Question about Uniden DWX207 1.9 GHz 1-Line Cordless Expansion Handset
I have a DWX207 with the four phones. The other day I tried using the phone and it said out of range and then seaching. I phoned in yesterday and thought I was going by what the gentleman said but still not working. Could you please send me instructions by e-mail and don't tell me to go to the manuel as I can't seem to understand it. I need help...this phone is only 2 and 1/2 months old. And worked up until Sunday night. My e-mail is lfunkk@shaw.ca Thank you
  • lfunkk Nov 12, 2010
    I had already done as you mentioned in your answer to my question.. Done of these things worked. I also phoned from my other phone and had phone assistance nothing worked. Since no one was able to help me with the problem I returned the item. The out of range would not work even 3 feet away---further was worse. The seaching stayed in where the printed information should of been. The directions you sent were the same as in the manual...
    Thanks.
    Colleen Funk
  • 8,197 Answers
Sorry we can not help you with the phone. I would take back for refund if not working after 2.5 months
Posted on Dec 07, 2010
  • 1,868 Answers
Hello and good morning! First a few questions...Do all 4 phones have the same problem; "Out of range, searching"? Does problem occur if you are near the base unit? Guru............saailer
Posted on Nov 12, 2010
  • David Burbee
    David Burbee Nov 12, 2010
    Hello! Here is additional information: The effective range of the DWX207 claims to be 150 feet...However, other electrical/electronic devices in and around the home may minimize that distance...Customer reviews of your phone indicate that the actual effective range is closer to 50 - 75 feet...When a handset reaches that maximum distance for its environment the message "out of range - searching" will appear...I have also included a simple method to register a handset...The directions included with the phone are a bit feeble...
    Unplug the base phone (either from the wall or by
    removing the connection at the base of the cradle...There is a
    "Find" button on the cradle... You can't see it with the phone in the cradle...It is located on the front of the cradle where the phone would rest if it was charging. While holding down the find button, plug the phone back in. Then hold down
    the pound button on the accessory phone until it reads that it's
    registering. When complete, place phone in cradle or base...
    Guru................saailer
  • David Burbee
    David Burbee Nov 13, 2010
    Hello! When you informed me that all phones were out of range when next to the base I would have suggested returning the item...Many reviews of the DWX207 mention the same fault that your system had...I wish I could have solved the problem without you having to return the product but the fault is an internal failure having nothing to do with set-up...If you require repair assistance in the future ask for saailer...I am here...
How can i get my dwx207 to comunicate with a phone line
that is an extension phone only will not work without the control unit e;i answering machine that plugs into phone jack on wall
Apr 12, 2015 | Uniden Dwx207 Dect 6.0 Waterproof...
Uniden dwx207
When a handset is reading "Searching", it can't communicate with the base. First, check if the base station is plugged into a live outlet. (Try plugging the base into a different outlet or making sure that the circuit breaker hasn't popped. I had a cordless phone base plugged into a UPS. During an extended power outage, the UPS was turned off. The phone didn't work until someone noticed and turned the UPS back on.) Move closer to the base station.
If this was an extra handset purchased later, make sure it is compatible with the base station. The Uniden DWX207 works with the DECT1500, DECT2000 and DECT3000 series bases. Register the handset with the base. The registration procedure depends on the base station. If the base unit has an LCD screen, with the phone in standby, press Menu/Select and press the down arrow to reach "Register Handset". Then press Menu Select again. (If the base doesn't have an LCD screen, unplug the power cord. Then hold the Find HS or Find button as you reconnect the power cord until the Charge/In Use light starts to blink.) Then press the # key on the handset before the registration period ends.
Make sure that you haven't exceeded the number of handsets for your base. You may need to de-register all handsets and then re-register them.
If no handsets will pair with the base, replace the base unit. The transmitter or the receiver aren't communicating properly with the handsets.
I hope this helps.
Oct 06, 2013 | Lands Phones
Uniden registering
Follow the registration instructions beginning on page 5 of the DWX207 manual at http://www.uniden.com/content/ebiz/uniden/resources/ownersmanuals/DWX207om.pdf
May 15, 2013 | Uniden Cordless Phone
HEY, Just got DWX207 and it's not working. It's been charging for 48 hrs. and when you pick it up off base it is dead. I did push in the button on base firts. On base it flashes Welcome Please Wait
When you got it do you take the back off to make sure the battery is plugged into the phone? if yes! the phone clearly has a manufacture defect and should be returned.
Mar 24, 2011 | Uniden DWX207 1.9 GHz 1-Line Cordless...
Wont charge
Maybe your charger is broken or the phone is broke try to get it fixed
Mar 12, 2011 | Uniden DWX207 1.9 GHz 1-Line Cordless...
My uniden waterproof phone does not charge.
Make sure charging indicator showing charge, if so! the battery will need to be replaced, try and get the genuine replacement because there have been problems reported with aftermarket batteries not working in the phones due to the specifications not matching the genuine product.
Jan 07, 2011 | Uniden DWX207 1.9 GHz 1-Line Cordless...
Handset out of range - message
We totally unplugged the phone, made sure the battery was charged and reset the phone as though it was brand new, in other words started from scratch. It seemed to work and the phone is O.K. now
Jan 16, 2009 | Uniden TRU9585 Cordless Phone
Uniden DWX207 1.9 GHz 1-Line Cordless Expansion Handset Logo
106 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
