Question about Toshiba 42H83 42" Rear Projection HDTV-Ready Television
The blue won't align with the other colors. It looks like a double pic, but it's only the blue that won't align with the others.
    President:
  • 788 Answers
It sounds to me like you have damaged Convergence IC's
If you try to adjust convergence with the flash focus, perfect focus, (depending on the make of your set) or by manual convergence and the lines will not line up or even move. You have a damaged convergence IC.
If you want to repair this set yourself, I have some instructions below that will be a help to you.
While it is not a very hard repair, this repair can be a bit tricky. If you have a 45W soldering iron, solder, solder wick, heat sink compound, and some basic soldering skills, you can repair the television yourself.
*** VERY IMPORTANT NOTE***
If your set is not producing a clear picture and the colors are not lining up, do not continue to watch the set as this can lead to further failure and possibly damage the individual CRT's in the set.
I have repaired hundreds of these sets, so if you have any questions after reading the following, please reply to this post and I will help you in any way that I can.
With that aside I have some support suggestions that I have put together that may help you make an informed decision.
You should be able to get a local service center to repair this at your house for between $350.00 - $450.00, If you want to repair this set yourself, I have some instructions below that will be a help to you.
How do I tell if the IC's are damaged?
Since you cannot look inside of an IC, you will have to locate some of the components in the area around the convergence IC's. You may be able to see some resistors that have changed colors or you test a resistor and it no longer reads the value marked by the color bands or the printed value. You will have to replace the IC's and the supporting components.
When you remove the old IC's, please be sure to remove all of the old heat sink compound, as it can act as an insulator for the new IC's and cause them to overheat. I usually clean the heat sinks with alcohol and a small rag.
Where are the IC's located and how do I find them?
There are two and large IC's that control the convergence in a big screen set. Some of the newer sets only have one. If you only have one, it is right in the middle of the set on the center circuit board. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110.
Along with the convergence IC's there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC's and you should be looking for either ones that have opened or have changed values.
If one of the convergence IC's are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
http://www.andrewselectronics.com/welcome.aspx
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC's that are available.
I would also advise that the convergence IC's be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC's fail after a short time, even though they look exactly like the OEM IC's. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try
http://www.tvrepairkits.com/ , they do carry OEM or better parts. When you order from them you will get a kit with instructions on how to do the repair, step-by-step.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Nov 10, 2010
    Genius:
  • 1,112 Answers
HI:
One of your convergence IC have failed. I recommend having both of them replaced as the other may not be far behind to fail also, They are large OP-AMP IC's that control the beam in each of your picture tubes. They may use the part# STK-392-110, google this number for better info on the IC's and where to get them. If you know how to solder and unsolder electronic componets then you can install them yourself, saving you some money. They are the two or three LARGE BLACK IC's mounted on a large metel sink. Typical price for most local shop to repair this problem is $130-$210.00 depending on what IC's part number is installed.
My colors are not blending correctly anymore. My green is giving me a double picture. I have tried to blend them on the front and back but not luck. I need help
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngCONVERGENCE SOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 11, 2011 | Hitachi 50DX01B 50" Rear Projection...
I 53" Hitachi Projection TV and I get double
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Common Problem #1) Convergence has gone out
  • Screen looks 3D
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
Jan 10, 2011 | Hitachi Televison & Video
There is double vision at times, then it goes away.
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Your set may have one or more of the following symptoms....
*Dull looking pic
*White looking pic
*Halos around objects
*Red/Orange looking pic
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 07, 2010 | Televison & Video
The pic is real brightand blue waypoint missed up
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
  • Halos around objects
  • Red/Orange looking
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 01, 2010 | Philips 55PW9363 55" Rear Projection...
Double image and colour
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
  • Dull looking video
  • White looking video
  • Red/Orange looking video
Oct 07, 2009 | Sony KP-53HS30 53" Rear Projection...
COLOR PROBLEM
you have a miss aligned convergence. try to aligned it first.
Aug 06, 2009 | Philips 55PP9363 55" Rear Projection...
Blue at top of my screen and showing double
Projection sets have two very common problems.
The first common problem is convergence
*Screen Looks 3-D
*Colors wont align
*Dull looking picture
*White looking picture
*Red/Orange looking picture
Apr 24, 2009 | Hitachi 51F59 51" HDTV Projection...
I have a Hitachi Projection color TV 57F500. The picture I get on all channels is a double people, double everything. One double is Green and teh other is Red. No other TV's do this and I am using Dish...
*Screen Looks 3-D
*Colors wont align
Dec 05, 2008 | Hitachi 51F500 51" Rear Projection...
Colors are out of alignment
There is an alignment mode that you can get to. You must take off the back cover and look for the alignment switch I suggest that a tecnician do this because he has the propper tools and knowledge. If just an allignment is all it needs it should not cost that much. You have to try not to move this type of tv around because it is very sensitive and the slightest bumb can send it out of wach.
Nov 17, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Red, Blue And green put of alignment- see double on screen all 3 colors off
Your convergence amps are bad. Replacement is necessary and I would recommend contacting a servicer in your area. You can find an authorized JVC serivcer at this link http://maps.jvc.com/cAscList/
Jun 06, 2007 | JVC AV-56WP74 56" Rear Projection...
Toshiba 42H83 42" Rear Projection HDTV-Ready Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
