Question about Briggs & Stratton Garden
Looking for a wiring diagram for Simplicity rider Model 5216. Tractor used to run good but wire rubbed through & shorted out something, repaired wiring, replaced the coil, have no spark to plugs
  • 297 Answers
Have you checked the 20 amp fuse behind the instument panel? It will be an inline fuse. It might be a glass fuse in your tractor. If you taped up the rub through, you should be good after you replace the fuse.
Hope this helps,
Nice tractor by the way.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/matt_8dbc24bf722649ac
Posted on Nov 11, 2010
Testimonial: "I did not realize that there was a fuse there, fuel tank covers all of dash inner, can barely see ignition switch. I will check out. Thanks"
Mice chewed wiring and board JT947 for Lil Rider tractor #80-KB6038 2016 production batch #115589. Where can I buy replacement wiring?
This is not likely to happen. If you have the booklet that came with it, look at the manufacturer. It is most likely made in China. The major sellers of that item are Kmart and Sears and we know that is not good.
Apr 03, 2018 | Toys
Where can I find a service/repair manual for Sears/Craftsman riding tractor model 917255735? Mainly looking for carb rebuild directions.
the motor used will be a makers model ( B&S , honda Tecumseh, Villers etc and manuals for the carby will be found in the repair manual for the engine used in the mower
Sep 11, 2016 | Garden
ECM fuse keeps blowing on my 2002 Tahoe
Explain that at a repair shop
That is not something you can work on
or we can tell you anything about
The vehicle has to be tested & wiring
diagrams & other info will be needed
before anything can be started
Jul 06, 2014 | Cars & Trucks
I am working on a Simplicity Landlord tractor with a 18hp Vangard engine. Will not start when both shut off wires on coils are plugged in. When I disconnect the wires the engine will start. I plug one in...
Sounds like one of the wires are shorted " going to ground " acting like a shut off switch.when connected...try disconnecting the old ones and bypassing them with new ones..see if that takes care of It..good luck.
Apr 19, 2014 | Briggs & Stratton Garden
Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Mar 17, 2010 | Garden
Garden Logo
771 people viewed this question
Top Briggs & Stratton Garden Experts
John Trevino
wadingriver
wadingriver
Jim Parker
Jim Parker
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
