Question about Acer Aspire 5050-3242 Notebook
The cooling fan in my Acer Aspire laptop (bought 1 year ago) stopped working. Can it be replaced or is it part of the motherboard?
  • Acer Master
  • 5,660 Answers
As stated it can be replaced. Might be the pits in finding the replacement fan, though.
Let's take a look at an Acer Aspire 5520 series laptop, as an example,
http://www.insidemylaptop.com/take-apart-acer-aspire-5520-laptop/
Scroll down until you come to the third photo.
Getting to the Cooling Fan in the Acer Aspire 5050 series Notebook PC's, requires a lot more disassembly, however.
The Acer Aspire 5050-3242 Notebook PC, in the category heading, is part of the Acer Aspire 5050 series of Notebook PC's.
This is the Service Manual for the Acer Aspire 5050 series of Notebook PC's,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Go to the second Aspire heading.
The one that begins with Aspire 1200.
Now go down to the 5th line, and scroll across to > 5050.
Left-click on 5050.
This is a PDF file.
The computer you are using now has Adobe Reader on it, which uses PDF files.
[ Although I would recommend upgrading to Adobe Reader 9, if it isn't on your computer ]
After you click on the file > 5050, you won't see anything happening for up to 30 seconds.
Most of the time the first page pops up within 10 seconds, and it requires additional time to fully download the file.
Suggest you let the file download all the way, before looking through it.
Watch the Download Progress bar.
You can save this file to your computer.
This way you can burn a copy to CD for safekeeping, and easy access anytime you wish.
You can also delete from your computer then, to save Harddrive space.
If you do not know how, and wish to, simply post in a Comment.
For further questions on this please post in a Comment.
Regards,
joecoolvette
Posted on Nov 10, 2010
  • joecoolvette
    joecoolvette Nov 10, 2010
    To add:
    1) ALL Power is removed from the laptop before disassembling.
    Remove the AC adapter (Charger) and Battery.
    2) Observe Anti-Static Precautions.
    It would be best if you buy, and wear an ESD wrist strap, and connect the alligator clip to a good ground source.
    (I connect to the metal frame of an empty desktop computer case, for example)
    Your body carries Static electricity.
    Static will fry out (Short Circuit) the hardware components inside a computer.
    You may not see it, or feel it.
    Your computer will. (POOF! No computer)
    Using an ESD wrist strap, and connecting to a good ground source, ensures that Static will not be an issue.
    The average cost is around $3 to $6. An economical one is all you need.
    One example of an ESD wrist strap.
    http://www.amazon.com/Cables-Unlimited-A...
    3) Use a can of compressed air for computers to clean out the inside of the computer. You may find built up areas that require more than just an air blast.
    For these areas you can use Q-tips, and a small fine brush.
    (Make-up brush of some kind?)
    The reason the Cooling Fan quit may be due to four reasons.
    1) The area around the Cooling Fans intake duct must be free of obstructions. There should be a flat surface so the air intake duct is not blocked.
    It states Laptop, but in reality should not be put on one's lap.
    The air intake duct can be blocked by clothing.
    Same for using the laptop directly on a bed, couch, or directly on a carpet floor.
    2) The fan's bearings only have a 'Lifespan' of so much.
    The bearings lubrication dried up, and this caused fan bearing damage.
    3) A can of compressed air for computers was used, and improperly.
    A Cooling Fan is only designed to spin so fast, and spinning it faster than it was designed for, can lead to premature failure of the fan's bearings.
    Short Bursts of air are used to clean a laptop cooling fan.
    Squeeze the trigger in all the way, let go quickly.
    4) Not to slam Acer laptops, but they are a budget laptop. Low quality parts are used to save money.
    This savings is passed on to the consumer, but in reality it costs more in the end.
  • joecoolvette
    joecoolvette Nov 12, 2010
    lucyhill, did you find a replacement fan?
Reset BIOS? how to
With both PC and LAPTOP Motherboards,Pc Motherboards are easier to Wipe Passwords than laptops because of ease of getting to the Jumper on the motherboard normally by the battery on the motherboard.I would suggest looking online for the motherboard manual which should show you where the bios reset jumper is.Laptops are just the same but a lot harder sometimes to find this jumper. Hope this helps
Aug 26, 2014 | Acer Aspire 7720 Notebook PC
Acer Aspire 9815WKHi Graphics Card was getting very hot, also the processor gets extremely hot, the fan is working, but cannot keep this computer cool and this has caused the graphics board to stop...
No it is not normal for the graphics to fail unless the heatsink and fan are so badly clogged.
The cpu will stand temperatures of up to 90 degrees but, it gets the main body of the cooling and the graphics chip does not get as well cooled, what happens is the graphics chip then suffers and the solder "bed" it is fixed by melts and the chip detaches.
You may be lucky and by cleaning out the cooling components get it working, but I suspect the motherboard has been damaged now
Jan 14, 2011 | Acer Aspire 9810-6829 Notebook
My daughter's laptop Acer Aspire 5315-2713 has been experiencing sudden shutdown. I cleaned out vents and replaced cooling fan. Problem persist! I did notice cooling fan never runs. Help! What else can I...
buy your daughters laptop a laptop cooler with built in USB fans i had similiar problems with my wifes hewlett packard compaq cq bought a laptop cooler fixed the problem
(if you replaced the cooling fan why does'nt it run)
hope this helps
Oct 28, 2010 | Acer Aspire 5315 Notebook
My Acer Aspire 5720 wont power up, i have tried it with and without the battery, power goes to the power buttons led and fan for 8-10 seconds and then it cuts out ?
Motherboard problems. It's an Acer and they're notorious for having these exact issues about one year to two years after being bought.
Jul 26, 2010 | Acer Aspire 5720-6661 Notebook PC
CPU Coolin Fan
The problem is from the power source recognizing the fan.If you don't have a specialist to find the wrong piece,replace the motherboard.
May 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
Acer Aspire 5630 Laptop Unexpectedly Shuts Down
r u allowing the fan to intake air to cool down cooldown
Apr 28, 2010 | Acer Aspire 5630 Notebook
Hi i've been using this laptop for over a year
If you can connect your VGA output to a regular desktop monitor and it works during the startup process, then it is probably you LCD screen. There is no way to know for sure that it is the backlight unless you replace it.
Jul 16, 2009 | Acer Aspire 6920 Notebook PC
Laptop Overheating
i have read lot of same type of problems,with acer,if it is under warranty send it before end, there is fee of 449.00 for out of warranty notebooks. my 5100's have problems,very unhappy! with acer good-luck!
Jun 21, 2008 | Acer Aspire 5100 Notebook
ACER 5610Z
it could be bad motherboard.
but try to reseat memory or move memory to another slot, it could be bad ram slot.
if this don't work, it motherboard/cpu problem. most of the time it's motherboard.
Mar 22, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 5050-3242 Notebook Logo
574 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
