Question about Behringer Pmp3000 16 Channel Audio Mixer
There is no sounds coming out of the left channel
  • Behringer Master
  • 5,603 Answers
Assuming your PAN controls are centered at 12 o'clock, likely one of the power amps has failed. There is a design weakness in insulation on the circuit board of channel A that often fries three to 5 transistors and a Zener diode and sometimes a metering resistor. The board gets charred and requires a lot of work to carve out the cancer and restore the insulation and circuit traces. If the problem persists and one continues to use it, sometimes further arcing will destroy the power supply as well.
Posted on Nov 10, 2010
  • john
    john Dec 29, 2013
    thanks, great answer
How to connect it ?
Instructions
    • 1
      Place your mixer in a location that will allow you to hear the sound coming from the speakers clearly. The best placement is opposite the speakers, centered between the left and right pair. Connect the power supply to your mixer.
    • 2
      Connect the female end of an XLR cable to a microphone. Run the other end of the cable to your mixing board. Plug the male end into the "Mic" port of an open channel. These channels provide the preamps that will shape the sound characteristics of the microphone signal, processing them for output. Repeat the process for each microphone in your rig
    • 3
      Connect one end of a balanced 1/4-inch cable to the left channel jack labeled "L" found on the "Main Out" panel. Connect another cable to the right channel jack with the "R" label. Connect the opposite end of each cable to the matching left and right inputs on you amplifier.
    • 4
      Power on your mixer and amplifier. Test each microphone connected to the mixer for output.
    • 5
      Adjust the volume of each microphone channel to create a balanced mix. Use the "EQ" knobs to shape the tone and cut out frequencies that are causing squeal and feedback.
    • Audi Performance Chip
Jun 19, 2012 | Behringer Xenyx 502 Audio Live Music Mixer...
I have my Onyx Blackjack plugged into my computer but the sound is only playing and recording through the left channel, with or without headphones. Is there anyway I can fix this?
You haven't told us where the "sound" is coming from... If you are ONLY plugged in one channel that is all that will be recorded. We can't guess at how you are setup. Please provide an adequate description. If you only have a mono signal to start with, then get a WYE connector and jumper to the second channel.
Sep 05, 2011 | Mackie Onyx Blackjack 2x2 Recording...
Sound is only coming out of the left headphone when I play
Is this the same on all channels?
Check your 3.5 -> 1/4 adapter is stereo (2 black bands on the connector) and check you havent got it set to mono.
Try with different headphones too.
Hope that helps!
Jul 05, 2011 | Live Wire Solutions HA04 4 Channel...
Sp250 right outout seems to have broken and as a result there is no sound coming from the speakers on the keyboard or through the PA. If we use the left output through the PA - it works, Could you advise...
Check if headphone jack also has right channel dead... If headphones work on both channels, switch contacts on headphone jack MIGHT be the problem.
Jan 17, 2011 | Korg SP-250
How can i setup mu xenyx 802 with my pc? i also hve fca202...
You can do it one of two ways when coupled with the FCA202. First, You can just come out of the main outs on the 802 via 1/4 in to the 202s 1/L in and 2/R in. Second, you could do two separate channels (ie. Vocal channel and Guitar Channel) using the L/R out on the 802. Use the pan knob to send the instrument to the selected channel. So, If your Guitar is on channel 1 pan hard left and you will only get it out of the left channel sending to channel 1 of the 202, and your vocal is in channel 2 pan hard right and you will only get it out of the left channel sending to channel 2 on the 202. Good Luck, Cody J.
Dec 17, 2010 | Behringer Xenyx 802 8-input 2-bus Mixer W/...
Suddenly the monitor one output jack has no sound. If I turn the Monitor one slider all the way up I can hear a very low sound with distortion. The monitor output works fine.
Make sure the appropriate channel rotary knob MON1 knob is turned up for the channels you want into MON1. ALSO test other channels if they can be sent to MON1. The MON jacks are TRS with the tip as the hot and the sleeve as resistor to ground.
Hopefully you have used good practice and have ALWAYS powered whatever you are driving from the MON1 out from the same receptacle as the PMP5000. If not, ground bounce MAY have destroyed the driver in thee PMP5000. They USUALLY don't tell you these things in the user manuals, so it is up to us electricaal engineers to educate.
FIRST plug in a set of headphones and see if sound comes out (it will only be one side and fairly low volume, usually the left). If it does, then cabling and whatever amp you have for the MON1 has a problem. I have schematics and can help you troubleshoot a bit.
Also PLEASE read the tip I have posted on here about a grounding hazard of the A channel when using Speakon to 1/4 inch cables.
Nov 07, 2010 | Behringer Europower Pmp5000 Powered Mixer...
I'm using an external reverb (T.C. Electronics Nova) through the effects loop and I can only get verb out of one channel (left I think) and in fact it seems that the "stereo" section (knobs etc.) have no...
The external effects when used would require an effect processor with left and right channels. You need four cables total for the effects... the two channels out to the effect unit and two cables to bring it back to the power amps.
Remember to use your pan controls if you want certain inputs to go more to either the left or right outputs.
Oct 15, 2009 | Fender Passport Deluxe 500watt Sound...
Sound only coming out opf left channel
Probably there are dirty contacts inside the assign switch, also it could be a bad solder contact on the switch or there around.
The switch can either be removed and cleaned or replaced.
Cleaning is a bit delicate procedure, but can actually be done, you need to take the switch apart, taking care not to damage any of the parts, then you need to clean the inner contacts and the contact making clamps with some fine sandpaper.
Be sure to put everything back together as it was otherwise the switch may not work properly or it may not work at all (be gentle with the contact making clamps, they can easily be damaged / squashed).
It could also be a problem with faders or preamps, but i would take a look at the switch first.
regards
3rq8 (Triarcuate)
Jul 09, 2009 | Vestax Pmc 280 DJ Mixer
I have the 2442 fx behringer ''XENYX'' mixing console, and while trying to operate channels 13/14 and 15/16 (these are both stereo channels with mono capabilities, and do not have XLR inputs) I only get...
Check you assign buttons and bottom (three black square buttons) and play with them. It sounds as if you are not sending to that side. You should use mono cables into left and right. I set pan on left all the way left and right, all the way right. Hope this helps.
Jul 06, 2009 | Music
Behringer djx700 pro 5 channel mixer
Always check your cables and connectors on them to make sure the cable is good and the connectors are not loose. This sounds like a bad cable or connection between the line output of your mixer and input to your stereo.
Apr 23, 2009 | Behringer DJx700 5-Channel Pro DJ Mixer...
Behringer Pmp3000 16 Channel Audio Mixer Logo
59 people viewed this question
Top Behringer Music Experts
Ben Armstrong
Ric Weide
Ric Weide
Level 1 Expert
Are you a Behringer Music Expert? Answer questions, earn points and help others
