Home
My Products
Sign In
Back to:
All Products
Ricoh
6513 Copier
Troubleshooting
Tags
error code
error
color
SC5
error 60
Ricoh afficio color 6010
posted by
map1
on Jun 17, 2008
Report abuse
error code sc547
Have the same problem? Click Here
X
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
OK
Best Solution
posted on Jun 17, 2008
compuhustler
Rank:
Apprentice
Rating:
70%, 1 votes
· Hot roller fusing
lamp brown
· Hot roller
thermofuse opened
· Defective main
control board
· Defective I/O
control board
· Defective AC drive
board
more than likely the thermofuse.
Rating Locked!
map1 has rated this solution as Thanks for Trying
Thank You!
Was the solution helpful?
Show your appreciation by commenting on ricoh afficio color 6010:
I don't want to Accept this solution
Suggest a new solution for this problem
Post a New problem for Ricoh 6513 Copier
Email this problem
Can you Help with these Copiers problems?
Copiers
My Sharp Digital Laser...
The letters H and 4 appear...
Answer This...
Copiers
i had a red wrench come up on...
i have a ep2010 and it does not...
Answer This...
Copiers
Di351f admin code reset
purchased a used Minolta Dialta...
Answer This...
Copiers
panasonic dp-6010 error code...
where is that motor located, do...
Answer This...
Ricoh 6513 Copier
steps to add toner
i wasn't able to print a copy...
Answer This...
Bogda
Let one of our
Experts Solve
your Problem
Repair Service
Find Copier Repairman Near You:
Advertise Here
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
No
Yes
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
