Question about Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho
Where can I purchase the plastic tripper switch
You posted under Intermatic or Malibu power packs:
For full information on Intermatic/Malibu power packs showing troubleshoot steps, replacement trippers, useful links, warranties and tips: Including order form and direct link for ML series black and red trippers
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Posted on Mar 20, 2011
Where to purchase trippers for GE mechanical time switch model #15163?
This actually a Jasco 15163 and according to www.harwareandtools.com it takes a Jasco 15602 tripper set. This tripper set can be found for online order at http://www.jascoproducts.com/products/pc/Replacement-Timer-Tripper-2-pack-p1089.htm#.U9Ov2bHG-f415602webg2.jpg
Jul 03, 2014 | General Electric GE 56941 24-Hour Outdoor...
Can I purchase extra on/off set pins, if so where can I get them?
1) Copy following link for Intermatic tripper resources:
http://waterheatertimer.org/Intermatic-trippers-and-parts.html#trippers
2) Add comment and include model number of timer for best possible help identifying tripper.
3) If you have different brand timer, then include that brand and whatever identifying information you can see
Dec 27, 2012 | Intermatic T103 Indoor 120-Volt 40-amp...
I have a timer hooked up to operate my outdoor landscape lights so that they come on around dusk and turn off at 11 pm or so. The "on" tripper which is white clicks as the timer rotates past the...
Sounds like the OFF tripper is worn down.
Timer needs to be replaced unless you have Intermatic-brand timer.
Intermatic is only company that sells plastic replacement trippers for their timers.
Except Intermatic on-off trippers are typically red-green.
It's possible your trippers faded in color.
Open following links to identify Intermatic timer and tripper:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#appliance
Sep 18, 2011 | General Electric Hardware & Accessories
Flippers not functioning
be sure that the trippers you are using are for this specific model if you purchased them seperately.
if they are for your model then make sure they are fully seated so that they are engaging the switch. if you are using trippers you have had a long time the remove one go to your local store where you can buy the low voltage power pack. they should have additional trippers to go with your model examine the new trippers to make sure yours look the same and are not worn or broken. if all appears good then you may have a problem with the switch that is engaged by the trippers and the unit may need to be replaced.
Feb 25, 2011 | Malibu ML200RTW - Low Voltage Power Pack...
I need replacement clips to a hb31r timer, were can i find them?
I have 2 links to plastic Intermatic trippers.
I search timers each day, and have not run across a different plastic Intermatic tripper.
images on page will let you compare with your tripper:
http://www.westsidewholesale.com/timer-switch-tripper-sets-red-on-and-green
http://www.hottubwarehouse.com/ProductDetails.asp?ProductCode=156PB10398A
If this tripper is correct, add a comment and help fixya community give this information to others asking same question.
If this tripper is incorrect, then HB31 tripper may not be available.
Large number of timers do not have replacement trippers.
You can also take advantage of fixya phone support.
Expert can answer your question for a price.
Dec 25, 2010 | Intermatic 24 Hour Outdoor Timer HB31R
Where can I purchase the trip inserts for this product
Nov 09, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Having trouble setting timer o ML200RT
Set on-off times by setting trippers
-Insert trippers
-Red tripper is ON
-Black tripper is OFF
-New timer has 2 sets of trippers
Set time
-Plug-in & turn-on power pack
Turn dial clockwise to set time of day
Manual override:
Turn manual-on-off switch counterclockwise
Troubleshoot:
-Power pack not turned on
-Plug does not have power > try hair dryer in plug to see if it turns on, check GFI breaker in bathroom, replace plug
-Manual-on-off is set to OFF > rotate to ON
-Outdoor lamp burned out > test with another lamp
-Important to replace burned out lamps promptly, or other lamps burn out quickly
-High household voltage will reduce life of timer
-Timer designed to last for many years under normal conditions
Sep 22, 2010 | Malibu ML200RT - Low Voltage Power Pack...
Clock works o.k. but does not trip on Intermatic pool timer. Operates in manual mode only. Problem started when dial became jammed and after I freed it up neither the on or off tripper would trip the...
no the tripper switch is not a part that they sell. The only advise is to purchase a new clock. If the housing is in good condition you can take the new clock out of housing and just swap out clock this way you do not need to pull out all the wiring from the housing.
Sep 19, 2010 | Intermatic T101 - 24 Hr. Dial Time Switch...
Malibu ML200RT - Low Voltage Power Pack -200 Watt - With Timer - Plastic Ho Logo
123 people viewed this question
Top Malibu Hardware & Accessories Experts
Gene Haynes
Scott Jelt
Scott Jelt
jdthefixer
Are you a Malibu Hardware and Accessory Expert? Answer questions, earn points and help others
