Question about Soyo DYLT032D 32 in. LCD Television
Remote does not turn tv on at times. also having same problem with off-on switch problem is getting worse.
  • lrylpz Nov 10, 2010
    remote ok
  • lrylpz Nov 11, 2010
    YES
  • 10,594 Answers
We need to narrow down problem as is it tv or remote control is cause of problem.
Lets confirm remote first, take any digital camera and watch remote front through camera, press power button of remote, you will notice infra red light will blink on remote front while watching it through digital camera because camera can see infra red light but we don't.
Once remote got confirmed that power button is sending signal properly then it is tv that is cause of problem.
Let me know your findings to proceed further.
Thanks.
Posted on Nov 10, 2010
  • Shahid Electronics
    Shahid Electronics Nov 10, 2010
    Can you change channels or volume level in tv with remote or tv side buttons easily?
    Shahid Electronics Nov 11, 2010
    OK, it seems few electrolytic capacitors are leaky/ bad in power supply output section and causing problem when tv turns On because bad capacitor does not help regulator to provide smooth and stable voltage supply so this low voltage or fluctuated supply would be cause of problem.
    Please ask tv repairman to replace capacitors in output section of power supply board to solve tv problem.
    Thanks.
My Onkyo TX NR609 is not coming on and immediately shuts off and is progressively getting worse it is hooked to a harmony smart hub
Hi Liz, I am sorry about your issue. Please remove the HDMI cable from the receiver that is connected to the TV as a test. Check and see if the receiver stays on. If it does not the receiver would need to be serviced. Thank you, Onkyo USA
Oct 29, 2016 | Onkyo Audio Players & Recorders
Why does my t.V keep switching to dvd screen.
TVs turn on in the last screen they were turned off. Try switching screens using the remote control. If the dvd screen keeps coming back, try pressing or tapping on the manual key located on the side or bottom or back of the TV panel. Sometimes this key gets stuck up. If this does not work, try unplugging your home theater and turn on the TV. Most TVs automatically switch to DVD when they sense signal from HDMI cables.
Nov 26, 2014 | Televison & Video
My sony wega kv-36 tries to power on. the stand by light blinks 6 times every time I try to turn it on. After turning on and off like 50 times, I seem to get lucky and it actually powers on and woks...
The Power/High Voltage board is the main cause of this. Most of these boards must be sent to Sony to be refurbished because Sony no longer manufactures the board.
I hope this helps,
skyassoc
Dec 08, 2010 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Tv turns on with remote but only for few secs..after 7=10 trys, maybe for an hour, then shuts off of cable.
The Horizontal Timing is getting worse. This is chassis L04.1U AA. Have a tv tech install the horizontal timing kit...Part# 4835 310 57673......You will be glad you did!
Sep 22, 2009 | Philips 32PT6441/37 32" TV
WS-5551 only on/off button works, won't respond to remote at all
take off the speaker grill, you will see 2 wire plugs, turn the tv on, disconnect both plugs, if it now works with the remote then you need to replace all of the front switches, or leave them unplugged and use the remote, if this doesn't work, you have a bad dm board or signal module which could get very expensive.
Sep 15, 2009 | Mitsubishi WS-55511 55" Rear Projection...
My tv seems to be dead...
Ur power board ic converter is dead.
Need a new one.
Aug 18, 2009 | LG 42LC2D 42 in. LCD HDTV
Clicking noise when turning on the tv. Everything works but the clicking.
When you turn your tv off turn it off using the remote control then turn off the tvs switch itself... Try this for a few days hope it works for you.
Thanks.
Jun 22, 2008 | Akai PT5492S 54" Rear Projection...
HDTV 52 INCH RCA
It could be a failing tac switch or the micro. The only way to tell is signal trace the switch circuit with a 20mhz scope.. Need a shop for that if you don't have the equipment and it's not terribly expensive...
Footnote: either failure can and usually will get worse over time and may infect other function, vol,ch, power and so on... Find a reputable shop and take it in.. If you have any problem location one let me know..
Bill
Dec 11, 2007 | RCA P52926 52" Rear Projection Television
TV keeps turning itself on and off, onto standby
Right i had this same problem for ages! i cannot explain why but when i uplugged my DVD player (which was flashing its light at the same time as the tv for some reason) the TV has worked fine.
Aug 24, 2006 | Philips TV Tuner Video Capture PCI Card -...
Soyo DYLT032D 32 in. LCD Television Logo
43 people viewed this question
Top Soyo Televison & Video Experts
ted dux
Are you a Soyo Televison and Video Expert? Answer questions, earn points and help others
