Question about Sony KDL32LL150 315 in HDTV TV
I have a Sony flat screen lcd tv. When I turn it on,there is distortion on the screen. What is the problem?
    Genius:
  • 1,112 Answers
HI:
This can be cause buy one or two problems. First check all connections to the television, if possible disconntect everything from the TV, and check with just TV Signal.
If there are lines in picture then you may have a bad T-CON board or MAIN board.
The other problem area is bad capacitors on the Power supply board causing low voltage to the main board.
Try opening the unit and with power off disconnect any connectors and reconnect them, this will include the LVDS Cable that runs from the main to the T_CON board which is usually hidden behind a metal shield towards the top of the unit. Sometimes doing this will correct problems.
But my best answer is check the power supply for leaky capacitors or ones where there tops are buldging.
Posted on Nov 10, 2010
Lines going through it and is very distorted
Search Results
    Troubleshooting Distorted Pictures - Stereo & Video Repair ...
    www.stereoandvideorepairco.com/.../DistortedPictureTroubleshooting.ht...
    Usually, this occurs on CRT projection TV's, and occasionally on CRT ... Dark, light, or colored bars can be seen rising slowly through the picture, ... Known as "hum bars" or "common-mode noise," these result from AC power line hum coming ...
    Flat Screen TV Has Lines Going Through Screen - Possible ...
    removeandreplace.com/.../flat-screen-tv-has-lines-going-through-screen-...
    Jun 17, 2015 - Flat Screen TV Has Lines Going Through Screen - Possible Bad ...inch LCD TV which is showing lines (vertically) and getting extremely hot. ..... If you leave the projection TV on for a certain amount of time does it ..... If so the plasma gas is most likely causing the screen to become distorted or color issues.
    Distorted Colors in an LCD Projector ' Business ...
    yourbusiness.azcentral.com/distorted-colors-lcd-projector-8597.html
Feb 08, 2016 | Televison & Video
Why does picture have lines of different colors?
Common easy LCD TV fix: bad picture screen rainbow colors
? 4:04
https://www.youtube.com/watch?v=KWIWeESmXC0
Aug 10, 2014 - Uploaded by Tampatec
Common easy lcd tv service repair fix, TV's distorted rainbowpicture screen fixed by ... Common easy LCD TV fix: bad picture screen rainbow colors ... Need to report the video? ... Sanyo LCD with Distorted Half Picture Lines Waves Distortion Distorted ...Duration: 11:36. by Do It With Dave 316,733 views.
LCD Display Symptoms and causes. - YouTube
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Mar 1, 2011 - Uploaded by Grants Pass TV Repair
With LCD TVs you can have the same display problems fordifferent ... Fix for Samsung lcd TV colour display problem - Duration: 1:26. by alwaysafix 462,823 views. 1:26. Sanyo LCD with Distorted Half Picture Lines Waves Distortion ... HOW TO FIX LED TV VERTICAL LINES ON SCREEN 55" MODEL LG ...
How To Fix A Broken Flat Screen LCD LED TV With Lines or ...
Dec 11, 2015 | Sharp Televison & Video
Bottom half of Sony Bravia TV screen has color distortion
Check for loose contacts in power outlet, RC cable, jack and socket.
In order to ensure, it is not caused by the input device, connect a DVD player and see.
Aug 22, 2012 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
About 3 yrs old. Picture is distorted for about 1/2 hour until tv warms up. Now has horizontal lines going through the picture and stays distorted on the right side of the screen.
This tv problems it is alway the board that call the T-CON decodering board it is dying.This T-CON decodering board sit in the middle at the bottom of the tv LCD screen panel.This T-CON decodering board decodes all the tv picture dots pixels before it go into the tv LCD screen panel itself.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish T-CON decodering board for the replacement.
May 09, 2011 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
Distortion and horizontl lines
If same lines/ distortion appears in every input of tv then it is lcd panel (screen) problem as question shows it is Sony KDL-32ML130 lcd tv.
Can you please post picture of tv screen to show distortion/ lines to diagnose it correctly?
Thanks.
Nov 16, 2010 | Sony Bravia KDL-32ML130 32 in. LCD TV
The top half of my Sony Bravia 32" screen plays as
I'm sorry, it sounds problem with lcd panel (screen) that is defective and causing lower half distorted image. If tv is under warranty then call number written on warranty documents for warranty cover or lcd panel (screen) replacement would cost you approx 80% of new tv price.
Hope these info will help you.
Thanks.
Nov 09, 2010 | Sony BRAVIA KDL-40S2010 40 in. LCD...
AKAI LCT2662N screen problems -distorted
that sounds like your LCD controller, since the LCD screen is so big, they will "split" the screen into 2 smaller screens, otherwise it would be so outrageously expensive to have one big massive lcd controller. Your lcd controller is most likely a two-in-one card though, meaning that there are 2 controllers on one board. You'll more than likely need a new controller card for your tv.
Feb 20, 2008 | Akai LCT2660 26 in. HD-Ready LCD...
Sony KDL32LL150 315 in HDTV TV Logo
278 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
