Question about Amana AMV5164BA Microwave Oven
My Amana over the oven microwave will not heat and the timer goes way too fast?
  • 135 Answers
SOURCE: amana mvh230 microwave
Hi there!
The magnetron has probably failed. Check the High Voltage Diode for short circuit. Replace protection fuse with same value. The Diode is standard on most microwaves. Magnetron to be replaced with the same profile and wattage. Be sure to unplug Mains before opening the unit. Good Luck, JUS004
Posted on Feb 29, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: LG microwave no longer heats!
It sounds as though you may have run the microwave while empty, which can damage the magnetron.
Not that I'm optimistic, but the first thing to try is a "hard reset". Unplug it from the power line for a few minutes, plug it back in, set the clock, then try again.
Let us know if the hard reset doesn't fix it.
Otherwise it likely needs a new magnetron.
Posted on Apr 08, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave won't heat, and turntable doesn't turn
All the parts you mention are very inexpensive, but yours does not have a triac.
It could be the cook relay, but it's more likely to be a switch.
Looking at the schematic, it's probably a bad primary interlock (upper door switch) or maybe its mount is bad.
Even though a door switch clicks, it may still be bad inside.
Door switch or mount trouble is usually caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
If you have a broken mount, it's usually more economical and safer to just add a dab or two of hot glue to the mount to secure the switch. Let it cool for about 30 minutes before using.
Here are some helpful links:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
There may also be a "mini-manual" hidden inside the unit behind the control panel or elsewhere, which is very helpful when troubleshooting & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you only need a switch, you can order a universal type here for $5 postpaid.
Posted on Jan 23, 2009
MicrowaveSvc
  • 9047 Answers
SOURCE: replace microwave light bulb
See page 24 of the owner's manual here:
Posted on Feb 08, 2009
  • 686 Answers
SOURCE: Panasonic microwave oven model NN-T774SF remain on
buy new one magnatron is bad
Posted on Feb 26, 2009
Timer clock runs vary fast and will not heat up or cook anything
You have the unit in demo mode, Follow instructions in manual to exit demo.
Oct 29, 2013 | Amana UMV1152CA 1000 Watts Microwave Oven
Doesn't heat. Power on, rotates, timer OK
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Dec 27, 2010 | Amana Radarange Microwave Oven
Amana ACM2160A 1100 Watts Microwave oven doesn't heat
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
heatman101
56ik
May 13, 2010 | Amana ACM2160A Microwave Oven
Tray is not rotating and its not heating up
Basic Microwave Oven TroubleshootingTips
heatman101;'][][\
Apr 25, 2010 | Amana ACO1860 Microwave Oven
Microwave does not heat
heatman101p[]][p
Apr 18, 2010 | Amana ACO1860 Microwave Oven
Amana microwave is loud and doesn't heat. Light
Magnetron went out causing a short-circuit of sorts. Replace magnetron.
Jun 29, 2009 | Amana MVH320 Microwave Oven
Timer runs fast, plus no heat Maytag MMV1153BAW
No... you are not in a microwave induced time warp...
Your microwave oven needs a "reboot". The same thing happened to me.
Unplug your microwave oven, wait about a minute (more or less), plug it back in. Try setting/running your kitchen timer, boil water, etc. Your timer software on the microwave should be reset.
Jun 14, 2009 | Whirlpool MH7135XE Microwave Oven
Abnormal noise produce by Amana microwave RC17
Deart Customer
please undergo the following
Since 30 to 50 percent of the power into a microwave oven is dissipated as heat in the Magnetron, cooling is extremely important. Always inspect the cooling fan/motor for dust and dirt and lubricate if necessary. A couple of drops of electric motor oil or 3-in-One will go a long way. If there are any belts, inspect for deterioration and replace if necessary.
An oven that shuts off after a few minutes of operation could have a cooling problem, a defective overtemperature thermostat, a bad magnetron, or is being operated from very high AC line voltage increasing power to the oven. One interesting note: Since 30 to 50 percent of the power goes out the vents in the back as heat, a microwave oven is really only more efficient than conventional means such as a stovetop or gas or electric oven for heating small quantities of anything. With a normal oven or stovetop, wasted energy goes into heating the pot or oven, the air, and so on. However, this is relatively independent of the quantity of food and may be considered to be a fixed overhead. Therefore, there is a crossover point beyond which it is more efficient to use conventional heat than high tech microwaves
i think the information would help u if so rate me please,otherwise just give it as fixya,Thank u
Dec 17, 2008 | Amana RC17 Microwave Oven
Microwave timer going too fast
I had the same problem and found that the "demo mode" had been enabled. Turned it off and everything worked fine.
Nov 10, 2007 | Whirlpool MH6130XEB/Q Microwave Oven
Amana AMV5164BA Microwave Oven Logo
42 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
