27 inch toshiba tube set 10 years old picture normal brightness then dims after playing awhile after a period of time picturererturns to normal
  • 10,594 Answers
Problem seems with screen volts (1000V) that drives G2 of picture tube to accelerate electrons emission that creates brightness.
Usually high value resistor nearby G2 found defective in such kind of problem, check screen volts line that goes to G2 pin of picture tube as G2 should have 600 to 800 DC volts for normal function.
Hope these info will help you if you have knowledge about tv.
Let me know if there is additional question.
Thanks.
Posted on Nov 10, 2010
MY TV PICTURE HAS GONE A LITTLE DARKER AND ADJUSTING BRIGHT, CONTRAST, COLOR,ETC. DOES NOT HELP
How long u have this RCA analoge tv?Around 10 years or more and used it like about 5 or 6 hrs everydays?Yes,than ur tv it is losing CRT tube radiation cohetion.As times go bye years in years out the tv CRT-(tv tube) radiation will slowly dying out,Tv actual pictures will lost some of it luster and it brightnesses to the tv auctual pictures.Brightnesses of CRT tube will get darker and darker until the tv actual pictures barely it is watchable anymore.Contrast,Brightness and Colors adjusting more will help some.But u have to take this tv aparts and take a Flat scerw driver turn up a little bit more of the tv HV-(high voltage) SCREEN button on the FBT-(flyback transformer) to make any big differences of the CRT tube brightnesses.The FBT-(flyback tranformer) is the big block of plastic with a red wire with a black cap hook up to the tv CRT-(tv tube).This adjustment on of the FBT,HV-SCREEN button will help the tv CRT-(tv tube) last another year or two.
Aug 16, 2011 | RCA TruFlat 27F520T 27" TV
Toshiba CF19F22 TV screen too dim.
It looks like the CRT tube on your TV came at the end of its days, if the tv is 15 years old or so this can be normal.
It may not be woth repairing.
Sep 14, 2008 | Toshiba CF19F22 19" TV
The picture on my Toshiba 65H84 - 65 Inch Theaterwide HD Projection Television is going dark. Is there a bulb that I can replace? If so, how?
This model 65H84 is a rear projection type with three picture tubes. And if I am not mistaken is around 10 years old. So, if it is at least 10 years old then the picture tubes are getting weak and burned out, therefore not producing a bright enough picture. Typical with rear projection with age on them.
Jun 28, 2011 | Televison & Video
Stand by timer light on the front of thr TV is blinking, how do I shut it off?
Sony TV's use auto Kine bias a very old term meaning Kinescope or Picture Tube.
When your picture tube is up to full output (approx 30 seconds) the set will click and perform as normal.
If not the tube you see the picture on is not up and running in any one or all colors (RGB) or something else has not started.
Service or replacement of a 10 year old set may be what's next.
Sep 23, 2010 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Rear projection tv picture quality loss
most of these sets have 3 lens for the three picture tubes inside and also a mirror---if it has never had the lens cleaned they could be dusty and this will diminish the brightness and clarity of your picture---if real dirty the picture will look washed out------most of these sets you can remove the back cover(unplug set first) and gain access to the lens ; clean them with a lens cloth or a paper towel with glass cleaner.
Aug 16, 2009 | Televison & Video
Extremely long warm up time 25 minutes. ok once it comes on.
Just a shot in the dark- I think your main projection lamp is going bad- If the set is more than a year or 2 old it can happen. Unfortunately they are a little expensive.
How is the brightness level after it warms up??
May 30, 2009 | Audiovox FPE2706 27 in. LCD Television
Is my picture tube going?
Hi there yes this is a common problem with old tube tv's and yes eventually stuff seems to break down there is not alot you can really do about it to be honest ...my suggestion is that this is lifes way of saying upgrade ...this tv has done well ....if your looking to upgrade i would suggest going to a Samsung LA26C450 as a replacement television or if you are not so much a fan then a KLV26BX300 as a new option ,
Cheers
Nov 04, 2008 | Samsung TXK2754 27" TV
Toshiba 36A42 TV. Dim Picture
Check the "screen" control on the flyback (lower knob) its easy to hit moving a board around. Try to adjust back to its original setting. Look for where the dust is, it should be on top. Or any marks might help. Other wise adjust slowly, back off if any retrace lines appear, with user settings at there normal settings.
Oct 27, 2007 | Toshiba 27AF42 27" TV
Picture is dark
Does not seem like a bad tube alone. Could also be that the Video output Transistors Supply Filter capacitor having dried out. It is a 100mfd 160V capacitor, which on replacement will improve the brightness of the immage. And yes, you could also try increasing the heater voltage (Filament Voltage)of the Pictuire tube, this will definitely increase brightness, but will reduce the life of the Picture tube. You gotta think - 10 year old TV, should I repair or exchange and get a new one???
Mar 03, 2007 | Zenith Z27X22D 27" TV
Televison & Video Logo
20 people viewed this question
Top Televison & Video Experts
