Question about Bose in-ear headphones - Black with black/white cord
Bose IE2 earphones cable developed a greasy almost oily feel that I cannot get rid of.
I have ice forming on copper line near compressor and there is a oily greasy substance on the compressor. What might be the problem?
the greasy dust is from a gas leak in the system and the oil is coming out with the gas
the ice forming on the pipe is the internal evaporation of the liquid gas
I suggest that a technician be called to repair the system
Oct 14, 2016 | Refrigerators
Earphone-only left earphone works... how can u repair right earphone
Rotating the jack or twisting the wire joint on the headset might work.
Nov 09, 2012 | Bose Around Ear Headphones Earphones
Is it recommended for oily skin? does it give greasy and shiny looks?
I've made the mistake of buying that product and it really doesnt work at all, even with a tonne of powder on your face. You should try looking at other brands such as Chanel because there you get expert advise about what type of foundation is best for your skin. My skin is also extremely oily and i use the Chanel Vitalumiere Aqua. IT IS AMAXING, it gives you a natural look and doesn't give a greasy look at all. you dont even need to use powder!!!!!!!!!!!
Jun 06, 2012 | Avon ANEW Age Transforming Compact Makeup...
How do you take care of greasy hair?
You don't need a lot of conditioner because your hair is naturally oily. You need a shampoo that has camomile, mint or lemon in it to combat the greasy. If it is unusually greasy then you should go see a trichologist to determine is there is a problem in your scalp.
Nov 23, 2010 | Health & Beauty
Right earphone shorting out
Good morning,
I would start off with calling Bose they do have a good warranty program and would help you.
Sep 21, 2017 | Bose QC2 Headphones
Air conditioner just quit. just blows hot air all fuses i could find were good
sounds to me that it needs recharged. You can a refill kit to fill the refrigerant, but you need to check all the fitting on the a/c in the engine compartment for a dirty/oily/greasy feel or look. If you find some then the system needs resealed. And they have kits for that also at the auto parts store.
Hope this helps
Aug 09, 2009 | 2005 Dodge Neon
Greasy oil and water is leaking from under the washing machine?
Hello, the good news is the water is coming from the pump and is easily replaced, the bad news is if you are seeing a yellow oily substance your transmission has a leak and will go bad at some stage soon. The question here you need to ask yourself is do you want to spend $35 on a new pump when your going to need to buy a new washer? If so pull the machine out and puch it back so it leans against the wall umder it's own weight. wedge some thing underneath the washer so you can access the bottom without the washer falling on you. you will see the pump attached to the motor which is attached to the transmission. remove the 2 clips and 2 pipes from the pump, remove the pump and replace it, reassemble in reverse order, you should be able to see where the leak came from the pump at the point where the motor shaft connected to the pump. Also while you are under there look at the base of the transmission, you should see some oily residue where the transmission fluid is leaking. Hope this helps! if you have any other questions please feel free to comment again. Good Luck!! Mike
Jul 21, 2009 | Whirlpool LSR5132PQ Top Load Washer
Does my belt need replaced?
If it is greasy and not oily, the belt will need to be replaced, there is slight possibility that the bearing seal under drum is leaking oil,
Jul 09, 2009 | Washing Machines
Unable to connect ipod
Reset the radio (it has a processor) by just unplugging the power cord for about 30+ seconds and plugging it back in. If this doesn't solve the problem, try replacing the remote battery (CR2032- can be found almost everywhere batteries are sold) If all else fails, call Bose tech support. The cable you connected has nothing to do with this.
May 09, 2009 | Bose Wave Radio II
Bose  in-ear headphones - Black with black/white cord Logo
570 people viewed this question
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Steve Allison
Steve Allison
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
