Question about Sylvania Televison & Video
My Sylvania DVD(silver)is 3 or s years old. I have installed a COX Digital Cable system and now my DVD wont respond. Why? Thank you, Bob Lee
    Genius:
  • 1,112 Answers
Hi: Make sure you note, if you changed how the DVD is installed to the system, also check the video inputs on the television to make sure you are trying to watch on right video mode. Turn on the DVD player and using the tv's remote cycle the inputs until you see your
DVD Logo. Cox may of installed the box using componet cables so this will change your input order in the tv's menu. Especially if you DVD was on one componet input and was moved to componet 2 input. If the unit is just not responding to the remote you can program you cox remote manually by hit the DVD Button in the remote and pressing setup until it blinks twice, then entering 000 and pressing the channel up button until the dvd cuts off and hit Setup to lock in code.
Posted on Nov 10, 2010
How do I connect a Sony DVD DVP-SR210P to a Scientific Atlanta Explorer 4240 HDC and a Sylvania TV C320SLX?
I am not sure you can connect your DVD player to your cable box. You should be able to connect both your cable box and DVD player to your TV set with two HDMI cables. This link is a pdf_usecares file of the TV manual that shows how to hook up your dad and cable box.
http://www.managemylife.com/mmh/pd_download/lis_pdf/OWNM/L0902617.pdf
Hope this helps.
Bob
Jan 04, 2015 | Sony DVP-SR210P Progressive Scan DVD...
Unable to find IR Code for power on/off using cox cable remote
1. Turn on a device and, if applicable, insert video
media, (e.g., cassette or disc).
NOTE: Please read steps 2-4 completely before proceeding.
Highlight or write down the codes and device
you wish to program before moving on to step 2.
2. On the remote control, press a device key once
(e.g., AUX, VCR, TV, or CABLE). Press and hold
SETUP until the selected mode key blinks
twice, then release SETUP.
3. Use the Manufacturer’s Codes (starting on
page 11) to locate the the type of device and
brand name and then enter the first four-digit
code for your device. If performed correctly, the
selected mode key will blink twice.
NOTE: If the selected mode key emits a long blink, the
code is invalid. Repeat steps 2 through 3 and try
entering the same code again.
4. Aim the remote control at the device and press
POWER once. The device should turn off. If it
does not, repeat steps 2-3, trying each code for
your brand until you find one that works. If it
still does not work, try searching for the code
(see Searching For Your Code on page 20).
NOTE: If the device does not have a POWER key, press
the (Play) key.
5. Repeat steps 1 through 4 for each device you
want the the remote control to control.
The potential codes for your Sylvania TV are:
0054
0030
0381
Here is the manual. The codes are on page 11 if you need more.
http://www.cox.com/Fredericksburg/digitalcable/Cox_d4.pdf
Hope this helps :)
Dec 22, 2007 | Televison & Video
Westinghouse 32' flat screen tv wont work with cox cable receiver
Hello
You haven't stated the type of signals that comes with your co-axial cable; analogue or digital. Anyway, you have to retune the TV after connecting it properly with Cox-Cable receiver with TV.
Feb 23, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Hitachi DV-PF 2U dvd player works fine when hooked directy to TV (channel 3) but won't work when connected through the new COX digital cable box. TV is set to channel 4, dvd player turned on, disc...
If the cable box needs to be set to 4, the TV will need to be set to 4 as well as the dvd player. The hookup should be cable box to dvd player to the TV for your system to work. Let me know if you have any other questions. Thanks.
Dec 30, 2010 | Hitachi DVD / VCR Combo
Cox Cable Remote wont program to my Sylvania LC320ss8 tv.
there are different codes for the devices that you are using. When you want to insert the code for the tv. > Switch tv on and then switch all the other devices off. Insert code. For digi box > switch on and all other devices off. Insert code for digibox. You must then switch between tv and digi box using the buttons on the top of the remote. Toggle between tv/ digi box.
Have a go with the codes below with the tv and the digibox both on, you never know you might get lucky as these are new codes, if not revert back to 1st solution.
Universal Codes (both should work using these, i think!!!!! try 'em)
002,
008,
155,
198,
227,
231
Here are the codes for the 1st solution.
Good Luck,
Hughie.
Tv
0062
0004
0009
0135
0189
0183
1141
0227
0456
0008
0068
0075
0141
0161
Digi Box.
0899
0227
0287
0290
0225
0456
0251
0292
0236
0458
1106
Jun 18, 2009 | Sylvania LC320SS8 32 in. LCD Television
Hook up Cox Dig CBL Box to receiver and TV for home theater
The easiest way to proceed is by using RCA cables (the red, white, yellow) to connect the cable box.
Jan 02, 2009 | Pioneer HTD-510 System
Cannot view tv program while recording on VCR
Hi and welcome to FixYa,
Initially, pls set the Samsung LCD TV to the Source selection as if watching a playback evgen if you are going to do a recording.
If that does not work, pls postback manner of connection (cabling) from Cox digital cable system to Philips DVD/VCR to Samsung LCD TV LN-T3253HX/XAA .
Good luck and Thank you for using FixYa. Happy Holidays.
Nov 15, 2008 | Philips DVP3345V/17 DVD Player/VCR
New dvd movie will not play
I rented Rush Hour 3 from blockbuster along with Woodcock and both did not play on my Sylvania DVD player. I did take them and put them on my computer and their was a page that came up INTERACTUAL
ENHANCED FEATURES
This DVD is enhanced with interactive features designed exclusively for use on a computer.
PLAY DVD with enhanced features (that prompted a download)
or PLAY DVD without enhanced features and you can play the DVD movie on your small home computer screen.
I believe that the DVD producers have added the ENHANCED FEATURES to be used on a computer and in so doing they do not work at least not on the Sylvania DVD players.
Jan 18, 2008 | Sylvania DVC850C DVD Player/VCR
Need code for universal remote Sylvania LC320SL8
We bought a Sylvania LC420ss8 HDTV.
Our current universal remotes would not work, I followed the advice on this site and got a Sony
RM- VL600 Sony Untergrated Remote Commander, use page 16 in the manual to teach the new remote off of the remote that came with the TV. It really works. I am happy with the tv and remote.
Dec 07, 2007 | Sylvania LC320SL8 Television
Universal remote
has anyone responded, I need the codes also.
Nov 05, 2007 | Lite On LVW-5115GHC+ DVD Recorder
Televison & Video Logo
282 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
