Question about Panasonic Workio DP-2500E Copier
Check the upper limit sensors if they are moving nicely and freely check out put or simply swap the sensor with other tray. "Or try with dust blower/dust buster can" Good luck
Posted on Jun 17, 2008
Add paper/add paper try 1/try 2
Is the error stating to add paper? If so, go ahead and add paper to the trays necessary.
Jul 23, 2014 | Panasonic DP-8020E Multifunction...
Our Panasonic WORKiO 1520 copier is giving us the error message
try and place the paper back on the tray properly for the censor to pick it i encounter this problem everyday but i just reset the paper.
Oct 12, 2012 | Panasonic WORKiO DP-1520P All-In-One Laser...
Tell me please hp laserjet printer 2420 paper tray setting
    1. Remove the packing material from the printer.
      1. Remove the all orange tape from the outside of the printer.
    1. Load all paper trays.
      1. Pull the paper trays completely out of the printer.
    2. Press the blue tab on the rear paper length guide and adjust the rear guide so that the pointer matches the size of the paper to be loaded. c00318778.gif
    3. Move the side width guides outward to match the desired paper size. c00318779.gif
    4. Add the media to the paper trays, make sure that it is flat in the tray at all four corners. Keep the media below the height tabs on the sides and rear of the tray. Push down on the metal lift plate to lock it in place. c00318780.gif
    6. Install the print cartridge.
      1. Remove the print cartridge from the packaging.
    7. Rock the print cartridge back and forth several times to "mix" the toner. c00318783.gif
    8. Pull the sealing tape from the end of the print cartridge to remove the entire length of the tape. c00318784.gif
    12. Connect the LAN cable (optional). (HP LaserJet 2420n, 2420dn, 2430tn, and 2430dtn models only) c00318788.gif
    Jan 13, 2011 | HP LaserJet 2420 Printer
    My printer says "no paper",
    try adding paper to any handfeed trays that the printer may have. check the print que to see if that gives you any information
    Oct 28, 2010 | Dell Office Equipment & Supplies
    How do I have printer switch from empty paper tray 1 to the full 550 paper tray 2
    Make sure the paper type and size in both trays are the same. If you are using letter size for both trays, make sure the settings in tray 1 and 2 are the same. If the settings are the same and it still fails to grab from the full tray change the engine settings in diag mode. Hope this helps but if you need more assistance, leave a comment and I'll get back to it. Thanks.
    May 10, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
    Hi. You need to do tray linking. When one linked tray is empty, paper feeds from the next linked tray. The size and type settings for all trays must be set from the Paper Menu. To set the paper type or size:
    1. On the home screen, touch Menu button
    2. Touch Paper Menu
    3. Touch Paper Size/Type.
    Note: To link the multipurpose feeder, Configure MP must be set to Cassette in order for MP Feeder Size or MP
    Feeder Type to appear as a menu item.
    4. Touch the right or left arrows to select the same size paper from all paper sources to be linked.
    5. Touch the right or left arrows to select the same type paper from all paper sources to be linked.
    Note: When the Size and Type settings are the same for any trays, the trays are automatically linked.
    6. Touch Submit.
    Submitting changes appears.
    7. Touch Home to return to the home screen.
    Hope this helps.
    Mar 16, 2010 | Lexmark X464DE Mono Laser MFP, 38ppm A4...
    Mp780 - Paper attempts to feed and fails Message: Load paper
    Your paper feed source is wrong .Go to the printers control panel and change the feed source.
    If all you do is 8.5X11 you can go into the maintenance tab and choose it to automatically change paper trays by selectin auto continuous feed.Make sure paper is in both trays of the same type and size.You will hear the printer try and grab the paper three times then it will automatically switch to the next tray.
    Jun 10, 2009 | Canon PIXMA MP780 All-In-One InkJet...
    Epson stylus photo 950 printer flashing lights
    I had the same Problem and checked the solution:
    This is a Printer Maintenance request.
    Ink Overflow -
    you sould change the waste ink pads under the printer mechanic.
    Sep 28, 2008 | Epson Stylus Photo 950 InkJet Printer
    Copier wont print
    Your unit is fine. Check the paper setting in your word processor and you will find that you are selecting either: (1) special paper type or (2) special paper size.
    Sep 24, 2007 | Sharp AR-168D Copier
    Panasonic Workio DP-2500E Copier Logo
    112 people viewed this question
    Top Panasonic Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Mitch S
    Mitch S
    Level 1 Expert
    Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
