Question about Visioneer RoadWarrior Pass-Through Scanner
Visioner roadwarrior 120- used 2 times now paper won't feed thru scanner, whats wrong? it makes noise as if it is being fed thru and even produces a blank image on my screen.
5 Suggested Answers
SOURCE: 8100 Visioner conflicts with Vista
Verified to work with Vista Home Premium x64 (should work for x32 as well):
1. Make sure your 8100 is unplugged.
2. Go to Visioneer's website and download drivers for the OneTouch 9420 scanner:
http://support.visioneer.com/products/home/9420/downloads_1.asp
3. Install the drivers. Nothing will work... yet, don't worry.
4. Now plug in your 8100. You'll get a message saying that Vista wants to find drivers. Select "Ask Me Later" or just cancel.
5. Next, open up Control Panel and then Device Manager. Find your 8100 in there (probably listed as "Unknown Device") and then right click on it and say "Update Driver Software". Now click "Browse My Computer For Driver Software" then "Let Me Pick From A List Of Device Drivers On My Computer".
6. Scroll down to "IMAGING DEVICES" then find Visioneer, then you should see the "Visioneer 9420" driver. Select it. You'll get a warning from Vista, but continue anyways. That's it... everything should work.
Posted on Mar 05, 2008
  • 32 Answers
SOURCE: Why does the scanner hesitate when feeding the paper through the scanner and gives a scanned double image at the top of the page?
Is there a gear grinding noise associated with this? If so, call your local dealer for service. If not:Clean all the rollers you can reach with a cloth dampened with alcohol. Check for any obstructions in the paper path like torn paper, heavy toner buildup on guide plates or the edges of the scanning glass, or any paper guides obviously loose or out of place.
Posted on Apr 07, 2009
mohanchennai
  • 490 Answers
SOURCE: Canon DR-2050C Scanner gets verticle line down image
:-) Please try and locate the scan module. All Scanners have glass to prevent dust entering the scan module. If dust 'sticks' to the glass and when scanned, it creates a 'line' in the output. Even slow desktop scanners are sealed for dust prevention.
S. Mohan
Posted on Oct 27, 2009
  • 78 Answers
SOURCE: My scanner scans black Does not scan document.
Does the scanning light come on? The light may be burned out. Also Try cleaning the scanning tip.
Posted on Jul 17, 2010
Documate error 8
Hello.
I am a Support Engineer with Xerox Scanners.
E8 is a Paper Jam error that could be caused by:
- paper crumpling during scan.
- paper is multi-feeding all at once instead of feeding separate.
- scanner continuously tries to feed after paper has fed through.
if the paper is crumpling during the scan, make sure the inside of the scanner is clear of any obstructions. use the paper guides in the ADF tray to keep the paper straight when feeding in.
if the paper is multifeeding while scanning, fan out the pages before inserting them into the scanner. if problem persists, try cleaning the rollers with rubbing alcohol and a lint free cloth.
if scanner tries to continually feed after the paper feeds through, the ADF tray will need to be reseated. open the scanner and remove the ADF tray at the top. line up the 4 keys at the bottom of the tray with the 4 corresponding key slots inside the scanner. push the tray back until it clicks into place.
We also have an extensive support site and knowledgebase at
http://www.xeroxscanners.com/en/en/support/
If you continue to experience trouble, please feel free to contact us by calling 800-648-0410.
Regards,
Xerox Scanners Support
Jan 28, 2013 | Xerox DocuMate 162 Pass-Through Scanner
Fujitsu fi 6130c sheetfed scanners make a clicking noise, then jam.
Hello Eddie,
The clicking noise could be due to abrasion of gears in the upper part of the scanner.Please check your scanner usage and a general service will resolve the issue with replacement of the gears, if required.You are recommended to contact your local Fujitsu authorised service station for repair. For more information, please visit www.fujitsu.com
Thanks,
ScanCare
Jun 15, 2012 | Fujitsu fi-6130 duplex scanner
Cannnot copy a double sided document to cardstock
This is normal. The cardstock is fed from the manual feed or bypass tray and when selected the duplex option goes away. Many manufacturers do this....meaning they do not allow duplexing from the bypass tray. For the same reason they do limit automatic duplexing to standard or near standard papers. Cardstock is specifically excluded from duplexing obviously due to it's thick nature and when duplexing the paper has to be turned over and go thru paper paths that are not suitable for thick paper. If you must make a 2 sided copy using cardstock you will have to run the sheet thru the machine 2 times, also known as manual duplex.
Hope this helps.
Apr 12, 2010 | Copystar - CS-3035 Printer
Paper feed not working properly
1. first check to see if there is any bits and pieces of paper in any place in the paper carriage -- look very carefully in front access and rear access
2. if this is not the problem, then disconnect printer from computer -- turn off printer, unplug power cord, unplug printer cable from printer
3. gain access to paper roller assembly, usually in rear
4. using lint free cloth, dampened with distilled water clean rollers -- read manual to determine direction of rotation (usually clockwise)
5. keep rotating rollers until all is wiped clean of paper dust
6. reassumble and try a test print as your printer manual directs
Apr 22, 2009 | Office Equipment & Supplies
Lexmarkx125 will scan larger pictures but smaller ones.
Here are some instructions from the Lexmark X63 which was similar to the X125.
The Lexmark X63 uses a sheet fed scanner, intended to scan 8 1/2 x11 inch paper.
  • To scan a document between 5 1/2 inches and 8 3/4 inches wide, center the document between the paper feed guides leading into the scanner and make sure the document is held straight,. Do not bend the document as it is fed into the scanner.
  • To scan photos or pictures that are 5 1/2 inches wide or smaller, you will need to use a flatbed scanner, or "mat" the image into a regular letter-size paper and scan the entire page. When the scan process is complete, crop out the picture using the AUTO CROP option in the Scan and Copy Control program or the photo-editing software.
Feb 27, 2009 | Lexmark Pro X125 All-In-One InkJet Printer
HP 2840 printer paper jam
does the paper feed at all(1/2 way) no feed,if not pick-up paper most likely will be feed motor if 1/4,1/2 or 3/4 fed will be sensor at falt or 2nd tray conectors dirty or making false contact.
Sep 08, 2008 | Office Equipment & Supplies
My printer, makes a grinding noise, when the paper is feeding through when printinig?
Look to make sure that there isn't a small bit of paper caught in the wheels that push the paper through. Over time, even a small bit in the corner can destroy your printer.
Mar 22, 2008 | Epson Stylus Photo R300 InkJet Printer
Making a noise
Maybe you just need to put some oil on your carriage shaft...With your finger tuch the carriage shaft and you will see if the shaft is dry and sticky...
Mar 02, 2008 | Lexmark X5150 All-In-One InkJet Printer
Can't Print on Card
I had the same problem with my 3 year old HP Officejet 5610. Feeding heavy paper or white card stock would result in a paper jam. The card stock would start to feed, but then stop half way. The pinch rollers seemed to spin without advancing the paper, even if the paper was fed one sheet at a time.
Solution: Clean the rubber pinch rollers with isopropyl rubbing alcohol. Partial disassembly/reassembly required.
To access the rollers, remove the scanner plate:
1. Disconnect power, USB, and phone cables.
2. Open up the scanner sheet feeder by tilting it left.
3. Unlatch the scanner scanner feeder so that it opens completely vertical. Latch is on front hinge only.
4. Remove the 4 corner hex screws on the scanner plate. Remove the 2 hex screws on the sheet feeder. (I used a small flat blade screw driver in the hex heads)
4. Lift the plate and sheet feeder away from printer box. Disconnect the 2 flat cable wires from the circuit board.
5. Scrub rubber pinch rollers with alcohol on a swab. Dry thoughly.
6. Reassemble. (NOTE: This is a good time to clean the underside of the glass plate and the scanner head)
Oct 18, 2007 | HP Officejet 5610 All-In-One InkJet...
Visioneer RoadWarrior Pass-Through Scanner Logo
199 people viewed this question
Top Visioneer Office Equipment & Supplies Experts
TomHighRidge
Mark Gough
Are you a Visioneer Office Equipment and Supply Expert? Answer questions, earn points and help others
