Question about Alert Driveway Patrol Infrared Wireless System
My yard sensor stopped working. The battery is ok. Red light doesn't blink on unit when motion is in front of it. So there is no sound on house unit.
The remote will not turn the TV on. When I turn it on with the button on the front, the power light on the TV starts blinking (no sound or picture). The red light will blink forever, and the TV will n
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician
Nov 01, 2014 | Toshiba Televison & Video
Why did my motion light stop working and the sensor light is blinking red?
Did you find out why?? I just purchased 2 of these and loved them as they worked for like a week and now both are not working however they are getting power as the red light comes on when there is motion...Please help if you know as I paid 110.00 each for these and I am confused how the bulbs could be blown?
Jun 02, 2014 | Defiant Flood Lights. 180 Degree Outdoor...
Furnace quits with 4 blinking lights on panel
Most likely it's a sensor triggering the unit off. You need to have someone determine which lights are blinking (there is a code to them) and then find out what the code refers to. Could be a simple as dirty filters.
Mar 07, 2014 | Heating & Cooling
Doesn't work
Try the test
Motion sensor on walk past or wave in front of it if the red light can be seen you have been detected to test the sonic function turn up sonic dial to hear the alarm harassment noise
If not heard get it looked at
If heard how old is dog as may be going deaf to ultrasonic sounds
Feb 25, 2014 | Aspectek Yard Sentinel - Electronic Pest...
Flood Lights. 180 Degree Motion Activated Solar Powered Floodlight -
Sounds like the batteries are not getting charged. Check to see if there was some packing material in place to keep the batteries disconnected for shipping.
Dec 05, 2013 | Cooper Lighting Flood Lights. 180 Degree...
The LED flashes, but the lights won't come on. Do I need to install a light shield. The sensor is mounted in a well shaded area 10 to 12 feet above ground. There are landscape lights beneath the sensor are...
There are settings on the sensor itself. Should be a dusk to dawn setting that will keep it off during those times and then function at night. as far as not working I would first suggest setting the sensitivity. Disrupting to power could have reset this.
Oct 15, 2013 | Heath Zenith Heath/Zenith SL-5411-WH Heath...
I bought a power adapter for the camera, but it doesn't seem to work without batteries in the unit. If I use the batteries alone, I will eventually get a red blinking light at the back of the camera,...
Because the camera is what is technically known as 'Portable'and is designed to work purely from the internal battery. the Power Adapter merely charges the internal battery
May 08, 2017 | Kodak EasyShare C330 Digital Camera
Fuji battery charger BC-45 - red light blinks when I put in battery and battery does not charge
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Aug 03, 2010 | Duracell AA/AAA NiMH Battery Charger with...
2001 olds silhouette non functioning alarm
red light? this is a factory alarm?? Is GM on the key fob? factory alarms dont have "motion sensors" and very few aftermarket alarms do. roll down the window and set the alarm, now open the door and see if it lights off.
Oct 18, 2009 | 2001 Oldsmobile Silhouette
Wiring motion sensor light
Hello Lesco1, first check the bulb, second I need Mgfr & model, third attempt BK from house to R of sensor & BK from sensor to BK of bulb.
Nov 06, 2008 | Electronics - Others
Alert Driveway Patrol Infrared Wireless System Logo
47 people viewed this question
Top Alert Home Security Experts
Paul Bade
Five sok
Five sok
Level 1 Expert
ka4iup
ka4iup
Are you an Alert Home Security Expert? Answer questions, earn points and help others
