Question about Toshiba 62HM95 62" DLP HDTV
When i turn tv on it says the fan used to cool the cable card had stopped. please unplug tv power cord from the wall and contact a toshiba authorized service center
2 Suggested Answers
  • 1039 Answers
SOURCE: Caution The fan used to cool the Cable Card has
Blow dust out of the fan to see if it still work. If not replace the fan.
Posted on Dec 05, 2009
No picture light blinking
We recommend you remove all HDMI cables from the TV then unplug the unit's power cord for 30 seconds. Then plug the power cord directly into the wall. If the problem persists we recommend you have the TV evaluated by an authorized service center.
Mar 24, 2014 | Panasonic TC-32LX85 LCD TV
TV won't turn on no lights.
Mar 23, 2014 | Panasonic Tc-42px24 42 in. Plasma TV
Lights went off now tv wont come back on
Mar 22, 2014 | Panasonic VIERA Televison & Video
The fan has stopped working
Check and replace either the damaged fan or its speed regulator board. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy.
Mar 14, 2014 | Toshiba 55TL515U 3D LCD TV
My toshiba lcd tv will only turn on and off
Hi Friend,
Please folliow the below steps one by one
Step 1: Turn on the TV
Step 2: Hold the ON/OFF Button for 10 to 20 Secs
Step 3:Without taking the hand from the ON/OFF button unplug the power cable connected to the wall outlet from the TV
Step 4:Without taking the hand from the ON/OFF button put the power cable back to the outlet
Step 5:Now take the hand from the ON/OFF Button and try to turn it ON again and check
If still you are having the same problem then please check the resolution configured in the Screen,try to reduce the Colour and the brightness of the TV
Even after that you are facing the same issue please check with the Display Card in the TV,
If you have any Clarification please feel free to contact us
Regards,
Ayyasam
Apr 03, 2010 | Televison & Video
TV MAKES A HUMMING NOICE WHEN TV IS ON, WHEN TOUCHING THE BACK OF TV WHERE NOISE COMING FROM IT IS VERY HOT. IT WILL THEN GET LOUDER AND EVENTUALLY CUT OFF TV. TV WILL COME BACK ON AFTER IT COOLS OFF. WHAT...
It is either the color wheel or a fan. To isolate the color wheel, remove the back cover and make sure you put the lamp door back on so that the door interlock switch is activated. Turn the set on and get the picture and humming noise going. Just to left of the rear fan there are some wires. One is a really flat brown or rust colored ribbon cable that plugs in to a board on the left of the wires. This is the color wheel ribbon. When you unplug it the set will keep going for a moment or two but if the noise stops, you will know it is the color wheel. Don't be alarmed because the set shuts off with this ribbon disconnected. Just let all the fans stop (for proper cooling) and then unplug the set for 5-10 minutes. If the humming did not stop you have a bad fan motor. Plug the little ribbon back in while you have the set uplugged. Plug the set back in and turn it back on and try to isolate which fan it is, if it is a fan. If you determine it is a color wheel, the light engine will have to be replaced as Toshiba does not offer just the color wheel. If it is a fan, those can be replaced. I hope this helps. Let me know what you find and thanks for using fixya.
Nov 23, 2009 | Toshiba 62HM95 62" HDTV
No picture or sound?? status light flashes in four blinking intervals. I was told it could possibly be the lamp it has never been replaced.
The STANDBY light will flash if an issue is detected within the television. This can sometimes be resolved by simply following the steps below to reset the television.
  1. Turn off the television.IMPORTANT: For a projection television that uses an internal lamp, wait 5 minutes after turning off the television to allow the lamp to cool before continuing with the following steps.
  2. Unplug the television power cord from the electrical outlet.
  3. Let the television remain without power for 60 seconds.
  4. Plug the power cord back into the electrical outlet.NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  5. Turn on the television.
Aug 08, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 62HM95 62" DLP HDTV Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
