Question about Panasonic Workio DP-4530 Copier
Hi, i am having an error code E07-21: its level, no paper-jams. Finisher Tray does not move.
I am having the same problem what was your solution?
Posted on Nov 24, 2010
Xerox WorkCentre 7120 error code
Chain Description 001 Cover and Door Interlocks 002 Touch Screen / Control Panel 003, 041, 045, 123 Machine Communications 004 Drives 005 Duplex Automatic Document Feeder (DADF) 061, 062 Scanner, DADF and ROS 007 Paper Supply 008 Paper Feed 009, 089 Xerographics 010, 011 Fuser, Copy Exit 012, 013, 047, 112 Finisher 016, 124, 127 Configuration, Software, Memory, Hard Drives, Color Server, DFE 018 Network Communications 020 Fax, Software 021, 121 Foreign Interface 022 Job Timers 024, 026, 027, 033 Job Parameters 034, 035, 036, 133, 134 Fax Communication 042 Motor, Fan, Sensor 071 Tray 1 Misfeed 072 Tray 2 Misfeed 073 Tray 3 Misfeed 074 Tray 4 Misfeed 075 Tray 5 Misfeed (Bypass Tray) 077 Paper Path Jam 078 High Capacity Feeder 083, 084 Fax Jobs 091 Drum Cartridge 092, 093 ATC, ADC, Toner 094 IBT, BTR 102 Job Queue 103, 116 Software
Aug 23, 2014 | Xerox Office Equipment & Supplies
Xerox docucolor 240-250 not stapling/folding, error codes 012-243, 012-229, 012-225
Koday Hero 7.1 carriage jam. Stuck to the left side. No paper jam can be found but can't get the carriage to move.
Nov 15, 2013 | Office Equipment & Supplies
MY AR-M350N COPIER DISPLAYS F1-15 ERROR CODE, IT ALSO SAYS THAT THE FINISHER IS OUT OF SERVICE. PLEASE I NEED A SOLUTION TO THIS PROBLEM
The error code F1-15 means that the stapler is not in home postion. It can also, be that the exit tray is not in "HP" aswell. I would turn the copier off and turn it back on and not use the stapler funcation. To repair the problem, there are a bunch of up dates to resolve this problem. I would change the out put tray from the finisher to the left out put tray... Good Luck
Mar 17, 2012 | Sharp AR-M350N Copier
I am getting an area R jam followed by SC726-00 service code. The paper is cleared but the machine won't run with the service code notification. Turning off and on again recycles through the R jam and...
SC726: Finisher Shift/Lift Motor Error
Definition [B']
1) Tray shift does not finish within a certain time after the shift motor turned on.
2) The stack height sensor does not activate within a certain time after the shift
tray lift motor turned on.
Possible Causes
• Shift motor defective
• Shift tray lift motor defective
This is a problem with the finisher shift motor normally.
Feb 21, 2011 | Ricoh Aficio 450 Copier
Ricoh error code 741
Hi
SC741 means 1,000-sheet Finisher Error in Saddle. You'll need to check the Stitching Area, Optional Paper Tray Unit. If the tray unit is fine then check the stitching area as well for any paper stuck or bits of paper If there is no paper then it is due to LCT Main Motor Error. You'll need to check the LCT motor whether it is jammed or not. Hope this helps...
Daniel
Sep 30, 2010 | Ricoh Office Equipment & Supplies
I received an error code for my Cannon IR8070 (EOOO583-001) What does this mean?
printnowgrap ; Code 583-001, try to clean the sensor from the finisher, there is a 3 guide before the paper comes out in the exit tray of finisher.that 3 guide moving up and down......Goodluck....
Jul 08, 2009 | Canon iRC3100 Printer
I have a Sharp AR 407 copy machine and when I turn it on it displays an F1-11 error code. Please help me. I work for a nonprofit and we really can't afford to pay someone to fix it. Thank you!
The problem is in your finisher and the quickest solution to get your copier running is to unplug the finisher and move it away from the copier. Take a tray off the finisher and put it on the copier where the paper comes out. (If the paper comes out too slow and causes a misfeed the tension springs need to be put back on over the exit rollers in the left door, write if you still have trouble)
The Engrish service manual sayeth:
F1-11: Finisher 1 pusher motor trouble/Finisher 2 boomerang rotation abnormality.
What this doublespeak means is that something is blocking your motor's ability to function when it goes through its' power on self test. First thing you should never do is put anything near, around, or under the finisher. I went on a lot of calls for F1 errors and either unjammed a finisher from the wall or unstuck a toner or paper box from under the tray. Next thing is to open the front door, move the plate from side to side, and look for bits of paper wedged in anywhere. Spray any photoelectric sensor you see with a can of air. And check those squishy orange rollers and see if they're swollen. Could be you have a dead motor, which would be at the rear of the finisher or inside one of the trays. Good luck!!
Jun 18, 2009 | Sharp AR-407 Copier
Error code E522. How to fix this?
You have an issue with your staple finisher, probably need to inspect the stapler unit itself to make sure nothing is jammed in it and it moves freely. If you can't clear the error then most likely the unit is defective.
Hope this helps,
TankMurdock
Apr 24, 2009 | Canon NP 6551 Black and White Copier
ERROR CODE
hi there, it means that the tray shift motor(the tray that holds the paper out) of your finisher has jammed.
you may put some lubricants on those of gears and guides connected to tray shift motor.
pls let me know if this helped you
Jul 18, 2008 | Panasonic DP-6010 All-In-One Printer
Canon iR8500 with Error E000583-0001
Hello Jeremy,
This error code has to do with your finisher. The auxillary tray is not finding its home position or does not leave the home position within the alotted time. Check for binds. I have limited exposure to the K4/3 finisher but try this. Turn the copier off, and open one of the finisher doors. Now turn the copier back on with the finisher door open so it cannot initialize. Once the copier is basically ready except the finisher door is open, close the finisher door and observe all the **** (and theres alot) initialize. This may help determine the problem. I hope this helps...........................SPINAL
Mar 12, 2008 | Canon imageRUNNER 8500 Copier
Panasonic Workio DP-4530 Copier Logo
79 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
