Question about Refrigerators
Dear reader, We have water leakage at the rear side of the water filter inside the refrigerator. Probably on tube connections, but there is a cover over it. Before i crack something, please give me a hint how to remove this cover. Thanks, Ron
  • 1 more comment
  • ronscheeres Nov 10, 2010
    The leakage is comming from behind the water filter at the right hand top side of the fridge.
    As far as i can see, there are no screws.
    Tried to pull, push or slide but no moving.
    Thanks,
    Ron
  • ronscheeres Nov 11, 2010
    Oh, sorry excuse,
    of coarse that would be helpful LG > GM-F228JTKA.
    Thanks again,
    Ron
  • ronscheeres Nov 17, 2010
    Sorry for this late reaction, very busy at the moment.
    When i Google GM-F228JTKA then i get a lot of links, but none of them with diagrams.
    But thanks enyway, will try sliding, pulling or pushing, and hope nothing breaks off :-).
    Ron
  • 4,070 Answers
Behind the crisper? The cover is usually lift off. If not look for screws up and down the sides. The water reservoir is there and should have connections at each end.
Posted on Nov 10, 2010
  • Charles T Nevin
    Charles T Nevin Nov 10, 2010
    If you can post your model number I may can find a diagram. It's usually stamped on a small tag in a visible location on your appliance.
    Refrigerator-
    Behind the lower toe kick-plate, Behind the lower crisper drawer, On the face frame of the refrigerator body, Inside the refrigerator of freezer on the left or right side wall.
  • Charles T Nevin
    Charles T Nevin Nov 11, 2010
    I can't find a match with the number you provided.
My water dispenser was not working. Tried the defrost trick and still no water. Noticed water under the refrigerator.
The Dispenser supply usually flows through the bottom, inside toward the back to cool the water. If the puddle is near the back. refrigerator section it's probably this water cooling arrangement. Usually. a number of the tubing loops near the back bottom edge. Connections here or tubing itself may leak. It may also be an undetected leak from the Filter housing or the filter is not properly seated or possible filter housing connections. I have had good success with paper towel detection method. Wrap
or paste, tape towel to suspect leak locations. They will soon appear and point to the apparent leak.
Apr 01, 2015 | Refrigerators
Water accumulates in the freezer tray turning to ice & flows to the floor if ice not removed in time.
there is a drain tube along the back inside of freezer side that clogs up with ice use hot water to melt ,and you may have to remove rear cover in back to remove the drain tube on right side to clear it .
Mar 16, 2015 | Whirlpool GB2FHDXWS Bottom Freezer...
Lg refrigerator leaks water inside
Probably water reservoir is leaking. It or tubing going to it probably is cracked.
Sep 28, 2017 | LG LSC26905TT Side by Side Refrigerator
Tube leaking connected to water filter
General Electric refrigerator model number PSS26NSTB SS is not cooling and the fan motor stop
Jun 16, 2012 | General Electric GSS22JET Side by Side...
My fridge is leaking, I don't know from where. I have a towel across the bottom on the inside so it won't leak on the floor. Is there any way I can correct this. There was no change in the temps.
Probably the defrost overflow tube is blocked. That water dripping out of the fridge should be siphoned by the tube to the rear outside of the fridge where the heat from the motor will evaporate the water from the defrost cycle. You need to remove the cover from the inside rear of the freezer andcheck that water can flow down the tube without spilling over the edges of the collection trough.
Nov 08, 2010 | GE 18.2 Cu. Ft. Frost-Free Top-Mount...
No water going to ice maker
Your inlet tube that goes to the icemaker may be frozen. To Check: Shut off water supply to Fridge, disconnect the water line that goes to the icemaker at top back. Use a flexible item to insert in the water line connection. I used a zip tie. If the flexible item won't all the through to the ice maker, the line is frozen. Thaw out the tube from inside the freezer with a hair dryer. Re-connect everything, you now have ice . . . Solution #2: You may have to replace your "Water Inlet Valve" located at bottom right rear of Fridge. Easy to do, just follow the color codes, be sure and shut off the water.
Jun 06, 2010 | Whirlpool GC5SHEXNS Side by Side...
How to clean/pull out reservoir in bottom of fridge?
If the instructions are different than below,I will need you model number. Water Tank Assembly (some models)
1. Remove crisper drawers from fresh food compartment.
2. Remove hex screw holding water tank to rear
bulkhead.
3. On rear of cabinent remove hex screws holding water
valve cover plate.
4. Remove plate and tubing away from cabinet to expose
water valves and tubing.
5. Disconnect water tube from secondary valve coming
from water tank, remove compression nut from tubing.
6. On front of unit remove toe grill and disconnect water
coupler going to water dispenser
7. Remove compression nut from water tubing on cabinet
side of connection.
8. From rear of cabinet pull water tube out of conduit
going to dispenser.
9. From inside of fresh food compartment pull tubing up
and out of cabinet to complete removal of water tank.
10. Reverse procedure to reassemble.
To clean I would use Clorox and warm water and rinse well before replacing. Thanks, Sea Breeze
Apr 18, 2010 | Maytag 22.7 Cu. Ft. Side-by-Side...
Ice buildup from water feeding the ice maker
Are you certain that the ice build-up is actually originating from the water flow into the icemaker? If ice is built-up on the rear freezer panel, then your problem is more than likely a defrost component issue (defrost thermostat or defrost heater(s). If the ice is built-up on the side wall of the freezer near the icemaker, then water is probably being diverted inside the water inlet tubing that goes into the icemaker. This diversion is usually caused by an accumulation of ice inside the water inlet tubing. You will probably need to remove the icemaker in order to glance inside the water inlet tubing to see if ice is in fact inside the tubing. If so, take a screw driver or other object that won't puncture the tubing and remove the ice.
Contact an appliance service company if the ice is on the rear freezer panel.
Feb 17, 2010 | GE GSH25JFR Side by Side Refrigerator
Kenmore Cold spot refrigerator model 106 70182001 leaking inside in the back of the refrigerator. Having to keep bowls in the back of the top shelf. How can I fix this?
Your defrost drain in the frezer is cloged. Every day when your refrig sellf defrosts the water should drain into a hole that leads to a tube wich drains the water to a pan under the refrig. You need to turn offrefrig and remove frezer floor and rear wall and clean out hole and tube with hot water.
Dec 12, 2009 | Cars & Trucks
I side by side refrigerator and I just replaced my water filter. No water will come out now. What do I need to do?
Turn off the water to the filter. Disconnect the water line from the filter to the refrigerator, at the refrigerator. Point the tubing into a bucket and turn the water on. If you're getting water there, you may have a plugged or defective solenoid. Make sure the wires are connected to the solenoid firmly. If the solenoid has a inlet screen, check it for sediment or water filter debris. If necessary, replace the valve.
If there is no water flow at the tubing to the fridge, shut the valve and remove the tubing from the filter to the fridge, at the filter. Inspect the inside of the filter for packing, ostructions, etc. Try again for water. If you get water there, clear or replace your tubing. If no water, close the valve and remove the tubing at the filter that comes from the wall. Check that end of the filter also for pluggage. Test the water line up to the filter. If you get water now, the filter is plugged or defective. Check the flow direction arrow on the filter, if it has one. Some filters have one-way valves. If no water, close the valve again and remove the tubing connection at the valve. Try again.. If you get water now, the tubing to the filter is plugged. If you don't, it'll be the valve or another plumbing issue. If you are getting water everywhere else, replae the valve. You may have to shut off the water to your house and depressure the lines to get at it.
Good luck. Hope this was useful!
Regards, --W/D--
Jul 14, 2009 | Kenmore 51572 / 51574 Side by Side...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
