Question about Saws
Task force jigsaw model tfjs i cant remove the blade
  • 14 Answers
SOURCE: change blade
depending on how new the saw is there are only 2 ways to change out the blade. the older saws have a allen head screw that you must loosen or remove to take te blade off. this screw is located on the shaft at the top of the blade. shed some light on it and look for a slot above the guide.the screw will be either on the right side or the left side. Newer models will have a quick release on one side or the other,it will look like a little lever,you just flip it out with your thumb the old blade drops out then you install the new blade flip it back and your back in business.
Posted on Jan 18, 2009
  • 211 Answers
SOURCE: cant change a blade on 500watt pendulum jigsaw fmtc500js
Hi
There is a click mechanism to replace the blade at the top of the blade.
best regards savumihai71
Posted on Feb 12, 2009
shameerariff
  • 89 Answers
SOURCE: Replace the blade on jigsaw Bosch # 1587 AVS item # 0 061 587 683
YOu can download the user manual in the following links
http://mdm.boschwebservices.com/MDMCache/English%20[US]/t10/0000000/r00061v-1.pdf
https://www.boschtoolsservice.com/Order/IPL/IPLDetails.aspx?tn=0601587651&mn=1587AVS&init=1
The blade can be replaced by unscrewing the screw found on the shaft.
Posted on Jul 28, 2009
mrrichardlbo
  • 59 Answers
SOURCE: Borrowed a B&D jigsaw model 7571 want to know
arrowred.jpgExclusive Quick Clamp® tool free blade change provides easy, tool free blade changes
arrowred.jpgAccepts U and T shank blades for use with your preferred blade
Posted on Aug 15, 2009
SOURCE: task-force-4-amp-jig-saw
how do i change blade on task force jig saw. i am un able to pull it out after pressing button for it
Posted on Jul 01, 2010
How do I change the depth of the blade on a Task Force TFJS jigsaw #Z31603? It looks like it can't be done...
I believe that you are correct. Your blade would break if your cut was deeper than the soft part of the stroke.
Jul 10, 2017 | Blade Saws
I can not find my instructions for the Dewalt321 jigsaw so i therefore cannot replace a blade that fell out
Most Dewalt manuals are available here: https://servicenet.dewalt.com/Home . There are 40 Dewalt power tools with 321 in the model number. Several are jigsaws. There are two types for the DW321 (TO3PAK-2LE JIG SAW) jigsaw. Please look at the label on the jigsaw to ensure that you get the correct model and type. The direct link to the manual for the DW321 Type 1 is currently https://servicenet.dewalt.com/Products/GetDocument?docName=402086-01,DW321.pdf&productId=2841&productType=3001&documentId=24909&translatedFileName=http://documents.dewalt.com/documents/English/Instruction%20Manual/402086-01,DW321.pdf .
To change the regular blade on the DW321 type 1, unplug the power tool. To remove the blade, pull the knob on the top of the jigsaw up about 1/4". Rotate the knob counterclockwise until the clamp opens. Do not force the knob after it stops. Insert the blade making sure that the back edge of the blade fits into the support roller. Rotate the knob clockwise until it clicks and then push it down.
I hope this helps.
May 24, 2017 | Blade Saws
How to change blade on a Chicago jigsaw
Harbor Freight Chicago Electric Jig Saw - Review - YouTube
? 2:21
www.youtube.com/watch?v=lSh0M4WIJTk
Dec 13, 2013 - Uploaded by AdamDIY
Chicago Electric - Orbital Jigsaw 92772 They change the design over time but some of the key flaws tend to ...
jigsaw from hell - chicago (electric?) brand - DoItYourself.com ...
www.doityourself.com/.../445560-jigsaw-hell-chicago-electric-brand.ht...
Mar 9, 2011 - Most blades either have a hole in the shank or the shank is shaped like a .... A brand new one is only about $25 and no tools for blade changes.
Oct 22, 2015 | Saws
What models of jigsaw blades are suitable for cutting wood using a Black & Decker DN31-H1 Jigsaw?
Blade can be had at any hardware store or home improvement store. There are a lot of wood cutting blades available depending on the hardness of the wood and how thick the material is
Nov 06, 2014 | Saws
Argos jigsaw blade psj350
Hey a little off topic..but can someone please tell me which kind of blades fit this jigsaw as I have just aquired one but need to buy blades.
Thanks
Mar 06, 2012 | Saws
I have an old bosch 158IVS uh, what do you call a little reciprocating saw? jigsaw? anyways i can't for the life of me figure out how to change the blade. i've undone every screw. opened up the motor...
well the sawzaw will be drastically different from the jigsaw, but the jigsaw will have either a round twist lock that needs to be turned a little to remove the blade, or two screws that hold a flat plate that clamp the blade. and as for the sawzaw, it will be a twist lock, or a latch lock, the latch lock will look like a lever that needs lifted to remove the blade, and the twist lock is the same as the jigsaw.
Dec 30, 2010 | Saws
My original blade broke so i bought a new blade from wickes 10tpi now when i use it i saw on the line i have marked but on the other side of the 2x2 it is about quarter to hallf inch out how can i make...
There are good blades and there are cheap blades. Good blades are straighter but less tolerant of poor technique and so tend to break, cheap blades can and do bend far more. You can keep the blade straighter by not forcing the blade through the work and allowing it to cut at it's own rate and by experimenting with the speed settings on the jigsaw. It also helps if you pick the correct blade for the job: 10tpi is a bit too coarse for ripping a timber batten along the grain but fine for rough cutting chipboard. Also, it's difficult to keep the foot of the jigsaw absolutely level on 2x2 which adds to your problems.
Aug 15, 2010 | Bosch T-Shank High Speed Steel Jigsaw...
Problem guiding the direction of cut with a jigsaw.
check that surface plate is square with the blade.don't push too hard,or force the saw,let it cut at it's own speed,guide rather than force.a scroll saw or band saw is more accurate as you control the work piece instead of the tool.
Oct 11, 2009 | Festool Jig Saw Circle Cutter - 490118
Borrowed a B&D jigsaw model 7571 want to know how two use the other speed and how to put the blade in properly....does not seem to cut without great force....Cindy
Aug 15, 2009 | Black & Decker Saws
Cant change a blade on 500watt pendulum jigsaw fmtc500js
Hi
Jan 18, 2009 | Saws
Saws Logo
734 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
