Question about Hunter Heating & Cooling
I bought a Hunter 44155C programmable thermostat to replace my Carrier non-programmable one. The wiring on the carrier is: W- white wire O- no wire G- green wire R- red wire C- blue wire Y- yellow wire Where do I put each of these wires on the Hunter? My available locations are: G RC RH Y/O W/B Y1 Thanks, David Martin
  • 455 Answers
Hello,You need RH/RCjumper together=red wire...C=blue wire...G=green wire...Y=yellow wire...W=white wire...O/B unused for reversing valve for heat pump.Hope that helps. : )
Posted on Nov 10, 2010
  • randi13 Aug 05, 2011
    That didn't answer the question. You repeated what they already have.
I am replacing a White-Rodgers thermostat with a Hunter 44155C and dont know where to connect the wires. I have white, red, green, blue, and yellow wires and none are labeled as to what they are.
The Yellow wire is for cooling, the white is for heating, the red is for power, the green is for blower fan, the blue is your common wire, all you should have to do is color code the wires to the thermostat. The thermostat should have the colors labeled R,W1,G,Y,B or C for common if it's wired correctly at the Air Handler or evaporator. The blue wire should go to B, or C.
May 28, 2011 | Hunter Fan Company 5/1/1 Programmable...
Unable to get ac compressor to start
HI,
you may get a pdf download of the manual form this site Programmable thermostats at discount prices at hunter-thermostats.com.
they may have the model you require .
Goodluck,
Please don't forget to rate the solution
Apr 23, 2008 | Hunter Fan Company 5/1/1 Programmable...
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
Changing a White-Rodgers 1F56-444 to a Hunter 44155c digital.
The W- terminal is for the HEAT RELAY.
Connect the brown and white wire to the WB terminal which is heat relay of the Hunter thermostat.
Aug 09, 2009 | Hunter Fan Company 5/1/1 Programmable...
Trouble Installing Hunter Brand Thermostat
on the back of the packaging for the HUNTER MODEL 44155C it states that it is not compatible with heat pumps
Mar 01, 2009 | Honeywell Programmable Thermostat Heater
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Need help !!
have you tried there web site for the wireing instructions or manual to installing it.
riz.
Feb 17, 2008 | Hunter Fan Company 5/1/1 Programmable...
Thermostat
What were each wire connected to on the white rodgers? The connectors on the white rodgers should have markings. Tell me this and I can tell you how to wire your new stat. This hunter will not work with multi stage heat pumps..so I need to know what was connected to what on the white rodgers to know what type of unit. Thanks Kevin
Dec 20, 2007 | Hunter Fan Company 5/1/1 Programmable...
Installing a Programable Thermostat
give me the wire colors from the white rodgers and how they are connect to the white rodgers .. The white rodgers should be marked on the back where the wires connect. I can then tell you where to hook each wire to on the hunter.
Heating & Cooling Logo
317 people viewed this question
Top Hunter Heating & Cooling Experts
1STHVACMAN
Jay Finke
Jay Finke
Are you a Hunter Heating and Cooling Expert? Answer questions, earn points and help others
