Question about Dyson Ball DC24 Bagless Upright Vacuum
The on/off stwich will not stay on. The vacuum turns on but when i release my finger it turns off.
  • 55 Answers
Not sure about the Ball DC24, but ive done this on another type. Anyway here is a video that I hope will help. Have a look around youtube if yours is different.
Posted on Nov 10, 2010
How to get the battery out of the hoover link
The battery itself has a release...
activated by gently lifting.
Run your finger over the top and as you go over the bottom edge you will feel a cavity...GENTLY LIFT WITH INDEX FINGER...
While lifting with the thumb and the rest of your fingers.
(got it?)
Carnac the Magnificent
Mar 19, 2017 | Hoover Vacuums
Vacuum will not stay on
Hi Patriccia,
I'm sorry to hear you're having difficulties with your Dyson's on/off switch. If the switch won't stay down when pressed, please call us free on 1866MYDYSON, or email askdysonUS@dyson.com so we can provide further assistance. We'll look forward to hearing from you.
Kind regards,
Jack
Dyson Online Customer Support
Nov 24, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
THE LIGHTS COMES ON WHEN YOU PUSH THE SWITCH BUT AS SOON AS YOU RELEASE THE LIGHT GOES OFF
Often the switch on a vacuum cleaner is 'Push-to-turn-ON" and "Push-to-Turn-OFF".
It sounds like the switch on your vacuum is broken-- so that it does NOT stay in the pushed position. Is that what it feels like?
If so-- you will need to replace the switch.
Do you want help with that process?
Let us know--
Mack B
Jan 26, 2011 | Vacuums
I have a Dyson vacuum. The vacuum won't stay
My vacuum had this exact same problem, but was out of warranty because it was remanufactured. Thankfully, it's a very quick, five-minute fix.
  1. UNPLUG The Vacuum!
  2. Remove the cannister.
  3. Extend the handle and remove it.
  4. Remove the two torx (T-15) screws behind the power button, where the handle normally stows.
  5. There are four tabs holding the front plate containing the power button on; use your screwdriver to release them.
  6. Gently pull the front plate off.
  7. The switch on the right is the power button. Remove it, try clicking it a few times; if it sticks, great! Replace it and reassemble, otherwise you'll need to replace it.
Jan 09, 2010 | Dyson DC17 Animal Bagless Upright Cyclonic...
The hand held dyson does not appear to charge. does the battery come away from the unit as I can't seem to release it? Would there be any point in buying a new battery as I don't know if this is the...
The battery is located at the bottom of the handle. To release it, press and hold down the button on top of the battery case (it has 3 ridges on it). That releases a catch and you can then slide the battery out to the rear. This can be quite hard work, and you may find a bit of additional leverage from a flat-blade screwdriver is helpful. It's a bit more difficult to answer your question about buying a new battery. The fact that the red light comes on would suggest that your charger is working, so the finger of suspicion does point to the battery, but without testing equipment it's impossible to be sure.
Jan 08, 2010 | Dyson DC16 Root 6 Bagless Handheld...
My Dyson upright suddenly won't stay in the upright position. It appears that a little rubber piece has fallen out of position.
- Stand behind the vacuum cleaner and look at the right-hand side wheel
- Remove the AI PIPE (it has two purple buttons that you push together to lift it up and out - it looks like a Tuba)
- Lay the handle down and look for a black button that will be exposed in front of the square hole
- Stick your index finger and middle finger into the vacant AI Pipe Hole (the square hole)
- Reach over with your thumb and press the black button in front of the square hole
- Whilst pushing the black button, lift your index finger and your middle finger and move the gray plastic piece up (lift the square
hole basically)
- Remove your fingers from the square hole
- Lift the handle and stand your machine back upright again
- Place the AI Pipe back into the square hole
Apr 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Switch Problem
It sound like the switch is loose if you are able take the handle apart and plug the leads back into the switch. be sure to unplugit ffirst
Jan 10, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Bissell Bagless Vacuum cleaner
There is no release, the part is a plastic handle release lever, you can find those at www.hesco.com, the cost is approximately 2.29 each, I have replaced more than 20 of these on the commercial vacuums for my cleaning crew, the part is easily broken and easily replaced. I always have 6 or more on hand.
Turn the vacuum over, remove the bottom plate, with a flat head screw driver punch out the old part. turn the vacuum upright again after the broken part is removed. With the body laying back on a hard surface, carefully push in the new part. Unfortunately, these are plastic, too bad they cannot design a more sturdy part for this.
Apr 10, 2008 | Bissell 3522 PowerForce Bagged Upright...
Dyson Ball DC24 Bagless Upright Vacuum Logo
66 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
