Question about Intel D845GVSR Motherboard
Ma cpu shows it is ok, I mean motherboard is running but the monitor remains black....monitor shows it is unplugged while I unplagged the wire connect agp with monitor...But when it is connected it just dont response... Please help me out..it is ma little bros computer and he is really upset with it...Thanks
    Guru:
  • 254 Answers
Hi!
if your cpu system is okey and there is no display in your monitor, try another monitor and if still no display check you video card, if so replace it with external video card.
thanks!!!
hope it helps!!!!
Posted on Nov 10, 2010
Monitor keeps shuting down
what do you mean by "computer starts"????? plz write full detail. first remove your monitor cable from your cpu cabinet. if you are able to see "no signal" message on screen then your monitor is working. if you aren't seeing anything on your screen then there is some problem with your monitor. there also may be problem with your VGA connection (VGA or D-Sub wire). remove and reconnect this wire from both end. first reconnect it from your monitor and then from your video card. if it dosen't fix then you have to check that all led's are glowing on your cpu cabinet or not. if only power led is glowing and other led's always remains off, then there may be problem with your video card or ram or hdd. first open your pc case, then if you have video card, then remove it and put it again. reconnect your hdd sata wire. remove your ram and place it again. if now also not showing anything on your screen, then there is problem with your motherboard bios.
Apr 10, 2013 | Computers & Internet
Hp pavilion slimline x3507c pc. when I boot up the monitor remains in standby mode. I have already determined that the problem is in the computer not the monitor. The power supply is good, the fans run,...
very simple bring a new AGP card and plug in it on your pc and plug the monitor pin in new agp now start your computer . monitor will turned on.
if the monitor is not turned on its mean your have problem in your ram or mother board for that pluged out your all rams from your pc and start your computer if cpu ring a beep its mean you have ram problem and the mother board is ok but if you cant hear any beep its mean mother board's problem ram is ok.
Jul 16, 2011 | HP Pavilion Slimline s3700f PC Desktop
Motherbord run but not dishplay
MY DEAR FRIEND
CAN you tell me the what is the display problem
OK
Apr 11, 2011 | Intel Motherboard
No input signal
that is the problem of cpu not a monitor to confirm disconnect signal cable and power on. monitor will show "no signal check signal cable" it means that monitor is ok and fault lies in cpu .then open the cpu and disconnect ram and listen the beep. contineus beep should be heard then ram is faulty replace it. if no beep heard then motherboard is faulty .
Mar 08, 2010 | HP vs17
Green light is not on in front of CPU. Monitor shows nothing!
ok memeory problem
try another chip and see..
Nov 14, 2009 | Intel Motherboard
Intel dg31pr mother board why dont show display?
First check your num lock led if it on and off when you press num lock key then your cpu is ok.
Then therer is issue with monitor to cpu loose connection
or
Screen resolution problem.
For that when you power up press F8 key then enter in enable vga mode.then go to control panel and dispaly then settings then change screeen resolution to 1024*768 then apply and ok.
Aslo reconnect connection from monitor to cpu vga port.
Also check in bios some times your harddisk is not detected proeprly.
If problem still remains open cpu cabinet and reconnect data cable and power cable to harddisk.
Refix RAM memory.
Pull cmos cell for 15 minutes then check.
Thanks for using fixya.
Pls rate solution if it help you .
Jul 18, 2009 | Intel DG31PR Motherboard
Black out screen,
Please follow this steps :
1. Unplug Monitor from CPU and check whether monitor sceen is givining any messages or not ?
2. If monitor is ok, then please remove RAM module from CPU.
3. After removing RAM stat the computer and check whether Beep sound is comming from Mother Board or not.
4. If above steps is not able to solved ur problem then just RESET BIOS
May 15, 2009 | Intel Motherboard, G31 Express, Core 2...
My motherboard P4V533-MX has no display
Check if any pin is bent of the keyboard PS2 connector. Download the graphics driver from : http://support.asus.com/download/download.aspx?SLanguage=en-us. However if your monitor should show its pwer-on led as blinking and on removal from the CPU the Display will indicate NO VIDEO SIGNAL RECEIVED. That will prove that the monitor is OK. Also if any key remains depressed on the keyboard will also result in no display. Use another working keyboard to check!!!............sodeep
Jan 29, 2009 | ASUS S478 VIA P4V533-MX Motherboard
No display on monitor but cpu is running
The main problem is in the RAM or MEMORY CARD, just detach it and place it back or on another slot beside it.... if this dont work, buy a new memory card. but this usually works
Oct 26, 2008 | Asrock P4I45GV R5 Motherboard
Screen remains blank when starting up, K7S41 motherboard,
Unplug the data cable of your monitor and using a tester, check if it is carrying some electric current. If the tester doesn't show any current, try touching the pins of the data cable to make sure it doesn't give a shock on touch (do this on your own risk). If it does give some shock, you need to properly earth the monitor. So, earthing the monitor MAY solve the problem.
Sep 09, 2008 | Asrock K7S41 Motherboard
Intel D845GVSR Motherboard Logo
42 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
Joe Negus
Joe Negus
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
