Hi, I have a sony rear projection TV when i try to turn it on it clicks ,buzzes for a for seconds then goes into standby, i took the back off and the buzzing is coming from the ballast board, in particular a canister shaped component which also flickers/flashes purple while buzzing, do i need a new board or is the problem the lamp? thanks Si
    Genius:
  • 1,112 Answers
Hi:
That is correct that canister is the lamp, seems its trying to light, If you have not replaced the lamp since you purchased the unit then this is the perfect time to do so. This buzzing from the ballast is normal just means it has received signal to light the lamp. Just start by replacing the LAMP>>>
Posted on Nov 10, 2010
Testimonial: "speedy helpful reply, many thanks."
  • 4 more comments
  • bj0n3d Nov 11, 2010
    Thanks for the reply techman007.
    When i refered to the 'canister' shaped component i was refering to a small component on the ballast board itself, it looks like a short fat diode if you know what i mean, it is white in colour and it is this that is flickering/flashing purple when the buzzing occurs, like its arcing inside the component, sorry for not making thisclear but would this still suggest a replacement lamp is necassary or could it be the ballast board itself? I'm on a bit of a budget so would prefer not to have to replace the lamp then the board or vice-versa.
    Many thanks again techman007
    Si
  • Lavell Turner
    Lavell Turner Nov 12, 2010
    This part is the spark gap if it sparks then it is a good indication that the lamp is faulty. But if it is a cansiter shaped it very well my be a bad capacitor, they tend to puffy on the top this indicates a leaky capaicitor, If you can take the part out of the unit by unsoldering it and get another one with the same value and voltage rating as othe old one, not the polarity on the cap also one end is neg and the other pos..
  • Lavell Turner
    Just replace the lamp..
  • bj0n3d Nov 12, 2010
    Hi Techman007,
    I'm sure the component is not a capacitor, and I will get a new lamp and hopefully this willresolve the problem.
    Out of interest, I have uploaded a picture of a similar ballast board which has the same component i'm talking about, it is located at the bottom right of the board in the picture, above what looks like a resistor and below the brown box thing with the lamp leads coming out, it's white and has 2 blue/purple stripes and some blue writing i think between the stripes, I'm just curious now as to what it is if you have any idea?
    Thanks for the help.
    Si
    forgot the link to the pic... http://www.mypicx.com/11112010/ballast/
    techman007, ignore those replies, I see that component is called a sparkgap as you said and as it's sparking the balast is fine, I'm going to order a lamp from ebay unless you can recommend a cheap supplier?
My sony wega KDP57WS655 tv wont turn on...makes noise like it is coming on, clicks then turns back off and standby light is flashing
If the red light is blinking in front that sasy lamp. Your lamp needs to be replaced. They cost about $100.00 at your TV Fix It shop. Very easy to replace yourself
Nov 20, 2012 | Sony Grand WEGA KDP-57WS655 57" Rear...
KF50XBR800 Rear projection LCD TV on and then standby
from how long you have this problem? and what made it start?
do u remember the cause?
Dec 28, 2007 | Sony Grand WEGA KF50XBR800 50" Rear...
There is no picture when I turn the TV on, the red lamp light under the power button is blinking, when you turn the tv on, it goes off for 60 seconds, there is a ringing buzz every 20 seconds, then the tv...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs it could be time to replace the lamp.The lamp you need is xl-2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click-48173.Have a blessed one!
Apr 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Samsung 50" r p tv switches off
Replace your Lamp BP96-01073A Fox has them $109.00 1-800-227-5369
Dec 29, 2009 | Samsung HLN5065W 50" Rear Projection...
Hi, tv set goes into standby,when you reset the picture is bright green for about 10 seconds and goes back into standby.
tv is drawing too much current and protection circuit kicks on and shuts tv down. try turning all screen controls all the way down. if that doesnt fix it, sounds like bad green picture tube. suggest local service center
Nov 09, 2009 | Toshiba 65HX83 65" Rear Projection...
Hi. My sony KDF-E50A10 will turn on for about 30 seconds, then the picture and sound go off, the standby/power light flashes 49 times green and the set turns back on. After 30 seconds, the same thing...
tv works for about 2 minutes, then shuts itself off. the red standby light flashes 50 times, then the tv. comes back on for approximetly 2 minutes then goes off again, only to repeat again
Sep 28, 2009 | Sony KDF-E50A10 TV
Sony tv turns on then off immediatly..standby light then is on
hey i have the same thing with my tv how do you fix it do you know?
May 29, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Sony 57 inch WEGA Projection TV
Hi, this is a very common failure, you need to replace 2 IC chips on your power supply board, marked on the top of the IC`s is this number: MCZ3001D you can purchase them here if you are very proficient at soldering & un-soldering, and the board has to come out of the tv to do this, you might want to call a tv man for this one, but it will fix your set, happy holidays, BMW Rider
Nov 29, 2007 | Sony Grand WEGA KDP-57XBR2 57" Rear...
Televison & Video Logo
210 people viewed this question
Top Televison & Video Experts
Electro Med Services...
