Question about Ricoh Aficio 250 Copier
Replacing toner Hi, I've recently purchased a used Ricoh, Aficio 250. The toner light appeared so I proceeded to change the toner. I shook the toner, cleaned out the area with air cleaner and set the toner cartridge in the area the other cartridge was. Now, the copies are so light you can hardly see them. I've tried unplugging the copying machine, taking everything out and cleaning it with the air cleaner, reviewing my copy reference, but nothing is working. Any ideas????
    Problem Solver:
Check the developer.
Posted on Jun 19, 2008
Add toner see instructions in front cover to replace toner
Hi
You say you have checked the toner and there is "enough inside", I don't know how you can check this and the error suggests that the cartridge needs replacing. Have you tried a new cartridge ? This is the first step.
Is the cartridge you get the error with a Ricoh cartridge or a compatible. If compatible this could be the cause of your error.
Cheers
Dec 06, 2014 | Ricoh Aficio mp2000 Copier Machine
We have a Ricoh Aficio CL3500N and are getting an error stating: "Used toner is almost full." No manual to refer to. Thank you!!
Hi there, You can just empty the waste toner bottle. here is what you need to do. Here is also a manual for your machine http://support.ricoh.com/bb_v1oi/html/oi/re/model/cl3500/cl3500en.htm Detailed instructions on cleaning the Waste toner bottle on Page 32 of the Maintenance Guide. Instead of replacing just empty it. Just be careful as the toner is toxic so you can also vacuum the toner out of the Waste Toner Bottle.
Regards,
Jul 27, 2011 | Ricoh Aficio CL3500N Laser Printer
Ive recently purchased a RICOH Aficio Super 180 G3...used.
press the "user tools" botton, then select "fax option",than "program fax information".You can change fax header there. "Time and Date" usually in "System" submenu.
Sep 10, 2009 | Ricoh Office Equipment & Supplies
Ricoh 250 code sc 320 polygon motor. How hard is it to change?
Hello sir; It is easy to replace it, the laser unit right under the toner unit remove the cover pull out laser unit the polygon motor right in there.
Sep 10, 2009 | Ricoh Aficio 250 Copier
Ricoh nrg mp 1600 Aficio copier/scanner/printer
MP 1600L copier/printer produces print-outs with small toner dots spread over the paper. How can I solve this problem?
Nov 07, 2008 | Ricoh Aficio 250 Copier
Toner problem
R u using gen OEM toners?
Dec 28, 2007 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio 250 Copier Logo
194 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
