Question about JC Whitney 200-watt Am/fm-mpx Radio Cassette/cd Player From
Code for radio cassette .for daewoo nubira 2000
Radio codes for 2000 Daewoo Nubira
Don't really know since Daewoo went out of business if it didn't you can go to one of their dealership, but since they went out of business years ago... you need to see if they still have a customer support and call them up and give them the radio S/N and Vin and they may be able to give you a radio code. Most of the time it's free of charge.
Jan 14, 2011 | 2002 Daewoo Nubira
What is the code for the radio in the 2000 daewoo nubira
Lots of daewoo's have the radio code stamped on a tag on the top of the radio. Pull the trim off around the radio and see if you can see it.
Nov 07, 2010 | 2000 Daewoo Nubira
I need code for 2000 daewoo nubira
Remove the radio. Daewoo printed the code on a sticker on the top of the radio on some models.
Oct 13, 2010 | 2000 Daewoo Nubira
Radio code
I have found on daewoo they stamped the code on a sticker on the top of the radio. If you pull off the radio trim you should be able to see the code.
Jul 19, 2010 | 2000 Daewoo Nubira
Bought a 2000 nubria daewoo and the seller did not give me the ra
You can obtain the code from daewoousa. Remove radio and get serial number from radio (white strip with black numbers on radio) Email this to daewoousa and they will email back your 4 digit code. To input code, disconnect the NEGATIVE battery cable, pause, then reconnect. Your radio face will now flash "code" Input the 4 digit code given to you. Radio will play after about 15 seconds.
Jun 11, 2010 | 2000 Daewoo Nubira
Changed battery and lost radio code 2000 daewoo nubira serial # 0042705721
Daewoo codes only available from the Main Dealer or a Radio Decoding Service
Apr 21, 2010 | 2000 Daewoo Nubira
Radio code
most codes have to be cleared by a computer. check with a mechanic or take it to a dealer to be cleared
May 20, 2009 | 2000 Daewoo Nubira
2000 daewoo nubira cdx radio code. manual stolen and cant afford to buy one at this time. i changed the battery and now code to radio is needed.
need a 8 figure radio chassis number ,you will need to remove the radio to find it ,then post it so i can generate a code for you
Apr 11, 2009 | 2000 Daewoo Nubira
Radio
yeah .. sure can .... foreign cars **** ....
Jun 11, 2008 | 2000 Daewoo Nubira
Daewoo Nubira 2002
try going on google and punching in something like daewoo radio codes otherwise look up daewoo dealers and call them
May 30, 2008 | 2002 Daewoo Nubira
Car Audio & Video Logo
119 people viewed this question
Top JC Whitney Car Audio & Video Experts
Jaime Hernandez
rigger094
xxxxxx xxx
Are you a JC Whitney Car Audio and Video Expert? Answer questions, earn points and help others
