Question about Dacor DMT2420 1200 Watts Microwave Oven
The panel touch controlls do not work - Dacor DMT2420 1200 Watts Microwave Oven
Buy a new one but dont buy samsung
Posted on Nov 26, 2010
Help! GE spacemaker 2.0
I had the same problem , it was finger touch control panel, when I cleaned with spray then it worked for some days . Finally to get ride of it , I changed control panel with a new one.
May 12, 2013 | Microwave Ovens
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
The sharp corousel microwave ( Model R-308 JW) was working . There was a small roach nest in the lighted digital display and the display was hardly to read . This was the only issue. After...
Look into the connector and see the point of contact which is visible of the metal contacts. Now the carbon tracks must be on the side of the metal contacts of the connector. In this case it is possible that while you pulled out the flexible stip cord there is damage on the strip , can be that the carbon tracks were damaged and so it does not contact. if so use a carbon track pen to line the tracks so as to contact.
Reversing the cord will not do any damage as there will not be any contact.
finally make sure that the PCB( printed circuit board) was washed with petrol and brushed properly and then DRIED before the unit was powered or else it can damage the processor.
Check the connection leads that were removed and make sure that it went to the correct postion.
Sometimes the touch pads refuse to work once it is disturbed as it might get damaged in the carbon tracks within.
Sep 21, 2011 | Microwave Ovens
I have chefmate microwave and suddenly stopped working. it is showing 2:50 code on the screen only...it was working fine and dont know what happened to it and touch pad is not working..how do i make it...
HELLO.
The code on the screen indicate electric panel fault resulting from the touchpad malfunction.
The touch pad on your microwave oven acts as the brain of the appliance. It not only contains the buttons that you use to enter cooking settings and times, but also controls the function of the entire microwave. If the touch pad malfunctions or breaks completely, the microwave will cease to function. In this instance, the broken touch pad must be removed and a new touch pad must be installed, to restore functionality to the microwave.
1 Unplug the microwave from the wall outlet.
2 Remove the two screws, located on the front or top of the grill at the top of the microwave.
3 Pull the grill off of the microwave.
4 Remove the mounting screw from the top of the control panel.
5 Lift the control panel up and out to loosen. Look behind the control panel to ensure there are no metal tabs securing the control panel in place. If there are metal tabs, gently rotate the control panel to free the tabs.
6 Transfer the wires from the old control panel to the new control panel one at a time to ensure that the wires are properly installed.
7 Install the new control panel into the microwave and secure using the mounting screw that was removed.
8 Replace the grill from the top of the microwave and secure it using the screws that were removed.
9 Plug the microwave back into the wall outlet.
Thanks.
Sep 12, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Amana rfs12sw2a....1200watt The soft touch buttons don't respond except for number 6....
Sounds like a bad control board. First just check and make sure all of your connectors are in tight. Part numbers for the control board is 53001806 you could have a bad touch panel. rare and not typical but can happen part number for that is 53002019. I would probably buy both of those parts plug in the new panel into the existing control board and see of everything works. if so replace the touch panel and send the control board back. If it still does not work then swap the control board and send the touch panel back. hope that helps
Mar 19, 2011 | Amana RFS12MPS Microwave Oven
I have a GE microwave and F3 has just come up on the display screen???
F3 Shorted key panel (touch pad).
1. Will occur if a shorted key panel is detected continuously over 60 seconds.
2. Replace key panel (touch pad).
What you can first try before replacing the keypad is first unplugging the microwave. Then you can get access to the panel by first removing the top grill and then unscrew the top of the control panel. There is a strip that looks like tape which attaches to the control panel which you need to wipe off and then blow dry. may not work the first time but be patient. also clean the bottom of the door and the latches to make sure the connection is clean. After that is should hopefully work without replacing the touch pad.
Let me know how this works out for you.
Benjamin
Apr 26, 2010 | GE Profile Spacemaker Over-the-Range...
Kenmore Microwave Oven, Model#66568680891
you should change the touch panel and or the control module.check to make sure the power supplied is correct and all connections to the board are all secure.
Feb 24, 2010 | Microwave Ovens
Touch screen not responsive. Can operate oven only by pressing one-minute button. Cannot set clock, change settings, etc.
try opening up the control panel,disconnect the connector ribbon coming from control panel and connected 2 control board by just pulling it out and cleaning end of connector ribbon and iserting it back.some times this works.if not then 4 sure touch panel needs to be replaced.
Aug 15, 2009 | Kenmore 63792 Microwave Oven
My microwave touchpad doesn't work
OK, i have located the actual part you will need. i found the part number. click the link below to be directed to the Auto-Touch Control panel you are seeking. you can order form this site as well if you choose.
Auto-Touch Control Panel
May 16, 2009 | Sharp Microwave Ovens
Control Panel Touch Screen Goes Blank
This is a problem with the control panel assembly, which we commonly repair for $32.50. Feel free to e-mail me at _ for more information or visit _ for full details.
Aug 01, 2006 | Sharp R-340 Microwave Oven
Dacor DMT2420 1200 Watts Microwave Oven Logo
41 people viewed this question
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
