Question about Brother MFC-9840CDW Laser Printer
Drum error wont go away - Brother MFC-9840CDW Laser Printer
  • Brother Expert
  • 159 Answers
This should be an easy one. Your Brother doesn't know it has a new drum until you tell it like this:
  1. Open the front, where the drum is.
  2. Touch the CLEAR button.
  3. The display will ask if you replaced the drum. I believe you touch 1 for "yes."
  4. Close the front door.
Posted on Nov 10, 2010
PRINTER DRUM ERROR
The drum unit needs to be replaced as it has reached maximum prints for the drum.
The drum unit is the carriage part that the toner unit sits in before it is put in the machine.
Aug 29, 2014 | Brother HL 1440 Laser Printer
Drum error dr-420
Sir/Madam
he following error messages will continue to appear if the drum counter was not reset when you replace the drum unit with a new one.
  • Replace Drum
  • Drum End Soon
  • Drum Near End
  • Drum Stop
To clear these error messages, you need to reset the drum counter,
Or Visit official Brother Printer website For Brother Printer Troubleshooting Page Url Below:http://welcome.solutions.brother.com/BSC/public/us/us_ot/en/faq/faq/000000/002800/000037/faq002837_000.html?reg=us&prod=mfc7340_us_as&c=us_ot&lang=en
Or
Still Having Problem then follow Us On For
Brother Printer Support
Jan 14, 2014 | Brother Office Equipment & Supplies
Drum error Brother DR350 take drum out and slide blue tab across corona wire and return drum to printer. Error message will not go away
Here's how I fixed it. Remove assembly from printer, and remove the toner cartridge. Using cotton balls, wipe the drum clean, turning it a quarter turn each time between wipes. When you have a clean drum, replace everything, and it should work fine till next time.
Feb 10, 2011 | HP Office Equipment & Supplies
Push start and machine wont fill and draining/unlocking light sarts blinking about 2 seconds later
My machine had the exactly same problem:
1. Push Start button to wash, but Draining/Unlocking light will flash right away. The drum started to run and stopped
2. No error code shown up
3. Run Quick test: no error code
4. Run Universal Test: error code F25 (later, found nothing wrong with the CCU)
What I did:
1. Clean the bump: found coins and strings.
2. Clean the drain pipe from the pump to tub: found more coins.
3. Clean chamber of pressure switch at the tub: found nothing.
4. Clean the gap between tub and drum: found a credit card!
After the cleanings, the Draining/Unlocking light would still come back and I almost gave up. Amazingly, I ignored it and a few minutes later.... the machine started to run as normal!
It seems that CCU needs sometime to reset itself after the failure.
Jan 24, 2011 | Whirlpool WFC7500VW Washer
SHARP AR M317 ERROR U2-40
That is a CRUM chip communication problem. Crums are on Drum units. Toner cartridges and Fusers.
One may have simply expierd, may have failed.
Mar 15, 2010 | Sharp AR-M317 Black and White Copier
HP CLJ 2840 - Engine error
It seems from the outside looking in that the drum may have frozen up the drive motor.
Remove the new drum and install the old drum and see the the error goes away.
Jul 06, 2009 | HP LaserJet 2840 Printer
L-50 machine gets Rec.paper jam slide platen left
Slide the uper unit to the left by pulling handle on the left,open cover on the right,remove drum unit by pulling on the handle,remove paperjam.
Oct 31, 2008 | Canon PC-1060 Black and White Copier
Canon imagerunner 2010f wont print
You may need to go into service mode and reset the drum status. Service mode is dangerous and recommended for Canon techs only.
Aug 25, 2008 | Canon imageRUNNER 2010F All-In-One Printer
Error message won't go away.
This message would continue to appear if the drum counter was not reset when you replaced the drum. To reset the drum counter, follow the instructions listed below.
  1. Open the front cover.
  2. Press the Options key on the control panel.
    The display will show "REPLACE DRUM - 1.YES 2.NO".
  3. Press 1 to reset the drum count.
  4. Close the front cover.
May 16, 2008 | Brother IntelliFax-2820 Laser Fax
Replace drum error
Hit the clear button with the front door open. this i believe is to clear drum counter. just follow the directions that came on a piece of paper with the drum.
Nov 26, 2007 | Brother IntelliFAX 3800 Plain Paper Laser...
Brother MFC-9840CDW Laser Printer Logo
619 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
