBLEM
BUT YOU WANT SOME OTHER OPTIONS TYPE IN THE ADDRESS BAR:
CANON 850i INKJET PHOTO PRINT WILL NOT PRINT BLACK INK
ROD
Jan 11, 2009 | Canon i850 InkJet Photo Printer
Canon i850 InkJet Photo Printer Logo
3,501 people viewed this question
old marine
old marine
