Question about Biostar Black IDEQ200T 865G S478 Pentium 4 Small Form Factor System (BBBIIDEQ200TB) Barebone
Computer wont turn on
Hi i have a
Biostar Black IDEQ200T 865G and it will not turn on all it has is a oringe light on the frount can u help
thanks andy
Try binning it!
Posted on Aug 20, 2008
    Novelist:
  • 121 Answers
It sounds like either the mother board is bad or the power supply is bad. If you have an extra computer try swapping the power supply over to this computer. If it still does not turn on the motherboard may be bad. One other issue you may have is the power switch could be bad. This is a very rare issue if the power switch is bad. The way to test to see if the power is bad is try and plug in a switch from a different computer. Keep me posted. If you found this solution helpful please rate me.
Thanks - Tech101
Posted on Jun 24, 2008
My ds lite was working fine then i dropt it (OOPS) now it wont charg the light on the side the oringe one and it flicks on for a sec then it turns off and of cours wont turn on
Hello.
Try removing then replacing back the battery. If that doesn't work, it needs servicing. There can be many causes for that problem.
Aug 11, 2011 | Nintendo DS Lite Console
Respected sir, i formated my sytem, now i
Try this site
http://www.biostar-usa.com/mbdownloads.asp?model=p4tsv.
Hope u can find the download link for Audio
May 21, 2010 | Biostar P4TSV INTEL 865G Motherboard
Decode Colors of Clarion RAX 341D harness.
well i think your talking about a car cd player most of them are all the same so
red is power when the key is on
yellow is Constant power
black is ground
blue is your remote wire - for amp or power ant
green and the green - black is your left rear speaker
purple and purple - black is right rear speaker
white and white - black is your left frount speaker
gray and gray - black is your right frount speaker
so on the speaker wires with the black runing down them is alway the neg and the solid color is pos
Mar 10, 2010 | Clarion Car Audio & Video
NEW BIOSTAR MOTHERBOARD DOES NOT BOOT
Good day sir, let try to test first the power supply, Unplug the power cord, remove the 20 pin (24 pin for the late model) molex power connector from the motherboard, plug in the power cord, get a 2 to 4 inch jumper wire, short the green wire with any of the red or black wire on the molex 20 pin power plug, the result maybe the following:
  1. you will see the power supply fan turn. you power supply is in good order. replug the power supply, and test again.
  2. you will see the fan turn for a few second then stops. you power supply is selective, and may require a different type of motherboard. Get a new one.
  3. you wont see the fan turn at all. get a new one.
If in case you are with #1. uinplug the power cord and remove all the expansion cards, data cables from the hard disk and cd drives. we are trying to isolate the problem. make sure that the only connected cables on the motherboard are as follows:
  1. 20 pin power cable.
  2. 4 pin 12 volt power cable (if applicable)
  3. speaker
  4. power switch
  5. power led
Test the pc once more. plug in the PC. If still the board wont power on. problem with your motherboard. Note:make sure your RAM is good. Hope this helps.
Aug 26, 2009 | Biostar I865GV-M4 (MB865GVM4) Motherboard
Biostar gf7100 mp - wont boot with ext usb drive attached
Hi, What you have to do is shut down the machine, pull the CMOS battery(CR2032) out and out and put your jumper on pins 1-2 from 2-3. Wait 30 seconds and put the battery back in. After installing the battery, put your jumper back to pins 2-3 from 1-2. This should work.
Jul 07, 2009 | Biostar GF7100P-M7S Motherboard - v6.0,...
Replaced P4 865G. Turned on the power afterwards to only a black.
please check your vga... try to replace the vga ...
May 26, 2009 | Computers & Internet
Usb driver is not available
I have a intel desktop board sr.no - DG33FB
and the sound driver along with the CD of driver is not installed to unknown reason
please help us by giving the realtek high definition audio driver
May 07, 2009 | Biostar P4TSV INTEL 865G Motherboard
Cd for BIOSTAR BI8600GV Intel 865 chipset mother board lost
http://www.motherboard.cz/mb/biostar/P4TSV.htm
I think you will find all you need there ...look carefully to be the exact same model if you want to flash the bios...otherwise its safe
Apr 08, 2009 | Biostar P4TSV INTEL 865G Motherboard
Sound driver
there is more than one company producing a motherboard with model 865g
Most common one is intel , here are drivers for intel 865g
You need to download the PCI sound driver at bottom of page.
Here instead are drivers for Elitegroup 865g
Regards
Apr 18, 2008 | Edirol UA-4FX External Sound System
Biostar Black IDEQ200T 865G S478 Pentium 4 Small Form Factor System (BBBIIDEQ200TB) Barebone Logo
87 people viewed this question
Top Biostar Computers & Internet Experts
Jayburt
David
David
Jerry Umali
Are you a Biostar Computer and Internet Expert? Answer questions, earn points and help others
