Question about Canon EOS 40D Digital Camera
How do I restore the menu icons at the top of the LCD screen
Ive only got 5 of my icons on the top of the screen when i press menu...
red.1
blue1
blue 2
yellow.1
yellow 2
How do i restore the menu so that i get the rest of them on the LCD display at the top?
  • 2,039 Answers
Set the Mode Dial to something other than Auto or one of the Basic Zones. If you select P, Tv, Av, etc., you should be able to see all the menu options.
Posted on Jun 17, 2008
Video downloadhelper 5 button is not showing on my browser for mozilla firefox after downloading
Open Firefox, Click on Open Menu Option in the right hand top corner of the screen, then click on Add-ons in the search box type Video DownloadHelper and click on Install. Once done, you will see and icon in the right hand top corner which is red/yellow/blue color
Mar 14, 2015 | Icon Computers & Internet
RESET DELL MONITOR E1709WC
Instructions
    • 1 Push the "Menu" button on the front or side of your Dell monitor. The button's icon resembles a miniature monitor. This will open the main monitor setting menu. Push the button again to exit the main menu and open the OSD menu.
    • 2 Push the "Down Arrow" button on the monitor to scroll through the OSD menu. Stop at "Factory Reset." Push the "Menu" button to open the factory reset menu.
    • 3 Push the "Down Arrow" button to select "Position Settings Only" to reset the monitor's horizontal and vertical screen settings. Press the "Menu" button to activate the setting changes.
    • 4 Push the "Down Arrow" button to select "Color Settings Only" to reset the monitor's red, blue and green color settings. Press the "Menu" button to activate the setting changes.
    • 5 Push the "Down Arrow" button to select "All Settings" to restore the monitor to its original factory settings. Press the "Menu" button to activate the setting changes.
    • 6 Push the "Up Arrow" button to select "Exit" to leave the monitor reset menu. Press the "Menu" button to exit the OSD menu. Push the "Menu" button again to exit the main settings menu.
Aug 02, 2012 | Dell Computers & Internet
Is there a code number that needs to be entered to bring the convergence pattern or menu on screen.
From a user standpoint you would follow these steps to bring up your Convergence menu:
1) Press your MENU button.
2) Press the Right Cursor Button to enter the Picture menu.
3) Press the Down Cursor Button until you highlight the MANUAL CONVERGENCE choice on the menu.
4) You will then see the following choices on the right hand side of the menu: Convergence Red, Convergence Blue, Multipoint Red, Multi Blue, Save Multipoint.
5) Once you choose either the Red or Blue choices you will get a crosshair in the middle of your screen. You will then use either your Up, Down, Left, or Right Cursor buttons to get the two images to line up correctly. If you still have multi images on your screen in either Red or Blue you would then have to adjust the Multipoint choice for that color.
May 14, 2011 | Philips 51PP9100D 51 in. Television
Wont load windows...just a blue screen with the mouse icon. Alt-f10 doesnt work at the acer screen
Windows is probably getting stuck on start-up and this is likely due to a driver problem. The presence of a blue screen with the mouse pointer icon on it has a description called BSOD (Blue Screen Of Death). BSOD was common in earlier Windows versions as they were not robust enough to withstand misbehaving applications. Current Windows better isolate applications so that BSOD does not occur but it can still happen during the start up process. My suggestion is that you should try running Safe Mode then do a System Restore to an earlier date when the system used to start properly. Strongly suggest that you have the system plugged into its AC adapter before doing this. The following is based on Windows XP (you didn't indicate what O.S. you had).
1. do a power-on and press F8 repeatedly to get the Windows Advanced Options Menu
2. use the up-down arrow keys to highlight Safe Mode and press the Enter key
3. on the Windows log-in screen, click your user name icon to log-on
4. on the Desktop window, click the No button to indicate a choice to use System Restore
5. on the Taskbar, click on the iconized System Restore to open the System Restore window
6. click the Next button to get the Select a Restore Point window with the monthly calendar
7. on the calendar, click a bold date then click the Next button
8. on the Confirm Restore Point Selection window, read and if it is OK click the Next button
9. during System Restore, the system will be shut down and restarted. Let this proceed normally.
Apr 30, 2011 | Acer Aspire One PC Notebook
How do you align the colors?
Press MENU button and ON-SCREEN MENU will appear. Press
POINT LEFT/RIGHT buttons to move a red frame pointer to
IMAGE ADJUST Menu icon.
Press POINT DOWN button to move a red frame pointer to the
item that you want to adjust. and then press SELECT button.
The level of each item is displayed. Adjust each level by
pressing POINT LEFT/RIGHT button(s).
Move a red frame pointer to
the item to be selected and
IMAGE ADJUST MENU
IMAGE LEVEL ADJUSTMENT
Press POINT LEFT button to decrease contrast, and POINT RIGHT
button to increase contrast. (From 0 to 63.)
Press POINT LEFT button to adjust image darker, and POINT
RIGHT button to adjust brighter. (From 0 to 63.)
Contrast
Brightness
Press either POINT LEFT button or POINT RIGHT button to obtain
better balance of contrast. (From 0 to 15.)
Gamma
To store manually preset image, move a red frame pointer to
Store icon and press SELECT button. Image Level Menu will
appear. Move a red frame pointer to the Image 1 to 4 where you
want to set and then press SELECT button.
Image Level Menu
Move a red frame pointer to any
of Image 1 to 4 where you want
button.
Store icon
Press SELECT button at this icon to
store the adjustment.
IMAGE ADJUST
Menu icon
Press POINT LEFT button to lighten red tone and POINT RIGHT
button to deeper tone. (From 0 to 63.)
White balance (Red)
Press POINT LEFT button to lighten green tone and POINT RIGHT
White balance (Green)
Press POINT LEFT button to lighten blue tone and POINT RIGHT
White
Jan 22, 2011 | Sanyo PLC XU35 Multimedia Projector
How do you turn the flash on? (with the vivitar vivicam 8018)
Your camera has a built in flash function which enables you to take photos when the light condition is not good.
1. Press the Up button. (for reference of buttons, please see the below figure mentioned)
2. Press the Up button once until you see the icon appear on the LCD screen. This indicates that the flash is forced on.
3. Press the Up button again to change to the auto flash function.
4. The icon will appear at the top of the LCD indicating that the auto flash is turned on and ready to use.
5. Press the Up button again to change from the auto flash to the red eye function.
6. The icon will appear on the LCD indicating that the red eye reduction function has been activated.
7. To turn off the flash function, press the Up button again until the icon is displayed on the LCD.
Note: A “Low Power” message will appear on the LCD screen, if you select the flash function when the battery power is insufficient. To continue using the camera with the flash, please change new batteries
Feb 13, 2010 | Vivitar ViviCam 8018 Digital Camera
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
How to take black and white pictures with the EOS 20D
1. Press the Menu button, and make sure you are on the Shooting menu (red)
2. Use the Quick Control Dial to scroll down to Parameters
3. Press Set, Press Set again
4. Scroll to B/W
5. Press Set
6. (Change sharpness, contrast, etc if desired)
7. Press the Menu button to exit
You should see the B/W icon to the right of center in the top LCD.
Apr 22, 2008 | Cameras
Pic taken stays on lcd screen too long
In the auto review section (under the setup menu) change from 5 seconds to 1 second.
Dec 26, 2007 | Panasonic Lumix DMC-FZ5 Digital Camera
Canon EOS 40D Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
