Question about Proxim 4954-BSUR (4954-BSUR-US) Wireless Access Point
I am having an issue with the a proxim 4954 R SU connecting to an existing BSU. The existing SU connect just fine but the new SU that we have configured exactly the same is having an issue connecting. The error message is cannot obtain ARS from BSU Any ideas?
2 Suggested Answers
  • 4 Answers
SOURCE: Reset AP-700 failed
Simple solution, firstly do not press the reset button to long as it will erase all software, or you will have to do this the hard way. google the software called ScanTool run that from either ethernet or wireless, this tool shows you the AP-700's ip, mac, and name (some techs run these AP's coadjacent so it shows the name as well). You can change the ip of the AP-700 from here most of the time with the proper pass, then you should be able to connect to it regardless. if this dont help ... Proxim/Support/AP700 you will find more of an in depth approach of these things there.
Posted on Dec 01, 2008
How do you do wire up for a new light in the loft and where do you get connection from
If you have an existing light where you want a new fixture then you can just use those wires. If you do not have power to the loft then you need to connect onto another circuit (wall outlet or a junction box). You need to make sure that the existing circuit that you connect onto can handle another load on it. If you cannot connect in then you need to do a home run to your breaker box. If you do that you need to see if you have an open port for a new circuit breaker. As far as running the conduit and wire that is more than fine to do yourself. As far as the final connections I would not save my money there. Have an electrician come in and do it for you.
Nov 29, 2014 | Dryers
Windows 7 no detecta mi Ipod A1236, al ingresar a la busqueda de los dispositivos Windows me muestra el Ipod con un error que dice "Unknown Divice" no funciona correctamente, ya trate de...
iPhone iPad or iPod not recognized in iTunes for Windows
Si conecta su dispositivo a su computadora con un cable USB e iTunes no reconoce su iPhone, iPad o iPod, obtenga ayuda.
Cuando iTunes en su computadora no reconoce su dispositivo conectado, es posible que vea un error desconocido o un error "0xE". Si lo hace, siga estos pasos e intente conectar su dispositivo nuevamente despu?s de cada paso:
Aseg?rese de tener la ?ltima versi?n de iTunes que funcione con su computadora.
Compruebe que tiene el ?ltimo software en su Mac o PC con Windows.
Aseg?rese de que su dispositivo est? encendido.
Si ve una alerta de Confianza en esta computadora, desbloquee su dispositivo y toque Confiar.
Desconecte todos los accesorios USB de su computadora, excepto su dispositivo. Pruebe cada puerto USB para ver si funciona. Luego prueba con un cable USB Apple diferente.
Reinicie su computadora y iPhone, iPad o iPod.
Intente conectar su dispositivo a otra computadora. Si tiene el mismo problema en otra computadora, comun?quese con el Soporte de Apple.
If you connect your device to your computer with a USB cable and iTunes doesn't recognize your iPhone, iPad, or iPod, get help. When iTunes on your computer doesn't recognize your connected device, you might see an unknown error or an "0xE" error. If you do, follow these steps and try to connect your device again after each step:
  1. Make sure that you have the latest version of iTunes that works with your computer.
  2. Check that you have the latest software on your Mac or Windows PC.
  3. Make sure that your device is turned on.
  4. If you see a Trust this Computer alert, unlock your device and tap Trust.
  5. Unplug all USB accessories from your computer except for your device. Try each USB port to see if one works. Then try a different Apple USB cable.
  6. Restart your computer and iPhone, iPad, or iPod.
  7. Try connecting your device to another computer. If you have the same issue on another computer, contact Apple Support.
Feb 14, 2018 | Car Audio & Video
Nokia 6310i turns itself off
TRY REPLACING A NEW BATTERY .IF U FEEL THERE IS AN ISSUE WITH AN EXISTING BATTERY. ELSE GET THE FIRMWARE REINSTALLED USING NOKIA PC SUITE DATA CABLE AND MUST HAVE A HIGH SPEED INTERNET.
Feb 24, 2010 | Cell Phones
I can not connect new laptop to existing personal wireless networ
unplug router for 10 seconds and plug back in. Then try. If needed, use network setup wizard.
You can also renew your pc's ip address by going to start menu, then run. Then type ipconfig/ release then type ipconfing /renew and everything should be fine.
Nov 09, 2009 | NetGear WG602 802.11g/b Wireless Access...
Reset AP-700 failed
Oct 30, 2008 | Proxim Orinoco Ap-700 802.11a, 802.11g/b...
I have a problem with my new internal CD/DVD burner. I have installed it per the instructions, all of the cables are connected, the tray opens and closes fine; but the computer does not acknowledge its...
The connection on the motherboard may be bad, if the harddrive cable has two connection try connecting the cd drive on the second connection. if it works you connection on the motherboard is bad
coastal-connection.com
Aug 02, 2008 | Computers & Internet
Technics su-a808 amp & sh-ge70 graphic equaliser.
connect your media source(dvd-cd player)to equalizer in-connect equalizer out to amplifier line in-or aux in-connect amplifier out to your loudspeaker.
Jun 24, 2008 | Audio Players & Recorders
Trying to connect new HP Blackbird PC
try updateing the system pc 1st all latest drivers video ect windows update ok
Feb 04, 2008 | Sharp Aquos LC-45GD6U 45 in. LCD HDTV
Wi-fi problem
I went to the Proxim website (www.proxim.com) to see if I could find info on the card, but Proxim looks like they make you register before you can get any information.
You probably just need a Vista driver. Go to the Proxim site, register, and see if one is available.
Good luck.
Dec 09, 2007 | Proxim ORiNOCO Gold 802.11b Wireless...
Proxim 4954-BSUR (4954-BSUR-US) Wireless Access Point Logo
62 people viewed this question
Top Proxim Computers & Internet Experts
Prashant M
Prashant M
David Gust
Don Eagan
Are you a Proxim Computer and Internet Expert? Answer questions, earn points and help others
