Question about Motorola Mobility SLVR L7 Cellular Phone
My Phone is phone is just swicth of now..........I plug my motorola charger just to on it same thing.........tell me how is going to on thanks modem Moto L7
    Brigadier General:
  • 7,752 Answers
Take the phone and have it check or diagnose to determined the issue
Posted on Aug 29, 2008
When i plug it in to the charger it says invalid battery
ik this happened to me too well, wat i did was i kept trying to charge which the thing is that when it says invalid charger thing its becuz ur charger has some nasty things on it so wat i would do is go to ur phone company place and buy a new charger... :D
Dec 21, 2009 | Motorola Mobility RAZR V3
Motorola l6 does not start up or switches on
The obvious here is, is the battery charged? Does your charger have an indicator light that comes on when plugged into the phone? Try to use your USB cable, connect it to your computer and then your phone. It should charge unless your battery is wasted. I would first ensure your charger is actually charging the battery. If that seems to be working, then check your battery to ensure it's good ( take it to your local phone store, they'll be able to tell you ). If the battery is bad, replace it. If the charger's bad, replace it. If neither is the problem, your phone would need to go to a repair shop. You can contact us for a repair estimate.
Nov 26, 2009 | Motorola Mobility L6 Cellular Phone
Whenever i plug my charher into my motorola razor it says unauhorized charger.
The "unauthorized charger" message is hence telling you that the power
output of your charger is significantly lower than a Motorola charger
would provide. It may or may not still charge the phone, you'll have
to try it to see. If it does charge the phone it will take longer to
do so than a higher power charger would.
Hope this helps. =)
Oct 20, 2009 | Motorola Cell Phones
My motorola hint phone says "unauthorized charger"
u have to turn off ur phone and then put the charger on..thts another way to fix it ..it can be any charger..u have to turn off ur phone then put the charger on
Oct 04, 2009 | Motorola Mobility Hint QA30 Cell Phone
Battery charger
I'm not sure what the problem is with your phone, but this happened to me with another Motorola phone and it turned out to be a battery problem. You can try another charger, which might work for some time before you get the same result, but I believe you will need to replace the battery. You can try calling Motorola and checking to see if they will give you a discount on another battery. I've had several Motorola phones give me this same message and most of the time it was only infrequently and resetting the phone and reinserting the charger worked, but if it persists, try the battery.
Jul 06, 2008 | Motorola Mobility V325 Cellular Phone
'Unable to Charge'?
COULD BE THE PHONE BUT MOST LIKELY ITS THE CHARGER, IF ITS AFTERMARKET GET RID OF IT AND BUY OEM, TRY AND TEST IT OUT WOULD A FREINDS MOTOROLA CHARGER SINCE THEY'RE MOSTLY THE SAME CHARGERS AND SEE IF YOU STILL GET THE MESSAGE.
Apr 06, 2008 | Motorola Mobility MOTORAZR2 V9 Cellular...
No Motorola Modem
try uninstallin' it the re-installing it.....or go to motodev.com and sign-up and download the updated driver for the modem.
Feb 09, 2008 | Motorola Mobility RAZR V3
Charging problem!!! PLEASE READ!
as i think that charger was not compatible to your phone so when you tried charging it the battery is dead bcoz of excess voltage than it normally bears with the compatible charger of ur phone ...
so this excess voltage has made the battery to be short circuited due to this may be the charging ic or the capacitor is gone ...
so i suggest you to take the cell to the near by technician and just have a check...
the only problem with all motorola phones is that it only charges with the charger with the desired voltage ... if the voltage of the charger is low then it will not show any response(i mean it will not charge but it will not cause any thing to battery as it is of less voltage than the desired voltage )
so i think the charger you buyed provides more than the desired voltage so the battery is dead .....
Feb 07, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Blank Screen
Sounds like the charger's defective. Did it get dropped accidentally? Take both the phone and the charger back where you got it. They should fix the problem for you. Battery in the phone is probably dead and just needs charging.
Aug 19, 2007 | Motorola Mobility RAZR V3
Motorola Mobility SLVR L7 Cellular Phone Logo
24 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
